1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 |
4 | entity TOP is
5 | Port (
6 | CLK : in STD_LOGIC;
7 |
8 | TMDSp_clock : out STD_LOGIC;
9 | TMDSn_clock : out STD_LOGIC
10 | );
11 | end TOP;
12 |
13 | architecture Behavioral of TOP is
14 |
15 | signal RST : STD_LOGIC;
16 | signal CLK25 : STD_LOGIC;
17 | signal CLK100 : STD_LOGIC;
18 |
19 | component OBUFDS
20 | generic (
21 | IOSTANDARD : string := "LVDS_25"
22 | );
23 | port (
24 | I : in STD_LOGIC;
25 | O : out STD_LOGIC;
26 | OB : out STD_LOGIC
27 | );
28 | end component;
29 |
30 | component DCM
31 | generic (
32 | DFS_FREQUENCY_MODE : string := "LOW";
33 | DLL_FREQUENCY_MODE : string := "LOW";
34 | DUTY_CYCLE_CORRECTION : boolean := TRUE;
35 | CLKIN_DIVIDE_BY_2 : boolean := FALSE;
36 | CLK_FEEDBACK : string := "1X";
37 | CLKOUT_PHASE_SHIFT : string := "NONE";
38 | DSS_MODE : string := "NONE";
39 | STARTUP_WAIT : boolean := FALSE;
40 | PHASE_SHIFT : integer := 0;
41 | CLKFX_MULTIPLY : integer := 4;
42 | CLKFX_DIVIDE : integer := 1;
43 | CLKDV_DIVIDE : real := 2.0;
44 | CLKIN_PERIOD : real := 41.66666;
45 | DESKEW_ADJUST : string := "SYSTEM_SYNCHRONOUS";
46 | CLKIN_BUF : boolean := FALSE;
47 | CLKFB_BUF : boolean := FALSE;
48 | CLK0_BUF : boolean := FALSE;
49 | CLK90_BUF : boolean := FALSE;
50 | CLK180_BUF : boolean := FALSE;
51 | CLK270_BUF : boolean := FALSE;
52 | CLKDV_BUF : boolean := FALSE;
53 | CLK2X_BUF : boolean := FALSE;
54 | CLK2X180_BUF : boolean := FALSE;
55 | CLKFX_BUF : boolean := FALSE;
56 | CLKFX180_BUF : boolean := FALSE;
57 | EXT_RESET_HIGH : integer := 1
58 | );
59 | port (
60 | CLKIN : in std_logic;
61 | CLKFB : in std_logic;
62 | DSSEN : in std_logic;
63 | PSINCDEC : in std_logic;
64 | PSEN : in std_logic;
65 | PSCLK : in std_logic;
66 | RST : in std_logic;
67 | CLK0 : out std_logic;
68 | CLK90 : out std_logic;
69 | CLK180 : out std_logic;
70 | CLK270 : out std_logic;
71 | CLK2X : out std_logic;
72 | CLK2X180 : out std_logic;
73 | CLKDV : out std_logic;
74 | CLKFX : out std_logic;
75 | CLKFX180 : out std_logic;
76 | LOCKED : out std_logic;
77 | PSDONE : out std_logic;
78 | STATUS : out std_logic_vector(7 downto 0)
79 | );
80 | end component;
81 |
82 | begin
83 |
84 | DCM_inst : DCM
85 | generic map (
86 | CLKDV_DIVIDE => 4.0,
87 | CLKIN_PERIOD => 10.0,
88 | CLKIN_BUF => TRUE,
89 | CLK0_BUF => TRUE,
90 | CLKDV_BUF => TRUE
91 | )
92 | port map (
93 | CLKIN => CLK, -- Clock input (from IBUFG, BUFG or DCM)
94 | CLKFB => CLK100, -- DCM clock feedback
95 | DSSEN => '0', -- ?
96 | PSINCDEC => '0', -- Dynamic phase adjust increment/decrement
97 | PSEN => '0', -- Dynamic phase adjust enable input
98 | PSCLK => '0', -- Dynamic phase adjust clock input
99 | RST => '0', -- DCM asynchronous reset input
100 | CLK0 => CLK100, -- 0 degree DCM CLK ouptput
101 | CLK90 => open, -- 90 degree DCM CLK output
102 | CLK180 => open, -- 180 degree DCM CLK output
103 | CLK270 => open, -- 270 degree DCM CLK output
104 | CLK2X => open, -- 2X DCM CLK output
105 | CLK2X180 => open, -- 2X, 180 degree DCM CLK out
106 | CLKDV => CLK25, -- Divided DCM CLK out (CLKDV_DIVIDE)
107 | CLKFX => open, -- DCM CLK synthesis out (M/D)
108 | CLKFX180 => open, -- 180 degree CLK synthesis out
109 | LOCKED => open, -- DCM LOCK status output
110 | PSDONE => open, -- Dynamic phase adjust done output
111 | STATUS => open -- 8-bit DCM status bits output
112 | );
113 |
114 | OBUFDS_TMDSCLK: OBUFDS
115 | port map (
116 | I => CLK25,
117 | O => TMDSp_clock,
118 | OB => TMDSn_clock
119 | );
120 |
121 | end Behavioral;
