1 | /*
2 | * File: main7219.c
3 | * Author: BeastyK
4 | *
5 | * Created on 9. Oktober 2016, 17:54
6 | */
7 |
8 |
9 | #include <xc.h>
10 | #include <delays.h>
11 | #include <spi.h>
12 | #include <timers.h>
13 | #include <stdio.h>
14 | #include <stdlib.h>
15 | #include "m7219.h"
16 |
17 | #define _XTAL_FREQ 20000000
18 |
19 | void Timer1Init();
20 | void interrupt_isr(void);
21 | //void max7219_time_write(unsigned int std, unsigned int min, unsigned int sek);
22 |
23 | /*****************************************************************************/
24 | /** C O N F I G U R A T I O N ************************************************/
25 | /*****************************************************************************/
26 |
27 |
28 | // PIC18F4455 Configuration Bit Settings
29 |
30 | // 'C' source line config statements
31 |
32 | // CONFIG1L
33 | #pragma config PLLDIV = 5 // PLL Prescaler Selection bits (Divide by 5 (20 MHz oscillator input))
34 | #pragma config CPUDIV = OSC1_PLL2// System Clock Postscaler Selection bits ([Primary Oscillator Src: /1][96 MHz PLL Src: /2])
35 | #pragma config USBDIV = 2 // USB Clock Selection bit (used in Full-Speed USB mode only; UCFG:FSEN = 1) (USB clock source comes from the 96 MHz PLL divided by 2)
36 |
37 | // CONFIG1H
38 | #pragma config FOSC = HSPLL_HS // Oscillator Selection bits (HS oscillator, PLL enabled (HSPLL))
39 | #pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
40 | #pragma config IESO = OFF // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
41 |
42 | // CONFIG2L
43 | #pragma config PWRT = OFF // Power-up Timer Enable bit (PWRT disabled)
44 | #pragma config BOR = ON // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
45 | #pragma config BORV = 3 // Brown-out Reset Voltage bits (Minimum setting 2.05V)
46 | #pragma config VREGEN = ON // USB Voltage Regulator Enable bit (USB voltage regulator enabled)
47 |
48 | // CONFIG2H
49 | #pragma config WDT = OFF // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
50 | #pragma config WDTPS = 32768 // Watchdog Timer Postscale Select bits (1:32768)
51 |
52 | // CONFIG3H
53 | #pragma config CCP2MX = ON // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
54 | #pragma config PBADEN = OFF // PORTB A/D Enable bit (PORTB<4:0> pins are configured as digital I/O on Reset)
55 | #pragma config LPT1OSC = OFF // Low-Power Timer 1 Oscillator Enable bit (Timer1 configured for higher power operation)
56 | #pragma config MCLRE = ON // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
57 |
58 | // CONFIG4L
59 | #pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
60 | #pragma config LVP = OFF // Single-Supply ICSP Enable bit (Single-Supply ICSP disabled)
61 | #pragma config ICPRT = OFF // Dedicated In-Circuit Debug/Programming Port (ICPORT) Enable bit (ICPORT disabled)
62 | #pragma config XINST = OFF // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
63 |
64 | // CONFIG5L
65 | #pragma config CP0 = OFF // Code Protection bit (Block 0 (000800-001FFFh) is not code-protected)
66 | #pragma config CP1 = OFF // Code Protection bit (Block 1 (002000-003FFFh) is not code-protected)
67 | #pragma config CP2 = OFF // Code Protection bit (Block 2 (004000-005FFFh) is not code-protected)
68 |
69 | // CONFIG5H
70 | #pragma config CPB = OFF // Boot Block Code Protection bit (Boot block (000000-0007FFh) is not code-protected)
71 | #pragma config CPD = OFF // Data EEPROM Code Protection bit (Data EEPROM is not code-protected)
72 |
73 | // CONFIG6L
74 | #pragma config WRT0 = OFF // Write Protection bit (Block 0 (000800-001FFFh) is not write-protected)
75 | #pragma config WRT1 = OFF // Write Protection bit (Block 1 (002000-003FFFh) is not write-protected)
76 | #pragma config WRT2 = OFF // Write Protection bit (Block 2 (004000-005FFFh) is not write-protected)
77 |
78 | // CONFIG6H
79 | #pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) are not write-protected)
80 | #pragma config WRTB = OFF // Boot Block Write Protection bit (Boot block (000000-0007FFh) is not write-protected)
81 | #pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM is not write-protected)
82 |
83 | // CONFIG7L
84 | #pragma config EBTR0 = OFF // Table Read Protection bit (Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks)
85 | #pragma config EBTR1 = OFF // Table Read Protection bit (Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks)
86 | #pragma config EBTR2 = OFF // Table Read Protection bit (Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks)
87 |
88 | // CONFIG7H
89 | #pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot block (000000-0007FFh) is not protected from table reads executed in other blocks)
90 |
91 | // #pragma config statements should precede project file includes.
92 | // Use project enums instead of #define for ON and OFF.
93 |
94 | /*****************************************************************************/
95 | /**** M A I N P R O G R A M ************************************************/
96 | /*****************************************************************************/
97 |
98 | unsigned char i;
99 | unsigned int second = 0, minute = 0, hour = 0;
100 |
101 | void Timer1Init() {
102 |
103 | //Timer1 ist ein 16bit Timer (FFFFh oder 65535) mit jeweils 8bit Timer High
104 | //und 8bit Timer Low mit externen Uhrenquarz von 32768Hz wird der Interrupt nach
105 | //2 Sekunden gesetzt, daher wird TMR1H auf 80h gesetzt (8000h ist der gesamte
106 | //Timer1 aus TMR1H und TMR1L und entspricht 32768)
107 | TMR1H = 0x80; //setzt Msb des oberen 8bit des Timer1 auf 1
108 | TMR1L = 0; //setzt die unteren 8bit des Timers1 auf Null
109 | TRISCbits.TRISC0 = 1; //setzt TRISC0 auf Eingang (warum aber nicht TRISC1?)
110 | LATBbits.LATB6 = 1; //setzt den PM-Zeit bit
111 | T1CON = 0b00001111; // 2x8bit, externer Takt, Osc enabled, asynch, start!
112 | PIE1bits.TMR1IE = 1;
113 | INTCONbits.PEIE = 1;
114 | //RCONbits.IPEN=0x01;
115 | //IPR1bits.TMR1IP=0x01; // TMR1 high priority ,TMR1 Overflow Interrupt Priority bit
116 | INTCONbits.GIE = 1;
117 | PIR1bits.TMR1IF = 0; //setzt den Timerinterrupt von Timer1 auf Null
118 | }
119 |
120 | void interrupt isr(void)
121 | {
122 | //TMR1H |= 0x80;
123 | if (PIR1bits.TMR1IF)
124 | {
125 | unsigned int d = 0, e = 0, f = 0, std = 0, min = 0, sek = 0;
126 | second++;
127 | // max7219new++;
128 | TMR1H = 0x70;
129 | //PIR1bits.TMR1IF = 0; //TMR1IF überlauf muß per software zurückgesetzt werden (Datenblatt Seite 102)
130 |
131 |
132 | if (second >= 60) //ist second gleich oder größer 60 dann
133 | {
134 | minute++; //Variable minute um 1 erhöhen (60 Sekunden sind eine Minute)
135 | second = 0; //die Variable second beim Timerinterrupt wieder von 0 anfangen lassen zu zählen
136 | }
137 |
138 | if (minute >= 60) //ist minute gleich oder größer 60 dann
139 | {
140 | hour++; //Variable hour um 1 erhöhen (60 Minuten sind eine Stunde)
141 | minute = 0; //die Variable minute wieder auf 0 setzen damit eine neue Minute gezählt wird
142 | }
143 | if (hour >= 24)
144 | {
145 | hour = 0;
146 | }
147 |
148 | //if (max7219new >= 1)
149 | // {
150 | // max7219_time_write(hour, minute, second);
151 | // max7219new = 0;
152 | // }
153 | //d = hour / 10;
154 | //std = hour - (d * 10);
155 | //max7219_digitwrite(3, d);
156 | //max7219_digitwrite(4, std);
157 | //e = minute / 10;
158 | //min = minute - (e * 10);
159 | //max7219_digitwrite(5, e);
160 | //max7219_digitwrite(6, min);
161 | f = second / 10;
162 | sek = second - (f * 10);
163 | max7219_digitwrite(7, f);
164 | max7219_digitwrite(8, sek);
165 |
166 | PIR1bits.TMR1IF = 0; //TMR1IF überlauf muß per software zurückgesetzt werden (Datenblatt Seite 102)
167 | }
168 | }
169 |
170 | /*void max7219_time_write(unsigned int std, unsigned int min, unsigned int sek)
171 | {
172 | unsigned int d = 0, e = 0, f = 0;
173 |
174 | d = std / 10;
175 | std = std - (d * 10);
176 | max7219_digitwrite(3, d);
177 | max7219_digitwrite(4, std);
178 | e = min / 10;
179 | min = min - (e * 10);
180 | max7219_digitwrite(5, e);
181 | max7219_digitwrite(6, min);
182 | f = sek / 10;
183 | sek = sek - (f * 10);
184 | max7219_digitwrite(7, f);
185 | max7219_digitwrite(8, sek);
186 |
187 |
188 | }
189 | */
190 | void main(void)
191 | {
192 | __delay_ms(25); //Delay of 100ms
193 | __delay_ms(25);
194 | __delay_ms(25);
195 | __delay_ms(25);
196 | OpenSPI(SPI_FOSC_16, MODE_00, SMPMID); // MODE besteht aus CKP/CKE, ist CKP gleich 1, SCK sendet nicht bei hohen Pegel oder CKP ist 0, SCK
197 | //sendet nicht bei niedrigen Pegel.
198 | __delay_ms(25); //Delay of 100ms
199 | __delay_ms(25);
200 | __delay_ms(25); //Delay of 100ms
201 | __delay_ms(25);
202 |
203 | TRISC &= 0xFB; // 1111 1011
204 | TRISD = 0xF0; // 1111 0000
205 | LATDbits.LATD0 = 1; //Set D0 high
206 | __delay_ms(25); //Delay of 100ms
207 | __delay_ms(25);
208 | __delay_ms(25); //Delay of 100ms
209 | __delay_ms(25);
210 | max7219_init();
211 | __delay_ms(25); //Delay of 100ms
212 | __delay_ms(25);
213 | __delay_ms(25); //Delay of 100ms
214 | __delay_ms(25);
215 | Timer1Init();
216 | __delay_ms(25); //Delay of 100ms
217 | __delay_ms(25);
218 | __delay_ms(25); //Delay of 100ms
219 | __delay_ms(25);
220 |
221 | while(1)
222 | {
223 |
224 | }
225 | }
