1 | //**************************************************************//
2 | // Name : shiftIn Example 2.1 //
3 | // Author : Carlyn Maw //
4 | // Date : 25 Jan, 2007 //
5 | // Version : 1.0 //
6 | // Notes : Code for using a CD4021B Shift Register //
7 | // : //
8 | //****************************************************************
9 |
10 | //define where your pins are
11 | int latchPin = 8;
12 | int dataPin = 9;
13 | int clockPin = 7;
14 |
15 | //Define variables to hold the data
16 | //for each shift register.
17 | //starting with non-zero numbers can help
18 | //troubleshoot
19 | byte switchVar1 = 72; //01001000
20 | byte switchVar2 = 159; //10011111
21 |
22 | char Taste[] = {'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H'};
23 |
24 | void setup() {
25 | //start serial
26 | Serial.begin(9600);
27 |
28 | //define pin modes
29 | pinMode(latchPin, OUTPUT);
30 | pinMode(clockPin, OUTPUT);
31 | pinMode(dataPin, INPUT);
32 |
33 | }
34 |
35 | void loop() {
36 |
37 | //Pulse the latch pin:
38 | //set it to 1 to collect parallel data
39 | digitalWrite(latchPin,1);
40 | //set it to 1 to collect parallel data, wait
41 | delayMicroseconds(20);
42 | //set it to 0 to transmit data serially
43 | digitalWrite(latchPin,0);
44 |
45 | //while the shift register is in serial mode
46 | //collect each shift register into a byte
47 | //the register attached to the chip comes in first
48 | switchVar1 = shiftIn(dataPin, clockPin);
49 | switchVar2 = shiftIn(dataPin, clockPin);
50 |
51 | //Print out the results.
52 | //leading 0's at the top of the byte
53 | //(7, 6, 5, etc) will be dropped before
54 | //the first pin that has a high input
55 | //reading
56 |
57 | for (int n=0; n<=7; n++)
58 | {
59 | //so, when n is 3, it compares the bits
60 | //in switchVar1 and the binary number 00001000
61 | //which will only return true if there is a
62 | //1 in that bit (ie that pin) from the shift
63 | //register.
64 | if (switchVar1 & (1 << n) ){
65 | //print the value of the array location
66 | Serial.println(Taste[n]);
67 | }
68 | }
69 |
70 |
71 |
72 |
73 |
74 | //white space
75 | Serial.println("-------------------");
76 | //delay so all these print satements can keep up.
77 | delay(500);
78 | }
79 | }
80 |
81 | //------------------------------------------------end main loop
82 |
83 | ////// ----------------------------------------shiftIn function
84 | ///// just needs the location of the data pin and the clock pin
85 | ///// it returns a byte with each bit in the byte corresponding
86 | ///// to a pin on the shift register. leftBit 7 = Pin 7 / Bit 0= Pin 0
87 |
88 | byte shiftIn(int myDataPin, int myClockPin) {
89 | int i;
90 | int temp = 0;
91 | int pinState;
92 | byte myDataIn = 0;
93 |
94 | pinMode(myClockPin, OUTPUT);
95 | pinMode(myDataPin, INPUT);
96 |
97 | //we will be holding the clock pin high 8 times (0,..,7) at the
98 | //end of each time through the for loop
99 |
100 | //at the begining of each loop when we set the clock low, it will
101 | //be doing the necessary low to high drop to cause the shift
102 | //register's DataPin to change state based on the value
103 | //of the next bit in its serial information flow.
104 | //The register transmits the information about the pins from pin 7 to pin 0
105 | //so that is why our function counts down
106 | for (i=7; i>=0; i--)
107 | {
108 | digitalWrite(myClockPin, 0);
109 | delayMicroseconds(2);
110 | temp = digitalRead(myDataPin);
111 | if (temp) {
112 | pinState = 1;
113 | //set the bit to 0 no matter what
114 | myDataIn = myDataIn | (1 << i);
115 | }
116 | else {
117 | //turn it off -- only necessary for debuging
118 | //print statement since myDataIn starts as 0
119 | pinState = 0;
120 | }
121 |
122 | //Debuging print statements
123 | //Serial.print(pinState);
124 | //Serial.print(" ");
125 | //Serial.println (dataIn, BIN);
126 |
127 | digitalWrite(myClockPin, 1);
128 |
129 | }
130 | //debuging print statements whitespace
131 | //Serial.println();
132 | //Serial.println(myDataIn, BIN);
133 | return myDataIn;
134 | }
