1 | //**************************************************************//
2 | // Name : shiftIn Example 2.1 //
3 | // Author : Carlyn Maw //
4 | // Date : 25 Jan, 2007 //
5 | // Version : 1.0 //
6 | // Notes : Code for using a CD4021B Shift Register //
7 | // : //
8 | //****************************************************************
9 |
10 | //define where your pins are
11 | int latchPin = 8;
12 | int dataPin = 9;
13 | int clockPin = 7;
14 |
15 | //Define variables to hold the data
16 | //for each shift register.
17 | //starting with non-zero numbers can help
18 | //troubleshoot
19 | byte switchVar1 = 72; //01001000
20 | byte switchVar2 = 159; //10011111
21 |
22 |
23 | int Befehl = 183; //Note on, Kanal 8
24 | int S1Taste[] = {1, 2, 3, 4, 5, 6, 7, 8};
25 | int S2Taste[] = {9, 10, 11, 12, 13, 14, 15, 16};
26 | int Wert1 = 127;
27 | int Wert2 = 0;
28 |
29 | int TasteAlt;
30 |
31 | void setup() {
32 | //start serial
33 | Serial.begin(9600);
34 |
35 | //define pin modes
36 | pinMode(latchPin, OUTPUT);
37 | pinMode(clockPin, OUTPUT);
38 | pinMode(dataPin, INPUT);
39 |
40 | }
41 |
42 |
43 | ////// ----------------------------------------shiftIn function
44 | ///// just needs the location of the data pin and the clock pin
45 | ///// it returns a byte with each bit in the byte corresponding
46 | ///// to a pin on the shift register. leftBit 7 = Pin 7 / Bit 0= Pin 0
47 |
48 | byte shift(int myDataPin, int myClockPin) {
49 | int i;
50 | int temp = 0;
51 | int pinState;
52 | byte myDataIn = 0;
53 |
54 | pinMode(myClockPin, OUTPUT);
55 | pinMode(myDataPin, INPUT);
56 |
57 | //we will be holding the clock pin high 8 times (0,..,7) at the
58 | //end of each time through the for loop
59 |
60 | //at the begining of each loop when we set the clock low, it will
61 | //be doing the necessary low to high drop to cause the shift
62 | //register's DataPin to change state based on the value
63 | //of the next bit in its serial information flow.
64 | //The register transmits the information about the pins from pin 7 to pin 0
65 | //so that is why our function counts down
66 | for (i = 7; i >= 0; i--)
67 | {
68 | digitalWrite(myClockPin, 0);
69 | delayMicroseconds(2);
70 | temp = digitalRead(myDataPin);
71 | if (temp) {
72 | pinState = 1;
73 | //set the bit to 0 no matter what
74 | myDataIn = myDataIn | (1 << i);
75 | }
76 | else {
77 | //turn it off -- only necessary for debuging
78 | //print statement since myDataIn starts as 0
79 | pinState = 0;
80 | }
81 |
82 | //Debuging print statements
83 | //Serial.print(pinState);
84 | //Serial.print(" ");
85 | //Serial.println (dataIn, BIN);
86 |
87 | digitalWrite(myClockPin, 1);
88 |
89 | }
90 | //debuging print statements whitespace
91 | //Serial.println();
92 | //Serial.println(myDataIn, BIN);
93 | return myDataIn;
94 | }
95 |
96 |
97 | void loop() {
98 |
99 | //Pulse the latch pin:
100 | //set it to 1 to collect parallel data
101 | digitalWrite(latchPin, 1);
102 | //set it to 1 to collect parallel data, wait
103 | delayMicroseconds(20);
104 | //set it to 0 to transmit data serially
105 | digitalWrite(latchPin, 0);
106 |
107 | //while the shift register is in serial mode
108 | //collect each shift register into a byte
109 | //the register attached to the chip comes in first
110 | switchVar1 = shift(dataPin, clockPin);
111 | switchVar2 = shift(dataPin, clockPin);
112 |
113 | //Print out the results.
114 | //leading 0's at the top of the byte
115 | //(7, 6, 5, etc) will be dropped before
116 | //the first pin that has a high input
117 | //reading
118 |
119 | for (int n = 0; n <= 7; n++)
120 | {
121 | //so, when n is 3, it compares the bits
122 | //in switchVar1 and the binary number 00001000
123 | //which will only return true if there is a
124 | //1 in that bit (ie that pin) from the shift
125 | //register.
126 | if ((switchVar1 & (1 << n) ) && TasteAlt==LOW ) {
127 | //print the value of the array location
128 | Serial.println(Befehl);
129 | Serial.println(S1Taste[n]);
130 | Serial.println(Wert1);
131 | TasteAlt=HIGH;
132 | }
133 | else if ((switchVar1 & (1 << n) ) && TasteAlt==HIGH ) {
134 | //print the value of the array location
135 | Serial.println(Befehl);
136 | Serial.println(S1Taste[n]);
137 | Serial.println(Wert2);
138 | TasteAlt=LOW;
139 | }
140 | }
141 |
142 |
143 | for (int n = 0; n <= 7; n++)
144 | {
145 | //so, when n is 3, it compares the bits
146 | //in switchVar1 and the binary number 00001000
147 | //which will only return true if there is a
148 | //1 in that bit (ie that pin) from the shift
149 | //register.
150 | if ((switchVar2 & (1 << n) ) && TasteAlt==LOW ) {
151 | //print the value of the array location
152 | Serial.println(Befehl);
153 | Serial.println(S2Taste[n]);
154 | Serial.println(Wert1);
155 | TasteAlt=HIGH;
156 | }
157 | else if ((switchVar2 & (1 << n) ) && TasteAlt==HIGH ) {
158 | //print the value of the array location
159 | Serial.println(Befehl);
160 | Serial.println(S2Taste[n]);
161 | Serial.println(Wert2);
162 | TasteAlt=LOW;
163 | }
164 | }
165 |
166 | /* if (switchVar2 & (1 << n) && TasteAlt==LOW ) {
167 | //print the value of the array location
168 | Serial.println(Befehl);
169 | Serial.println(S2Taste[n]);
170 | Serial.println(Wert1);
171 | TasteAlt=HIGH;
172 | }
173 | else if ((switchVar2 & (1 << n) ) && TasteAlt==HIGH ) {
174 | //print the value of the array location
175 | Serial.println(Befehl);
176 | Serial.println(S1Taste[n]);
177 | Serial.println(Wert2);
178 | TasteAlt=LOW;
179 | }
180 | } */
181 |
182 | //white space
183 | Serial.println("-------------------");
184 | //delay so all these print satements can keep up.
185 | delay(500);
186 | }
187 |
188 | //------------------------------------------------end main loop
