Wuste nichts besseres mit dem Pollin 5€ Gutschein anzufangen und hab mir ein Display und eine IC-Tüte mit Majo bestellt :-) Die hälfte des Sortiments ist auch etwas für den Elektronikschrott aber 2 Cips sind echt Prima. Es geht um 2 mal BECK IPC@CHIP SC12 (20MHz) C13 (40MHz) http://www.beck-ipc.com/en/products/sc1x/sc13.asp - 80186 and 80188 compatible microcontroller with 512KB RAM and 512KB flash - 6 x 256-byte I/O space - Low-power CMOS process with single 5V power supply - Up to 14 programmable I/O (PIO) pins - Two full-featured asynchronous serial ports allow full-duplex, 7-bit or 8-bit data transfers, Serial port hardware handshaking with CTS and RTS selectable for each port - Independent serial port baud rate generators DMA to and from the serial ports - Ethernet controller IEEE 802.3 10/100 Base-T Full/Half Duplex2 - Watchdog timer - Pulse-width demodulation option - Two independent DMA channels - Programmable interrupt controller with up to six external interrupts - Two programmable 16-bit timers, interrupt capable - Programmable memory and peripheral chip-select logic - Pre-installed Realtime RTOS - 32-pin, plastic pack (DIL32) Unmengen an Software und nützliche Beispiele stehen zum Download bereit. CHIP-RTOS UDP configuration server protocol FTP server/client and a Telnet client Source Level Remote Debugger 3S CODESYS, C++ Beck Edition of Borland, Pascal, C++ IDE BIOS Application Programming Interface Example to read and write user persistent data that are stored in a RTOS CGI - Common Gateway Interface Example that shows how CGI functions could create and handle cookies. Example demonstrating how to control and view the digital I/Os Example demonstrates how a CGI handler can be installed for HTTP error codes, e.g. 404. FileUpload - This HTML page shows how to transfer files to the IPC@CHIP® using the HTTP put method. Requires a special RTOS available on demand. MiniCGI - Small example clarifying the use of CGI on the IPC@CHIP®. The installed CGI page returns the remote IP address. SMPT, POP3 ... - External Memory - Serial ports - FOSSIL - Hardware Application Programming Interface and many many more ... Ist halt etwas für die kommenden kalten dunklen Tage wenn man Spass am "Tüfteln" hat. DJ
So ist dein Post ein bisschen nutzlos..musst dann schon zeigen wenn's läuft
Irgendwie hatte Beck da ein komisches Lizenzmodell (wie es heute aussieht weiss ich nicht. Aber wenn die bei Pollin auftauchen ist das wohl gescheitert). An sich war es ein guter Ansatz, aber in Stückzahlen und legal war es einfach zu teuer - ich habe diesbezügliche Projekte vor 5 Jahren eingestampft und nicht wieder angefasst.
D.j. P. schrieb: > Es geht um 2 mal BECK IPC@CHIP SC12 (20MHz) C13 (40MHz) Dein Link sagte 2016: "Not recommended for new application Last buy date: February 15, 2010 Last shipment date: February 15, 2011 Last service date: February 15, 2012"
H.Joachim S. schrieb: > Aber wenn die bei Pollin auftauchen ist das wohl gescheitert Würde ich so nicht sagen - laut Beck-Homepage spezialisieren sie sich bis heute auf diese IPCs. Es ist vollkommen normal, dass ältere Hardwaregenerationen zyklisch durch neue ersetzt werden - so auch hier. Und wenn ich mich recht erinnere, wurde der SC12/13 bereits um die Jahrhundertwende herum in Elektor beworben (oder war es der SC11? - Meine Fresse, bin ich alt...). Daher würde ich nicht auf ein gescheitertes Geschäftsmodell schließen, sondern lediglich auf Abverkauf auf Grund von Generationenwechsel. oszi40 schrieb: > Dein Link sagte 2016: > "Not recommended for new application > Last buy date: February 15, 2010 > Last shipment date: February 15, 2011 > Last service date: February 15, 2012" Naja - einen Intel Core i7-7700k wird man wohl kaum in den Pollintütchen finden - aber dieser Fund ist IMHO wahrlich deutlich besser als ein NE555 von anno 1982 oder so - Pollin ist nun einmal Resteverwerter und kein Katalogdistributor.
Toni Tester schrieb: > aber dieser Fund ist IMHO wahrlich deutlich besser als ein > NE555 von anno 1982 oder so Vergaloppiert! Aus einem 555 auf die Schnelle was Sinnvolles zaubern - versuche das mal mit 'nem BECK!
Toni Tester schrieb: > Es ist vollkommen normal, dass ältere Hardwaregenerationen zyklisch > durch neue ersetzt werden Ich würde mir keinen Oldi kaufen, wo mir nur wenige helfen können.
Setze dich mal mit Hennes zusammen, der könnte den Chip für seine Audio Anwendung gebrauchen.
den sc13 würde ich dir sofort abnehmen. habe hier ein board von"damals" wo genau der kaputt ist... willste den los werden? (mag bei pollin deshalb nicht viele wundertüten kaufen) mach einen preisvorschlag! tks zipp
Wenn SC12 oder SC23 benötigt werden --> markus1bernhard@gmail.com
Was soll man mit dem BECK Schrott noch machen? Ich meine, gegen 2006-2007 gab es nicht viele Alternativen, vielleicht ein paar ARM7 mit Ethernet MAC. Aber heute, gibt es genug Module, die ins "Internet" können und das für einen Bruchteil vom Preis.
So isses. 2010 habe ich die aus allen Designs rausgeschmissen.
Für mich als Außenstehenden sieht das aus, also ob die Entwicklungstools für diese Module viel zu teuer sind, um sie für ein paar Einzelstücke davon zu kaufen. Vielleicht täusche ich mich, aber es erscheint zunächst so.
Ich hatte mal eine Anwendung mit einem Beck IPC. Die API für den SPI ist so vergurkt, dass ich mit einem als Zähler konfigurierten Timer alle acht Takte stumpf das Byte auslesen musste. Wenn ich mich recht erinnere war der Slave auf 16 bit Worte angewiesen bei denen der Chipselect nicht unterbrochen werden konnte und der Beck kam damit nicht klar. Grausam, aber lief komischerweise recht stabil... (ein paar "far long megajump" später, natürlich, weil das Speichermodell eines 186er halt eingeschränkt ist nach heutigen Maßstäben). Das ist nun auch schon wieder fast 10 Jahre her und freiwillig würde ich mir das nicht mehr antun. Hach, das waren noch Zeiten ;-)
