1 | #include "board.h"
2 | #include "cli.h"
3 |
4 | #include "FreeRTOS.h"
5 | #include "task.h"
6 |
7 | #include "stdio.h"
8 | #include "cdc_vcom.h"
9 |
10 | extern ErrorCode_t USB_Init(void);
11 | extern USBD_API_INIT_PARAM_T usb_param;
12 |
13 | long ledStackHighWaterMark;
14 | long uartStackHighWaterMark;
15 |
16 | static TaskHandle_t xUARTTaskHandle = NULL;
17 |
18 | static short rx_byte;
19 | static char rx_status;
20 |
21 | void UART_IRQHandler(void)
22 | {
23 | BaseType_t xHigherPriorityTaskWoken = pdFALSE;
24 |
25 | uint8_t iirvalue = Chip_UART_ReadIntIDReg(LPC_USART) & UART_IIR_INTID_MASK;
26 | if ((iirvalue == UART_IIR_INTID_RLS) || (iirvalue == UART_IIR_INTID_RDA))
27 | {
28 | rx_status = Chip_UART_ReadLineStatus(LPC_USART) & (UART_LSR_OE | UART_LSR_PE | UART_LSR_BI | UART_LSR_FE | UART_LSR_RXFE);
29 | rx_byte = Chip_UART_ReadByte(LPC_USART);
30 | }
31 | else if (iirvalue == UART_IIR_INTID_CTI) /* Character timeout indicator */
32 | {
33 | // if (UART_Character_Timeout)
34 | // UART_Character_Timeout();
35 | }
36 | else if (iirvalue == UART_IIR_INTID_THRE) /* THRE, transmit holding register empty */
37 | {
38 | /* all data transmitted on UART disable UART_IER_THREINT */
39 | Chip_UART_IntDisable(LPC_USART, UART_IER_THREINT);
40 | }
41 |
42 | NVIC_ClearPendingIRQ(UART0_IRQn);
43 |
44 | /* Notify the task that the transmission is complete. */
45 | // vTaskNotifyGiveFromISR( xUARTTaskHandle, &xHigherPriorityTaskWoken );
46 |
47 | /* If xHigherPriorityTaskWoken is now set to pdTRUE then a context switch
48 | should be performed to ensure the interrupt returns directly to the highest
49 | priority task. The macro used for this purpose is dependent on the port in
50 | use and may be called portEND_SWITCHING_ISR(). */
51 | // portYIELD_FROM_ISR( xHigherPriorityTaskWoken );
52 | }
53 |
54 | static void vUARTTask(void *pvParameters)
55 | {
56 | uint32_t ulNotificationValue;
57 | const TickType_t xMaxBlockTime = pdMS_TO_TICKS( 1000 );
58 |
59 | /* Store the handle of the calling task. */
60 | xUARTTaskHandle = xTaskGetCurrentTaskHandle();
61 |
62 | for (;;)
63 | {
64 | uartStackHighWaterMark = uxTaskGetStackHighWaterMark( NULL );
65 |
66 | /* Wait for the transmission to complete. */
67 | ulNotificationValue = ulTaskNotifyTake( pdFALSE, xMaxBlockTime );
68 |
69 | if( ulNotificationValue >= 1 )
70 | {
71 | /* The transmission ended as expected. */
72 | printf("ISR - ch = 0x%02x\r\n", rx_byte);
73 | }
74 | else
75 | {
76 | /* The call to ulTaskNotifyTake() timed out. */
77 | printf("TO\r\n");
78 | // rx_byte = Chip_UART_ReadByte(LPC_USART);
79 | // printf("ch = %x\r\n", rx_byte);
80 | }
81 | }
82 | }
83 |
84 | /* LED toggle thread */
85 | static void vLEDTask(void *pvParameters)
86 | {
87 | for (;;)
88 | {
89 | ACT_LED_TOGGLE();
90 | vTaskDelay(configTICK_RATE_HZ/2);
91 | ledStackHighWaterMark = uxTaskGetStackHighWaterMark( NULL );
92 | }
93 | }
94 |
95 | /* STATS thread */
96 | static void vStatsTask(void *pvParameters)
97 | {
98 | for (;;)
99 | {
100 | vTaskDelay(configTICK_RATE_HZ*10);
101 | printf("\r\n");
102 | printf("Heap: %d (act) / %d (min) byte free\r\n", xPortGetFreeHeapSize(), xPortGetMinimumEverFreeHeapSize());
103 | printf("this stack: %ld entries free\r\n", uxTaskGetStackHighWaterMark( NULL ));
104 | printf("UART stack: %ld entries free\r\n", uartStackHighWaterMark);
105 | printf("LED stack: %ld entries free\r\n", ledStackHighWaterMark);
106 | printf("\r\n");
107 | }
108 | }
109 |
110 | uint8_t lower_heap[5*1024];
111 |
112 | HeapRegion_t xHeapRegions[] = {
113 | { (uint8_t*)lower_heap, sizeof(lower_heap) },
114 | { NULL, 0 },
115 | { NULL, 0 }
116 | };
117 |
118 | /* Main Program */
119 | int main (void)
120 | {
121 | Board_Init();
122 | USB_Init();
123 | CLI_Init();
124 |
125 | /* Setup UART for 38.4K8E1 */
126 | Chip_UART_Init(LPC_USART);
127 | Chip_UART_SetBaud(LPC_USART, 38400);
128 | Chip_UART_ConfigData(LPC_USART, (UART_LCR_WLEN8 | UART_LCR_SBS_1BIT | UART_LCR_PARITY_EN | UART_LCR_PARITY_EVEN));
129 | Chip_UART_SetupFIFOS(LPC_USART, (UART_FCR_FIFO_EN | UART_FCR_TRG_LEV2));
130 | Chip_UART_TXEnable(LPC_USART);
131 |
132 | /* Enable receive data and line status interrupt */
133 | Chip_UART_IntEnable(LPC_USART, (UART_IER_RBRINT | UART_IER_RLSINT));
134 |
135 | /* prio = 3 */
136 | NVIC_SetPriority(UART0_IRQn, (1UL<<__NVIC_PRIO_BITS)-1UL); // only 2 bits used, so prio can be 0,1,2,3 where 0 is highest priority
137 | NVIC_EnableIRQ(UART0_IRQn);
138 |
139 | // use remaining USB RAM for RTOS heap
140 | xHeapRegions[1].pucStartAddress = (uint8_t*)usb_param.mem_base;
141 | xHeapRegions[1].xSizeInBytes = usb_param.mem_size;
142 |
143 | vPortDefineHeapRegions(xHeapRegions);
144 |
145 | /* UART thread */
146 | xTaskCreate(vUARTTask, "UART", 80, NULL, configMAX_PRIORITIES - 1, (xTaskHandle *) NULL);
147 |
148 | /* STATS thread */
149 | xTaskCreate(vStatsTask, "Stats", 80, NULL, tskIDLE_PRIORITY, (xTaskHandle *) NULL);
150 |
151 | /* LED toggle thread */
152 | xTaskCreate(vLEDTask, "LED", 32, NULL, tskIDLE_PRIORITY + 1, (xTaskHandle *) NULL);
153 |
154 | /* Start the scheduler */
155 | vTaskStartScheduler();
156 |
157 | for (;;)
158 | {
159 | if (rx_byte != -1)
160 | {
161 | printf("ISR - ch = 0x%02x\r\n", rx_byte);
162 | rx_byte = -1;
163 | }
164 | CLI_Task();
165 | }
166 | }
167 |
168 | void vApplicationIdleHook( void )
169 | {
170 | // must never been delayed by FreeRTOS function...
171 | CLI_Task(); // consume all input
172 | // __wfi();
173 | }
174 | /*-----------------------------------------------------------*/
175 |
176 | void vApplicationMallocFailedHook( void )
177 | {
178 | ACT_LED_ON();
179 | taskDISABLE_INTERRUPTS();
180 | for (;;) {;}
181 | }
182 | /*-----------------------------------------------------------*/
183 |
184 | void vApplicationStackOverflowHook( TaskHandle_t pxTask, char *pcTaskName )
185 | {
186 | ( void ) pcTaskName;
187 | ( void ) pxTask;
188 |
189 | ACT_LED_ON();
190 | taskDISABLE_INTERRUPTS();
191 | for (;;) {;}
192 | }
