Forum: PC Hard- und Software HDD Power-Off_Retract_Count 148 Millionen :-)
von Mac G. (macgyver0815)
hatte ein gebrauchtes Notebook gekauft und mir mal die SMART Werte der
Festplatte Baujahr 2012 angeschaut (wurde schon gegen eine SSD ersetzt,
keine Sorge ;-) )
Model Family:     Hitachi/HGST Travelstar Z7K500
Device Model:     HGST HTS725050A7E630
User Capacity:    500.107.862.016 bytes [500 GB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Form Factor:      2.5 inches
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   062    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   100   100   040    Pre-fail  Offline      -       0
  3 Spin_Up_Time            0x0007   248   248   033    Pre-fail  Always       -       1
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       1194
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
23
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
24
  8 Seek_Time_Performance   0x0005   100   100   040    Pre-fail  Offline      -       0
25
  9 Power_On_Hours          0x0012   088   088   000    Old_age   Always       -       5435
26
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
27
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       992
28
191 G-Sense_Error_Rate      0x000a   100   100   000    Old_age   Always       -       0
29
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       148242443
30
193 Load_Cycle_Count        0x0012   092   092   000    Old_age   Always       -       88910
31
194 Temperature_Celsius     0x0002   162   162   000    Old_age   Always       -       37 (Min/Max 18/44)
32
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
33
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
34
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
35
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
36
223 Load_Retry_Count        0x000a   100   100   000    Old_age   Always       -       0
37
Power-Off_Retract_Count  148242443
Load_Cycle_Count 88910
148 MILLIONEN Mal soll die Platte also die Köpfe geparked haben?
(bei 5435 Betriebsstunden, also im Schnitt 7x pro Sekunde)
Wer bietet mehr?
Bei meinen anderen Platten ist der Wert im Bereich 5 - 500.
Zumal der Wert eigentlich abruptes Abschalten zählt und nicht normales
Parken...
Wie kommt denn dieser irrwitzig hohe Wert zustande?
von MM (Gast)
Mache mal einen Gegentest mit einem anderen Programm zum auslesen der
Werte. Da nicht jede Platte alles verrät, hatte ich schon
Fehlinterpretationen der Werte je nach verwendetem Programm.
Das dürfte keine Mechanik überstehen.
Könnte sein, allerdings verwende ich Linux und
sudo smartctl -a /dev/sdb
sollte eigentlich recht wenig von den Werten interpretieren.
Die meisten anderen Tools mit GUI dürften nix anderes machen als
smartctl aufzurufen (mal kurz gesucht und ja, ist bei den meisten die
ich gefunden habe so).
Oder kennt da jemand ein anderes Tool wo das nicht der Fall ist?
von K. J. (Gast)
;) hab mir gerade mal meine Platten angeschaut ;( nach smartctl sind die
TOT ich hab noch nie so schlechte Werte gesehen bei meinen Platten aber
dafür laufen sie einwandfrei.
Allerdings geben die mir den wert nicht aus den du meinst, unter linux
gibt es nix anderes als smartcrl.
von Google user (Gast)
Offensichtlich benutzt  Hitachi die Smart ID 192 für ein anderes
Attribut, eventuell Anzahl der geschriebenen Bytes.
Siehe hier:
https://bbs.archlinux.org/viewtopic.php?id=209574
von Rolf M. (rmagnus)
Naja, bei einer Spin-Up-Time von gerade mal 1 Millisekunde... wer weiß?
Möglich wärs. Aber geschriebene Bytes sinds nicht - gerade mal getestet
und 3 GByte raufkopiert. Ändert nix am Wert.
(der ist übrigens schon länger konstant geblieben, ist nicht so das der
weiter hochzählt)
Mysteriös.
Aber vermutlich stimmts, dann kann ich die Platte doch noch für Backups
nutzen :-)
von Headcrash (Gast)
Wenn die so oft geparked haben, solltest du prüfen, das Patchkabel
richtig gepatched war.
Headcrash.
Sorry, ist schon spät.
Headcrasch.
