Class im STRUCT
Gast #4784620
ich habe folgendes Problem:
Ich benutze die CountUpDownTimer lib, und die funktioniert super,
jetzt wollte ich einen Struct machen und lib da einbinden das geht
nicht:
Die lib ist:
/* Count Up/Down Timer */
  Helpful Corrections by:
  Github user Mannelito - Correction to ResumeTimer function
The MIT License (MIT)
Copyright (c) 2016 Andrew Mascolo Jr
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
23
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
24
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
25
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
26
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
27
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
28
SOFTWARE.
29
30
31
32
#ifndef CountUpDownTimer_h
33
#define CountUpDownTimer_h
34
35
#include<Arduino.h>
36
#define UP 1
37
#define DOWN 0
38
39
class CountUpDownTimer
40
41
  public:
42
        CountUpDownTimer(bool type, bool precision = LOW) : _type(type), _precision(precision)
43
44
    SetStopTime((type? 0xFFFF : 0)); // 18h 12m 15s
45
    time = precision ? micros() : millis();
46
    Clock = 0;
47
    Reset = false, Stop = true, Paused = true;
48
    timeFlag = false;
49
    duration = precision ? 1000000 : 1000;
50
51
  unsigned long _InternalClock()
52
53
    return _precision ? micros() : millis();
54
55
56
  boolean Timer()
57
58
    timeFlag = false;
59
    if (!Stop && !Paused) // if not Stopped or Paused, run timer
60
61
      if(Paused)
62
        time = _InternalClock();
63
64
    if ((_intTime = _InternalClock() ) - time > duration ) // check the time difference and see if 1 second has elapsed
65
66
      _type == UP? Clock++ : Clock--;
67
68
      timeFlag = true;
69
70
      if ((_type == DOWN && Clock == 0) || TimeCheck()) // check to see if the clock is 0
71
      Stop = true; // If so, stop the timer
72
73
      time = _intTime;
74
75
      if(_intTime < time)
76
        time = 0;  // check to see if micros() has rolled over, if not, then increment "time" by duration
77
78
79
80
    return !Stop; // return the state of the timer
81
82
83
  void ResetTimer()
84
85
    if(_type)
86
      Clock = 0;
87
    else
88
      SetTimer(R_clock);
89
    Stop = false;
90
91
92
  void StartTimer()
93
94
    Watch = _InternalClock();
95
    Stop = false;
96
    Paused = false;
97
//     if(_type == UP)
98
//       Clock = 0;
99
100
101
  void StopTimer()
102
103
    Stop = true;
104
105
106
  void StopTimerAt(unsigned long hours, unsigned long minutes, unsigned long seconds)
107
108
    if (TimeCheck(hours, minutes, seconds) )
109
    Stop = true;
110
111
112
  void PauseTimer()
113
114
115
    Paused = true;
116
117
118
  void ResumeTimer() // You can resume the timer if you ever stop it.
119
120
    Paused = false;
121
122
123
124
  void SetTimer(unsigned long hours, unsigned long minutes, unsigned long seconds)
125
126
    // This handles invalid time overflow ie 1(H), 0(M), 120(S) -> 1h, 2m, 0s
127
    unsigned int _S = (seconds / 60), _M = (minutes / 60);
128
    if(_S) minutes += _S;
129
    if(_M) hours += _M;
130
131
    Clock = (hours * 3600) + (minutes * 60) + (seconds % 60);
132
    R_clock = Clock;
133
    Stop = false;
134
135
136
  void SetTimer(unsigned long seconds)
137
138
   // StartTimer(seconds / 3600, (seconds / 3600) / 60, seconds % 60);
139
    Clock = seconds;
140
    R_clock = Clock;
141
    Stop = false;
142
143
144
  void SetStopTime(unsigned long seconds)
145
146
    STh = seconds / 3600;
147
    STm = (seconds / 60) % 60;
148
    STs = seconds % 60;
149
    STotaltime = seconds;
150
151
152
  void SetStopTime(unsigned long hours, unsigned long minutes, unsigned long seconds)
153
154
          STh = hours;
155
    STm = minutes;
156
    STs = seconds;
157
    STotaltime = (hours * 3600) + (minutes * 60) + (seconds % 60);
158
159
160
  unsigned long ShowHours()
161
162
    return Clock / 3600;
163
164
165
  unsigned long ShowMinutes()
166
167
    return (Clock / 60) % 60;
168
169
170
  unsigned long ShowSeconds()
171
172
    return Clock % 60;
173
174
175
  unsigned long ShowMilliSeconds()
176
177
    if (_precision == HIGH)
178
      return ((_intTime - Watch)/ 1000.0) + 1;
179
    else
180
      return (_intTime - Watch) + 1;
181
182
183
  unsigned long ShowMicroSeconds()
184
185
    if (_precision == LOW)
186
187
    else
188
189
190
191
  unsigned long ShowTotalSeconds()
192
193
    return Clock;
194
195
196
  unsigned long ShowStopTime()
197
198
    return STotaltime;
199
200
201
  boolean TimeHasChanged()
202
203
    return timeFlag;
204
205
206
  boolean TimeCheck(unsigned int hours, unsigned int minutes, unsigned int seconds) // output true if timer equals requested time or has passed it.
207
208
    unsigned long TC = ((hours * 3600) + (minutes * 60) + (seconds % 60));
209
    if(_type)
210
      return (Clock >= TC);
211
    else
212
      return (Clock <= TC);
213
214
215
  boolean TimeCheck() // output true if timer equals requested time or has passed it.
216
217
    if(_type)
218
      return Clock >= STotaltime;
219
    else
220
      return Clock <= STotaltime;
221
222
  boolean Stop;
223
   private:
224
      unsigned long duration;
225
      unsigned long STh, STm, STs, STotaltime;
226
      unsigned long Watch, _intTime, time;
227
            unsigned long Clock, R_clock;
228
      boolean Reset, Paused;
229
      volatile boolean timeFlag;
230
      bool _type, _precision;
231
232
233
#endif
typedef struct {
  int a;
  int b;
  byte c;
  bool d=false;
  CountUpDownTimer t(DOWN, LOW);
} blabla_t;
Fehlermeldung kommt:
expected identifier before numeric constant
                    und
expected ',' or '...' before numeric constant
Bitte um hilfe
Milan
Gast #4784628
Milan schrieb:
> Bitte um hilfe
das geht so nicht, du kannst eine Variabel in der Struct zuweisen und
auch kein Objekte mit Konstruktor anlegen.
Beides ist falsch
 bool d=false;
man müsste die struct Variable getrennt anlegen
typedef struct {
  int a;
  int b;
  byte c;
  bool d;
  CountUpDownTimer t;
} blabla_t;
blabla_t x = { 0, 0, 0, false, (DOWN, LOW) };
bin mir mit dem Objekt aber nicht ganz sicher.
