ich versuche gerade 2 NRF24L0+ Boards zum Laufen zu bekommen.
Ein Board ist der Sender, das andere der Empfänger.
Ich hab beide mit einem zusätzlichen Kondensator ausgestattet (47uF).
Der Empfänger wird wie folgt betrieben:
1 | nrf_set_ce(NRF_CE_RX); //Set High
2 |
3 | nrf_start_write_register(0x00);
4 | spi_send_byte((1<<6)|(1<<1)|(1<<0)); //RX Interrupt,PRX mode, Wake UP
5 | spi_css(SPI_SLAVE_DESELECT);
6 |
7 |
8 | nrf_start_write_register(0x01);
9 | spi_send_byte((1<<0)); //Auto Ack
10 | spi_css(SPI_SLAVE_DESELECT);
11 |
12 |
13 | nrf_start_write_register(0x02);
14 | spi_send_byte((1<<0)); //Enable Pipeline
15 | spi_css(SPI_SLAVE_DESELECT);
16 |
17 |
18 | nrf_start_write_register(0x03);
19 | spi_send_byte(0x01); //3Byte Adress
20 | spi_css(SPI_SLAVE_DESELECT);
21 |
22 | nrf_start_write_register(0x05);
23 | spi_send_byte(40); //RF Channel
24 | spi_css(SPI_SLAVE_DESELECT);
25 |
26 | nrf_start_write_register(0x06);
27 | spi_send_byte((1<<5)|(00<<1)); //250kbps; RF Power
28 | spi_css(SPI_SLAVE_DESELECT);
29 |
30 | nrf_start_write_register(0x11);
31 | spi_send_byte(0x1);//Payload number of bytes
32 | spi_css(SPI_SLAVE_DESELECT);
33 |
34 | nrf_start_write_register(0x10);
35 | spi_send_byte(0xE7);//TX Adress
36 | spi_send_byte(0xE7);//TX Adress
37 | spi_send_byte(0xE7);//TX Adress
38 | spi_css(SPI_SLAVE_DESELECT);
39 |
40 | nrf_start_write_register(0x0A);
41 | spi_send_byte(0xE7);//RX Adress
42 | spi_send_byte(0xE7);//RX Adress
43 | spi_send_byte(0xE7);//RX Adress
44 | spi_css(SPI_SLAVE_DESELECT);
Sender:
1 | nrf_set_ce(NRF_CE_RX);//CE High for transmit
2 |
4 | spi_send_byte((1<<5)|(1<<1)); //RX Interrupt,PTX mode
6 |
7 | nrf_start_write_register(0x01);
8 | spi_send_byte((1<<0)); //Auto Ack
9 | spi_css(SPI_SLAVE_DESELECT);
10 |
11 |
12 | nrf_start_write_register(0x03);
13 | spi_send_byte(0x01); //3Byte Adress
14 | spi_css(SPI_SLAVE_DESELECT);
15 |
16 | nrf_start_write_register(0x05);
17 | spi_send_byte(40); //RF Channel
18 | spi_css(SPI_SLAVE_DESELECT);
19 |
20 | nrf_start_write_register(0x06);
21 | spi_send_byte((1<<5)|(00<<1)); //250kbps; RF Power
22 | spi_css(SPI_SLAVE_DESELECT);
23 |
24 | nrf_start_write_register(0x11);
25 | spi_send_byte(0x1);//RF Payload number
26 | spi_css(SPI_SLAVE_DESELECT);
27 |
28 | nrf_start_write_register(0x10);
29 | spi_send_byte(0xE7);//TX Adress
30 | spi_send_byte(0xE7);//TX Adress
31 | spi_send_byte(0xE7);//TX Adress
33 |
34 | nrf_start_write_register(0x0A);
35 | spi_send_byte(0xE7);//RX Adress
36 | spi_send_byte(0xE7);//RX Adress
37 | spi_send_byte(0xE7);//RX Adress
Senden eines Bytes
1 | spi_css(SPI_SLAVE_SELECT);
2 | spi_send_byte(NRF_W_TX_PAYLOAD); //0xA0
5 |
6 |
7 |
8 | nrf_set_ce(NRF_CE_TX); //High
9 | timer_delay_ms(2);
10 | nrf_set_ce(NRF_CE_RX); //Low
Empfangen:
Durch NOP-> liefert 0x0E = keine RX Daten
Das SPI Timing stimmt, habe ich durch Logic Analyzer kontrolliert.
Beim Sender erhalte ich das Status-Byte 0x1F = Kein Rx, TX Buff voll,
Maximum of retransmits
Ich habe keine Ahnung mehr wo der Fehler liegen könnte.
Die Boards sind vieleicht 50cm auseinander.
Vielen vielen Dank schon im vorraus.
