Xen installation on x64 pc as a step towards using xen on ARM
OP #4799981
Hi every body. I am interested in XEN to run both Linux and Windows 10
on my PC concurrently, just switching windows on my desktop. So not dual
boot!
Having started experimenting with Raspi I suffered an attack on my
Windows 7 Ultimate running PC rendering it inoperable. The Windows os
was fully up-to-date and I had the tools running to protect it. The area
used for attack was my connection between Raspis and PC via ssh and the
Raspis with a DNS entry. I was just starting to learn Linux/Raspbian and
so my security setup was practically not existing.
So the Trustedzone concept of ARM and their new controllers, ARM Cortex
M23 and M33, goes toward using the isolation achievable through
virtualization, specifically for IoT kind of devices, connected devices.
So my plan is to setup my PC with a bare metal XEN hipervisor type 1 and
have Windows 10 and Ubuntu running concurrently. This way I can start
learning about XEN.
As soon as the i.MX8 controller is available on a makers board I will
install XEN on it. I do expect that ARM Cortex Mx based controller
implementations to become mainstream and hopefully there will be Raspis
using ARMv8 cores with the Trustedzone support of ARM.
Does anybody know where I can download and how to install XEN, its
current release seems to be XEN 4.7.1, on one spare hard disk I have on
my PC. I have already setup the virtualization support for the Intel CPU
of my system.
Gast #4800183
CloudFreak schrieb:
> CITRIX Website:
Soso.
@Hellmut Kohlsdorf:
I think you should read the ARM documents about TrustZone first. It is
not what you think it is.
It would take me too long to explain it all, but since you are
interested in Virtualisation (with XEN):
In TrustZone the number of virtual machines is limited to two, one
running in the secure zone and one running in the non-secure zone. There
is no possibility to protect multiple OSes in the non-secure zone.
So in general it is better to think of TrustZone as an alternative for a
TPM.
Another important thing which is missing for a useful hypervisor is MMIO
virtualisation.
Also the use of TrustZone ist not transparently possible, therefore some
modifications of the guest OSes are mandatory.
So only ARM MCUs/CPUs which also implements the ARM Architecture
virtualization extension can do real virtualisation.
This will be the case with the i.MX8, but NOT with the Cortex M23/M33.
OP #4800355
I used the english language to allow none native german speakers to also
read my contribution. I assume that those who know about the topic are
also capable to read in english!
The info on the Citrix website is not so evident, specially whn you
would like to start our of a Windows 10 environment. From Linux it is
well explained!
As to STMler contribution: Xen has being used for hosting in data
centers for example. This is a pretty mature area of use of a bare metal
hipervisor. Different from what I undestood from your contribution, you
have a single Domain0 os running that has the charter to do
administration and a multiple guest operating sistems runing in DomainU.
As you can well imagine, a data center hosts many, many hosts running as
DomainU guests. It is even posible to move a guest host to a different
physical machine anywhere on the globe while it being operative. This
way data centers manage the load on their server farm!
The ARM Cortex M23 and M33 are for embedded aplications as you find in
IoTs, IIots or Industry 4.0 devices. Here the purpose of the
virtualization is to isolate the application running in DomainU. Not to
have multiple os running concurrently! If you happen to read what is
available at the ARM website you will find out that the use of
Trustedzone is meant to minimalize the area of attack of an connected
device!
So, thx for advicing me that my question is not adequately precise to
have a reader grasp what I mean! I plan to use XEN on my desktop to run
concurrently Ubuntu and Windows 10, opposed to use a dual boot setup!
This way while adding stuff to protect my desktop from attacks while
experimenting, I can switch between the 2 os buy switching the window on
its desktop!
This is the first step to start familiarzing myself with XEN using a
mature use of it.
The second step is using XEN as a mean to protect deep embedded sistems.
Here i.MX8, as well as future devices that use the ARM license for the
Cortex M23 or M33, will benefit from what I will be learning.
#4800374
Gerade wenn es dir um vielfältige Rezeption geht, dann solltest du auch
die Grundregeln beachten. Eine davon ist, dass die Form ebenso wichtig
ist wie der Inhalt. Es mag dich stören, denn du willst ob deines Inhalts
respektiert werden, nicht ob der Form.
Aber es ist die Form, die man als erstens wahrnimmt. Da du in Konkurrenz
zu einer Informationsflut steht, ist es wichtig, den gut trainierten
Informationsfilter des Lesers zu überstehen. Der entscheidet in Sekunden
oder weniger, ob sich überhaupt die Mühe lohnt, es zu lesen.
Und da verlierst du. Einerseits wegen der Sprache, die mancher als
anstrengender empfindet, insbesondere wenn er es nicht nur lesen soll,
sondern auch darin antworten soll. Andererseits - ganz banal - weil dein
Text auf den ersten Blick als unstrukturierte Textwüste wirkt. Schon
eine Leerzeile zwischen Absätzen lockert das auf.
Persönliche Seite #4800592
That mistyped letter "e" makes that sentence a contradiction in itself.
Either spell-check what you type or ...
Schreib' einfach auf Deutsch. Dieses Forum hier wird sehr deutlich
überwiegend, wenn nicht sogar fast ausschließlich von Leuten besucht,
die des Deutschen mächtig sind.
Der Versuch, krampfhaft Englisch zu schreiben, um ein hier nicht
vorhandenes Publikum anzusprechen (Leute, die Englisch, aber kein
Deutsch können), der ist nicht zielführend.
Im Englischen wird übrigens der Gebrauch von Ausrufungszeichen noch mehr
mit Hysterie assoziiert als im Deutschen, auch wenn Du immerhin darauf
verzichtet hast, gleich mehrere davon zu verwenden.
Also: Schreib' auf Deutsch. Das kannst Du vermutlich auch besser als
Englisch.
Moderator Persönliche Seite #4800767
Und hier habe ich beim Lesen abgeschaltet. Zu anstrengend, meinen
internen Übersetzungscomputer zu bemühen.
@TO: Du kannst davon ausgehen, dass der weitaus größte Teil der Leser
hier der deutschen Sprache mächtig ist. Durch die Verwendung der
englischen Sprache reduziert sich der Anteil derjenigen, die sich Deinen
Beitrag überhaupt bis zum Ende durchlesen, auf einen verschwindend
geringen Bruchteil.
Zudem ist das spezielle Thema Xen nicht gerade jedermans Sache. Damit
reduziert sich der Anteil der Leser nochmals. Da bleibt irgendwas
zwischen 0,001 und 0,0005 Prozent übrig.
Mein Vorschlag: Such Dir ein Form, Mailingliste oder Newsgroup, wo das
zentrale Thema Xen ist und benutze dann die dort übliche Sprache. Das
kannst Du voraussichtlich durch Lesen einiger weniger Threads direkt
herausfinden.
Auf jeden Fall besser als einfach so "hereinzustolpern".
