1 | #include "floatToString.h"
2 | //von Tim Hirzel
3 | //http://forum.arduino.cc/index.php?topic=37391.0
4 | char command;
5 | String string;
6 |
7 | int strom_StationNetzPulser = A0;
8 | int Spannung_StationNetzPulser = A1;
9 | int strom_StationPulserAkku = A2;
10 | int Spannung_StationPulserAkku = A3;
11 | int strom_StationAkkuWandler = A4;
12 | int Spannung_StationAkkuWandler = A5;
13 |
14 | int sensorValueA0 = 0;
15 | int sensorValueA1 = 0;
16 | int sensorValueA2 = 0;
17 | int sensorValueA3 = 0;
18 | int sensorValueA4 = 0;
19 | int sensorValueA5 = 0;
20 |
21 | float messA0 = 0;
22 | float messA1 = 0;
23 | float messA2 = 0;
24 | float messA3 = 0;
25 | float messA4 = 0;
26 | float messA5 = 0;
27 |
28 | const float U = 13.80;
29 | const float Umin = 13.00;
30 | const float Umax=16.00;
31 | const float UDOD=11.00;
32 |
33 | int M1 = 2; // legt Mosfet1 auf Digital Pin2
34 | int M2 = 4; // legt Mosfet1 auf Digital Pin2
35 |
36 | void setup() {
37 | // Serielle Schnittstelle für Ausgabe öffnen
38 | Serial.begin(9600);
39 | Serial.println("Messwerte");
40 | pinMode(M1, OUTPUT); //legt M1 als Ausgang fest
41 | pinMode(M2, OUTPUT); //legt M2 als Ausgang fest
42 |
43 | }
44 |
45 | void loop() {
46 |
47 | for (int i=0; 25; i++){
48 | Serial.println("Status M1");
49 | Serial.println(digitalRead(M1));
50 | Serial.println("Status M2");
51 | Serial.println(digitalRead(M2));
52 |
53 |
54 | //***********Start Pulsung**************
55 |
56 | StationNetzPulser ();
57 | StationPulserAkku ();
58 | if (messA3 < Umin)
59 | {
60 | while (messA3 > Umax)
61 | {
62 | StationPulserAkku ();
63 | digitalWrite(M1, HIGH);
64 | Serial.println("Status M1");
65 | Serial.println(digitalRead(M1));
66 | delay(300000);
67 | }
68 | }
69 | else
70 | {
71 | digitalWrite(M1, LOW);
72 | delay(300000);
73 | }
74 | //*************Ende Pulsung*************
75 |
76 | //****Start Kapazitätsmessung***********
77 | StationAkkuLast ();
78 |
79 | if (messA5 > Umin)
80 | {
81 | while (messA5 > UDOD)
82 | {
83 | StationAkkuLast ();
84 | digitalWrite(M2, HIGH);
85 | Serial.println("Status M2");
86 | Serial.println(digitalRead(M2));
87 | delay(300000);
88 | }
89 | }
90 | else
91 | {
92 | digitalWrite(M2, LOW);
93 | delay(6000);
94 | }
95 | }
96 | }
97 |
98 | void StationNetzPulser (){
99 | // Strom
100 | sensorValueA0 = analogRead(strom_StationNetzPulser); //Hole Wert
101 | //510=0A
102 | sensorValueA0 = sensorValueA0 - 510;//510=0Ampere 0=-30A 1023=30A
103 | //springen um 0 reduzieren
104 | if (sensorValueA0 == 1)sensorValueA0 = 0;
105 | if (sensorValueA0 == -1)sensorValueA0 = 0;
106 | //Umwandeln um einen Wert zuwischen -30 und +30 zu erhalten
107 | messA0 = (float)30 / 512 * sensorValueA0;
108 | //über Serielle Schnittstelle ausgeben
109 | Serial.println("Strom an Station 1");
110 | Serial.print(floatToString(buffer, messA0, 2));
111 | Serial.print("A");
112 | Serial.print("\t");
113 |
114 | // Spannung
115 | sensorValueA1 = analogRead(Spannung_StationNetzPulser); //Hole Wert
116 | //Wert umwandeln für Anzeige 0..12.0 Volt
117 | messA1 = (float)12 / 1023 * sensorValueA1;
118 | //über Serielle Schnitstelle ausgeben
119 | Serial.println("Spannung an Station 1");
120 | Serial.print(floatToString(buffer, messA1, 2));
121 | Serial.println("V"); //\n
122 | }
123 |
124 | void StationPulserAkku (){
125 | // Strom
126 | sensorValueA2 = analogRead(strom_StationPulserAkku); //Hole Wert
127 | //510=0A
128 | sensorValueA2 = sensorValueA2 - 510;//510=0Ampere 0=-30A 1023=30A
129 | //springen um 0 reduzieren
130 | if (sensorValueA2 == 1)sensorValueA2 = 0;
131 | if (sensorValueA2 == -1)sensorValueA2 = 0;
132 | //Umwandeln um einen Wert zuwischen -30 und +30 zu erhalten
133 | messA2 = (float)30 / 512 * sensorValueA2;
134 | //über Serielle Schnittstelle ausgeben
135 | Serial.println("Strom an Station 2");
136 | Serial.print(floatToString(buffer, messA2, 2));
137 | Serial.print("A");
138 | Serial.print("\t");
139 |
140 | // Spannung
141 | sensorValueA3 = analogRead(Spannung_StationPulserAkku); //Hole Wert
142 | //Wert umwandeln für Anzeige 0..12.0 Volt
143 | messA3 = (float)12 / 1023 * sensorValueA3;
144 | //über Serielle Schnitstelle ausgeben
145 | Serial.println("Spannung an Station 2");
146 | Serial.print(floatToString(buffer, messA3, 2));
147 | Serial.println("V"); //\n
148 | }
149 |
150 | void StationAkkuLast (){
151 | // Strom
152 | sensorValueA4 = analogRead(strom_StationAkkuWandler); //Hole Wert
153 | //510=0A
154 | sensorValueA4 = sensorValueA4 - 510;//510=0Ampere 0=-30A 1023=30A
155 | //springen um 0 reduzieren
156 | if (sensorValueA4 == 1)sensorValueA4 = 0;
157 | if (sensorValueA4 == -1)sensorValueA4 = 0;
158 | //Umwandeln um einen Wert zuwischen -30 und +30 zu erhalten
159 | messA4 = (float)30 / 512 * sensorValueA4;
160 | //über Serielle Schnittstelle ausgeben
161 | Serial.println("Strom an Station 3");
162 | Serial.print(floatToString(buffer, messA4, 2));
163 | Serial.print("A");
164 | Serial.print("\t");
165 |
166 | // Spannung
167 | sensorValueA5 = analogRead(Spannung_StationAkkuWandler); //Hole Wert
168 | //Wert umwandeln für Anzeige 0..12.0 Volt
169 | messA5 = (float)12 / 1023 * sensorValueA5;
170 | //über Serielle Schnitstelle ausgeben
171 | Serial.println("Spannung an Station 3");
172 | Serial.print(floatToString(buffer, messA5, 2));
173 | Serial.println("V"); //\n
174 | }
