1 | /*
2 | * 1WallSwitch_RS485.c
3 | *
4 | * Created: 27.02.2017 08:15:42
5 | * Author : Mitch
6 | */
7 |
8 | #include <avr/io.h>
9 | #include <avr/sleep.h>
10 | #include <avr/power.h>
11 | #include <avr/wdt.h>
12 | #include <avr/interrupt.h>
13 | #include <stdint.h>
14 | #include <string.h>
15 | #include "EEPROM.h"
16 |
17 | #define F_CPU 8000000UL
18 | #include <util/delay.h>
19 |
20 | #define DEVICE 1
21 |
22 | #define BAUDRATE 19200UL
23 | #define USAR_BAUD_CALC 25 //8000000 / (16*19200)
24 |
25 | #define LOW(x) ((x) & 0xFF) //LOWBYTE
26 | #define HIGH(x) (((x) >> 8) & 0xFF) //HIGHBYTE
27 |
28 | //RF24 radio(8,7);
29 |
30 | volatile uint8_t fourBtn = 0, initBtn =0;
31 | volatile uint8_t WDT_count = 0;
32 | volatile uint64_t Zeitstempel = 0;
33 | volatile uint8_t id = 0;
34 | volatile uint8_t timer_1s = 0;
35 | volatile uint8_t timer_3s = 0;
36 |
37 | //Für Spannungsüberwachung
38 | volatile uint8_t adc_low, adc_high; //Zwischenspeicher für die Ergebnisse des ADC
39 | volatile uint64_t adc_result, vcc; //adc_result Gesamtergebnis der Messung des ADC //VCC Versorgungsspannung
40 |
41 | const uint64_t addresses[2] = {0xF0F0F0F002LL,0xE101000000LL};
42 |
43 | char *sendByte[20];
44 | volatile char recByte[10];
45 |
46 | void rs485_putc(unsigned char c){
47 | while (!(UCSR0A & (1<<UDRE0))) /* warten bis Senden moeglich */
48 | {
49 | }
50 |
51 | UDR0 = c; /* sende Zeichen */
52 | //return 0;
53 | }
54 |
55 | void rs485_puts(char *s, unsigned int len){
56 | while (*s)
57 | { /* so lange *s != '\0' also ungleich dem "String-Endezeichen(Terminator)" */
58 | rs485_putc(*s);
59 | s++;
60 | //_delay_ms(200);
61 | }
62 | }
63 |
64 | void rs485_putAddr(uint8_t data){
65 | UCSR0B |= (1<<TXB80);
66 | // _delay_ms(10);
67 | rs485_putc(data);
68 | //rs485_putc('\n');
69 | // _delay_ms(10);
70 | UCSR0B &= ~(1<<TXB80);
71 | }
72 |
73 | void config_timer(){
74 | //16Bit Timer1
75 | OCR1A = 31250;
76 | TCCR1B = (1<<CS12) | (1<<WGM12);
77 | TIMSK1 = (1<<OCIE1A);
78 | }
79 |
80 | void config_interrupt(){
81 | //PinChange Interrupt
82 | PCMSK1 |= (1<<PCINT11)|(1<<PCINT10)|(1<<PCINT9)|(1<<PCINT8); //4 Taster PC0,PC1,PC2,PC3
83 | PCICR |= (1<<PCIE1);
84 |
85 | //PinChange Interrupt PD4 (InitTaster)
86 | PCMSK2 |= (1<<PCINT20);
87 | PCICR |= (1<<PCIE2);
88 | }
89 |
90 | void config_rs485(){
91 | UBRR0H = HIGH(USAR_BAUD_CALC);
92 | UBRR0L = LOW(USAR_BAUD_CALC);
93 |
94 | //Bei Slave mit Adresse
95 | // UCSR0A = (1<<MPCM0); //Adressüberprüfung... dann 9Bit Modus
96 |
97 | //Character
98 | UCSR0B = (1<<RXEN0) | (1<<TXEN0) | (1<<RXCIE0); //RX Enable, TX Enable, Empfangsinterrupts erlauben , UCSZ02 und UCSZ01 und 2aus UCSR0C = 9n1 ...(1<<RXCIE0)
99 | UCSR0C = (1<<UCSZ00) | (1<<UCSZ01); //8n1
100 | }
101 |
102 | ISR(PCINT1_vect){ //4Taster
103 | fourBtn = 1;
104 | }
105 |
106 | ISR(PCINT2_vect){ //InitTaster
107 | initBtn = 1;
108 | }
109 |
110 | ISR(TIMER1_COMPA_vect){
111 | timer_1s = 1;
112 | timer_3s++;
113 | }
114 |
115 | int main(void){
116 | DDRC |= (1<<DDC4)|(1<<DDC5); //PC4 & PC5 als Ausgang für LEDs(Tasterleds)
117 | DDRD |= (1<<DDD2)|(1<<DDD3)|(1<<DDD5); //PD2 & PD3 als Ausgang für LEDs(Tasterleds), PD5 StatusLed
118 | DDRB |= (1<<DDB2);//PB1 als Ausgang Ansteuerung für RS485
119 |
120 | config_timer();
121 | config_interrupt();
122 | config_rs485();
123 | sei();
124 |
125 | //ADC abschalten, verbraucht dann noch weniger
126 | ADCSRA = 0;
127 |
128 | //Für Batterieüberwachung
129 | ADMUX |= (1<<REFS0); //VCC als Referenzspannung f?r den AD-Wandler
130 | ADMUX |= (1<<MUX3) | (1<<MUX2) | (1<<MUX1); //1.1V Referenzspannung als Eingang f?r ADC
131 |
132 | _delay_ms(10); //warten bis sich die Referenzspannung eingestellt hat
133 |
134 | sendByte[0] = 1;//DEVICE; //Modus
135 | sendByte[1] = 2;//EEPROM_read(0); ; //lese ID aus EEPROM
136 | sendByte[2] = 5;//EEPROM_read(1);
137 | sendByte[3] = 6;//EEPROM_read(2);
138 | sendByte[4] = 7;//EEPROM_read(3);
139 | sendByte[5] = 8; //CRC
140 | sendByte[6] = 9; //BAT
141 | sendByte[7] = 10; //STATUS
142 | sendByte[8] = 11; //STATUS
143 | sendByte[19] = 0; //STATUS
144 | for(uint8_t i=9; i<19; i++){
145 | sendByte[i] = 0xF1; //DATA i
146 | }
147 |
148 | while(1){
149 | if(fourBtn == 1){ //wenn einer der 4Taster gedrückt
150 | if(PINC & (1<<PINC0)){ //Btn 1 gedrückt
151 | _delay_ms(60);
152 | PORTC |= (1<<PORTC4);
153 | _delay_ms(60);
154 | PORTC &= ~(1<<PORTC4);
155 |
156 | sendByte[8] = 0x01;
157 | char *test = "1234567";
158 |
159 | // rs485_putAddr(0x42);
160 | rs485_puts(test,sizeof(test));
161 | //uart_putstring("\r\n");
162 | //uart_putstring(test);
163 | //_delay_ms(100);
164 | }
165 | if(PINC & (1<<PINC1)){ //Btn 2 gedrückt
166 | PORTC |= (1<<PORTC5);
167 | _delay_ms(100);
168 | PORTC &= ~(1<<PORTC5);
169 |
170 | // sendByte[8] = 0x02;
171 |
172 | rs485_putAddr(0x42);
173 | rs485_puts(sendByte,sizeof(sendByte));
174 |
175 | //_delay_ms(100);
176 | }
177 | if(PINC & (1<<PINC2)){ //Btn 3 gedrückt
178 | PORTD |= (1<<PORTD2);
179 | _delay_ms(100);
180 | PORTD &= ~(1<<PORTD2);
181 |
182 | // sendByte[8] = 0x03;
183 |
184 | rs485_putAddr(0x42);
185 | rs485_puts(sendByte,sizeof(sendByte));
186 |
187 | //_delay_ms(100);
188 | }
189 | if(PINC & (1<<PINC3)){ //Btn 4 gedrückt
190 | PORTD |= (1<<PORTD3);
191 | _delay_ms(100);
192 | PORTD &= ~(1<<PORTD3);
193 |
194 | //sendByte[8] = 0x04;
195 |
196 | rs485_putAddr(0x42);
197 | rs485_puts(sendByte,sizeof(sendByte));
198 |
199 | //_delay_ms(100);
200 | }
201 | fourBtn = 0;
202 | //sendByte[8] = 0x00;
203 |
204 | //rs485_putAddr(0x42);
205 | //rs485_puts(sendByte);
206 | }
207 | //Initialisierung
208 | if(initBtn == 1){
209 | timer_3s = 0;
210 | while(PIND & (1<<PIND4)){ //InitBtn gedrückt
211 | PORTD |= (1<<PORTD5);
212 | if(timer_3s == 3){ //3sekunden gedrückt
213 | for(int i=0; i<5; i++){
214 | PORTD &= ~(1<<PORTD5);
215 | _delay_ms(100);
216 | PORTD |= (1<<PORTD5);
217 | _delay_ms(100);
218 | }
219 |
220 | }
221 | }
222 | PORTD &= ~(1<<PORTD5);
223 | initBtn = 0;
224 | }
225 | }
226 | }
