1 | #include "gps.h"
2 |
3 | using namespace gps;
4 |
5 | Gps::Gps(USARTSerial* serial) {
6 | _gpsSerial = serial;
7 | _is_connected = false;
8 | _reading_status = false;
9 | };
10 |
11 | bool Gps::Connect(uint8_t baudrate) {
12 | //Log.info("Connect");
13 | //_gpsSerial->begin(baudrate);
14 | Serial1.begin(baudrate);
15 | _is_connected = true;
16 | return true;
17 | };
18 |
19 | void Gps::defaultMessageCallback(void (*messageCallback)(uint8_t message, size_t logID))
20 | {
21 | _messageCallback = messageCallback;
22 | };
23 |
24 | void Gps::StopReading() {
25 | Log.info("StopReading");
26 | _reading_status = false;
27 | };
28 |
29 | void Gps::ReadSerialPort() {
30 | Log.info("ReadSerialPort");
31 | _reading_status = true;
32 |
33 | uint8_t buffer[MAX_NOUT_SIZE];
34 | size_t len = 0;
35 | char incomingByte = 0;
36 |
37 | while (Serial1.available() && _reading_status) {
38 | //incomingByte = _gpsSerial->read();
39 | incomingByte = Serial1.read();
40 | buffer[len] = incomingByte;
41 | len++;
42 |
43 | if (len == MAX_NOUT_SIZE)
44 | break;
45 | }
46 |
47 | if (len > 0) {
48 | _BufferIncomingData(buffer, len);
49 | }
50 | else {
51 | Log.info("no data");
52 | };
53 |
54 | Serial.println("-----");
55 | return;
56 | };
57 |
58 | bool Gps::_SendMessage(uint8_t *msg_ptr, size_t length) {
59 | Log.info("_SendMessage");
60 |
61 | /*for (unsigned int i = 0; i < length; i++) {
62 | Serial.print(msg_ptr[i], HEX);
63 | Serial.print("-");
64 | };*/
65 |
66 | size_t bytes_written;
67 |
68 | //bytes_written=_gpsSerial->write(msg_ptr, length);
69 | bytes_written=Serial1.write(msg_ptr, length);
70 | //_gpsSerial->flush();
71 | Serial1.flush();
72 | //delay(50);
73 | // check that full message was sent to serial port
74 | if (bytes_written != length) {
75 | Log.error("Full message was not sent over serial port.");
76 | return false;
77 | }
78 | return true;
79 | };
80 |
81 | bool Gps::_ConfigureOutputFormat(OutputType output_type) {
82 | Log.info("_ConfigureOutputFormat");
83 | bool send_result;
84 |
85 | gps::ConfigureOutputFormat message;
86 | message.header.sync1 = SKYTRAQ_SYNC_BYTE_1;
87 | message.header.sync2 = SKYTRAQ_SYNC_BYTE_2;
88 | message.header.first_payload_byte = FIRST_PAYLOAD_BYTE;
89 | message.header.payload_length = CONFIGURE_OUTPUT_FORMAT_PAYLOAD_LENGTH;
90 | message.message_id = CFG_OUTPUT_FORMAT;
91 | message.type = output_type;
92 | message.footer.end1 = SKYTRAQ_END_BYTE_1;
93 | message.footer.end2 = SKYTRAQ_END_BYTE_2;
94 |
95 | //unsigned char* msg_ptr = (unsigned char*)&message;
96 | //_calculateCheckSum(msg_ptr+HEADER_LENGTH, CONFIGURE_OUTPUT_FORMAT_PAYLOAD_LENGTH,
97 | // &message.footer.checksum);
98 | uint8_t msg_ptr[] = {160, 161, 0, 2, 9, 2, 11, 13, 10};
99 | send_result = _SendMessage(msg_ptr,HEADER_LENGTH+CONFIGURE_OUTPUT_FORMAT_PAYLOAD_LENGTH+FOOTER_LENGTH);
100 | return send_result;
101 | };
102 |
103 | bool Gps::SetOutputFormatToBinary() {
104 | Log.info("SetOutputFormatToBinary");
105 |
106 | bool send_result;
107 | send_result = _ConfigureOutputFormat(BINARY_OUTPUT);
108 | return send_result;
109 | };
110 |
111 | bool Gps::QuerySoftwareVersion() {
112 | bool send_result;
113 |
114 | gps::QuerySoftwareVersion message;
115 | message.header.sync1 = SKYTRAQ_SYNC_BYTE_1;
116 | message.header.sync2 = SKYTRAQ_SYNC_BYTE_2;
117 | message.header.first_payload_byte = FIRST_PAYLOAD_BYTE;
118 | message.header.payload_length = QUERY_SOFTWARE_VERSION_PAYLOAD_LENGTH;
119 | message.message_id = QUERY_SOFTWARE_VERSION;
120 | message.software_type = SYSTEM_CODE;
121 | message.footer.end1 = SKYTRAQ_END_BYTE_1;
122 | message.footer.end2 = SKYTRAQ_END_BYTE_2;
123 |
124 | uint8_t msg_ptr[] = {160, 161, 0, 2, 2, 1, 3, 13, 10};
125 | //unsigned char* msg_ptr = (unsigned char*)&message;
126 | //_calculateCheckSum(msg_ptr+HEADER_LENGTH, QUERY_SOFTWARE_VERSION_PAYLOAD_LENGTH,
127 | // &message.footer.checksum);
128 |
129 | send_result = _SendMessage(msg_ptr,HEADER_LENGTH+QUERY_SOFTWARE_VERSION_PAYLOAD_LENGTH+FOOTER_LENGTH);
130 | return send_result;
131 | };
