1 | #include <avr/io.h>
2 | #include <util/delay.h>
3 | #include <i2cmaster.h>
4 |
5 |
6 | #define BAUD 9600
7 | #define MYUBRR ((uint16_t) ((F_CPU / ((BAUD) * 16.0)) + .5) - 1)
8 | #define LED1 PD6
9 | #define LED2 PD7
10 |
11 |
12 | // contains what the bluetooth module received
13 | uint8_t data;
14 |
15 | void USART_Init(unsigned int ubrr) {
16 | // set baud rate
17 | UBRRH = (unsigned char)(ubrr>>8);
18 | UBRRL = (unsigned char)(ubrr);
19 | // enable receiver, transmitter and interrupts for rx/tx
20 | UCSRB = (1<<RXEN) | (1<<TXEN) | (1<<RXCIE) | (1<< TXCIE);
21 | }
22 |
23 |
24 |
25 | void USART_transmit(char c) {
26 | while ( !(UCSRA & (1<<UDRE)) ) {}
27 | UDR = c;
28 | }
29 |
30 |
31 |
32 | void transmit_char(char c) {
33 | USART_transmit(c);
34 | USART_transmit('\r');
35 | USART_transmit('\n');
36 | }
37 |
38 |
39 |
40 | void send_string(char s[]) {
41 | int i =0;
42 |
43 | while (s[i] != 0x00) {
44 | USART_transmit(s[i]);
45 | i++;
46 | }
47 | USART_transmit('\r');
48 | USART_transmit('\n');
49 |
50 | }
51 |
52 |
53 | void flash_led1(uint8_t count) {
54 | for (int n=1; n<=count; n++) {
55 | PORTD |= (1 << LED1); // Turn on LED1
56 | //PORTD |= (1 << LED2); // Turn on LED2
57 | _delay_ms(300);
58 | PORTD &= ~(1 << LED1); // Turn off LED1
59 | //PORTD &= ~(1 << LED2); // Turn off LED2
60 | _delay_ms(300);
61 | }
62 | }
63 |
64 |
65 | void flash_led2(uint8_t count) {
66 | for (int n=1; n<=count; n++) {
67 | //PORTD |= (1 << LED1); // Turn on LED1
68 | PORTD |= (1 << LED2); // Turn on LED2
69 | _delay_ms(1000);
70 | //PORTD &= ~(1 << LED1); // Turn off LED1
71 | PORTD &= ~(1 << LED2); // Turn off LED2
72 | _delay_ms(1000);
73 | }
74 | }
75 |
76 |
77 | void flash_led2_long(uint8_t count) {
78 | for (int n=1; n<=count; n++) {
79 | //PORTD |= (1 << LED1); // Turn on LED1
80 | PORTD |= (1 << LED2); // Turn on LED2
81 | _delay_ms(3000);
82 | //PORTD &= ~(1 << LED1); // Turn off LED1
83 | PORTD &= ~(1 << LED2); // Turn off LED2
84 | _delay_ms(3000);
85 | }
86 | }
87 |
88 |
89 | void flash_all_leds(void) {
90 | for (uint8_t n = 0; n <= 3; n++) {
91 | PORTD |= (1 << LED1); // Turn on LED1
92 | PORTD |= (1 << LED2); // Turn on LED2
93 | _delay_ms(500);
94 | PORTD &= ~(1 << LED1); // Turn off LED1
95 | PORTD &= ~(1 << LED2); // Turn off LED2
96 | _delay_ms(500);
97 | }
98 | }
99 |
100 | /*
101 | 0xD0 = 1 1 0 1 0 0 0 0 = write
102 | 0xD1 = 1 1 0 1 0 0 0 1 = read
103 |
104 | the first 6 bits contain the device id, and the last one tells the device if we want to read from it
105 | or write to it
106 | */
107 |
108 | // adress of the rtc clock device/chip
109 | #define rtc_clock 0xD0
110 |
111 |
112 |
113 | /* example: http://exploreembedded.com/wiki/Real_Time_Clock%28DS1307%29_with_AVR
114 | void RTC_Init(void)
115 | {
116 | I2C_Init(); // Initialize the I2c module.
117 | I2C_Start(); // Start I2C communication
118 |
119 | I2C_Write(C_Ds1307WriteMode_U8); // Connect to DS1307 by sending its ID on I2c Bus
120 | I2C_Write(C_Ds1307ControlRegAddress_U8);// Select the Ds1307 ControlRegister to configure Ds1307
121 |
122 | I2C_Write(0x00); // Write 0x00 to Control register to disable SQW-Out
123 |
124 | I2C_Stop(); // Stop I2C communication after initializing DS1307
125 | }*/
126 |
127 |
128 | // my init, adapted from the above
129 | void init_i2c(void) {
130 | // initialize, taken from peter fleurys i2c example (he wrote the i2c code)
131 | i2c_init();
132 | // connect to the device and tell it that we want to write to it
133 |
134 | //i2c_start_wait(rtc_clock+I2C_WRITE);
135 | // this is from rtc.h from the exploreembeeded example: #define C_Ds1307ControlRegAddress_U8 0x07u // Address to access Ds1307 CONTROL register
136 | // write 0x07 to it, telling it that we want to access the control register
137 | uint8_t ret;
138 | ret = i2c_start(rtc_clock+I2C_WRITE); // set device address and write mode
139 | if ( ret ) {
140 | flash_led2_long(1);
141 | /* failed to issue start condition, possibly no device found */
142 | i2c_stop();
143 | // we can issue an error message here if the device failed to respond
144 |
145 | } else {
146 | flash_led1(1);
147 | i2c_write(0x07);
148 | // see above
149 |
150 | i2c_write(0x00);
151 | i2c_stop();
152 | }
153 |
154 | }
155 |
156 |
157 | typedef struct {
158 | uint8_t sec;
159 | uint8_t min;
160 | uint8_t hour;
161 | uint8_t weekDay;
162 | uint8_t date;
163 | uint8_t month;
164 | uint8_t year;
165 | } rtc_t;
166 |
167 | rtc_t rtc;
168 |
169 | void setClock(rtc_t *rtc) {
170 | rtc->hour = 0x00; // 10:40:20 am
171 | rtc->min = 0x40;
172 | rtc->sec = 0x00;
173 |
174 | rtc->date = 0x01; //1st Jan 2016
175 | rtc->month = 0x01;
176 | rtc->year = 0x16;
177 | rtc->weekDay = 5;
178 |
179 | uint8_t ret;
180 | ret = i2c_start(rtc_clock+I2C_WRITE); // set device address and write mode
181 | if ( ret ) {
182 | flash_led2_long(1);
183 | /* failed to issue start condition, possibly no device found */
184 | i2c_stop();
185 | // we can issue an error message here if the device failed to respond
186 |
187 | } else {
188 | i2c_write(0x00);
189 | i2c_write(rtc->sec); // Write sec from RAM address 00H
190 | i2c_write(rtc->min); // Write min from RAM address 01H
191 | i2c_write(rtc->hour); // Write hour from RAM address 02H
192 | i2c_write(rtc->weekDay); // Write weekDay on RAM address 03H
193 | i2c_write(rtc->date); // Write date on RAM address 04H
194 | i2c_write(rtc->month); // Write month on RAM address 05H
195 | i2c_write(rtc->year); // Write year on RAM address 06h
196 | i2c_stop();
197 | }
198 | }
199 |
200 |
201 |
202 | uint8_t result;
203 |
204 | uint8_t getSeconds(void) {
205 | // receive 1 byte (seconds)
206 |
207 | /*i2c_start_wait(rtc_clock+I2C_READ);
208 | result = i2c_readNak();
209 | i2c_stop();
210 | result = 2;
211 | return result;*/
212 |
213 | uint8_t ret;
214 | ret = i2c_start(rtc_clock+I2C_WRITE); // set device address and write mode
215 | if ( ret ) {
216 | flash_led2_long(3);
217 | /* failed to issue start condition, possibly no device found */
218 | i2c_stop();
219 | // we can issue an error message here if the device failed to respond
220 |
221 | } else {
222 | /* issuing start condition ok, device accessible
223 | we can now use i2c_write() to talk to the device*/
224 |
225 | flash_led1(2);
226 |
227 | // request second ram adress
228 | i2c_write(0x00);
229 | i2c_stop();
230 |
231 | // _rep_start or _start? whats the difference?
232 | i2c_rep_start(rtc_clock+I2C_READ);
233 | result = i2c_readNak();
234 | i2c_stop();
235 | }
236 | return result;
237 |
238 |
239 | }
240 |
241 |
242 |
243 |
244 | int main(void) {
245 | DDRD |= (1 << LED1);
246 | DDRD |= (1 << LED2);
247 |
248 | // test the leds
249 | flash_all_leds();
250 | USART_Init(MYUBRR);
251 | init_i2c();
252 | setClock(&rtc);
253 | uint8_t count = 0;
254 | while (1) {
255 |
256 | uint8_t tmp = getSeconds();
257 | transmit_char(tmp);
258 | //transmit_char(count + '0');
259 | count = count + 1;
260 | _delay_ms(2000);
261 |
262 | // flash LED1 "count" times to see if the program crashed
263 |
264 | //flash_led1(tmp);
265 | //flash_all_leds();
266 | }
267 | }
