1 | #include <LiquidCrystal.h>
2 |
3 | LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
4 |
5 | int lcd_key = 0;
6 | int adc_key_in = 0;
7 | float current_volume = 0; //Current total volume passed though flow meter
8 | float target_volume = 0.5; //Total desired volume
9 | float adjustment_volume = 0; //Adjustment volume to take into account delays in solenoid closing. Subtracted from the current volume.
10 |
11 | #define btnRIGHT 0
12 | #define btnUP 1
13 | #define btnDOWN 2
14 | #define btnLEFT 3
15 | #define btnSELECT 4
16 | #define btnNONE 5
17 |
18 | #define hltSIZE 0.6 //Size of the Hot Liquor Tun in litres
19 |
20 | #define SOLENOIDPIN 13 //Solenoid relay on Pin 13
21 | #define FLOWSENSORPIN 12 //Flow sensore on Pin 2
22 |
23 | // count how many pulses
24 | volatile uint16_t pulses = 0;
25 | // track the state of the pulse pin
26 | volatile uint8_t lastflowpinstate;
27 | // you can try to keep time of how long it is between pulses
28 | volatile uint32_t lastflowratetimer = 0;
29 | // and use that to calculate a flow rate
30 | volatile float flowrate;
31 | // Interrupt is called once a millisecond, looks for any pulses from the sensor!
32 | SIGNAL(TIMER0_COMPA_vect) {
33 | uint8_t x = digitalRead(FLOWSENSORPIN);
34 |
35 | if (x == lastflowpinstate) {
36 | lastflowratetimer++;
37 | return; // nothing changed!
38 | }
39 |
40 | if (x == HIGH) {
41 | //low to high transition!
42 | pulses++;
43 | }
44 | lastflowpinstate = x;
45 | flowrate = 1000.0;
46 | flowrate /= lastflowratetimer; // in hertz
47 | lastflowratetimer = 0;
48 | }
49 |
50 | void useInterrupt(boolean v) {
51 | if (v) {
52 | // Timer0 is already used for millis() - we'll just interrupt somewhere
53 | // in the middle and call the "Compare A" function above
54 | OCR0A = 0xAF;
55 | TIMSK0 |= _BV(OCIE0A);
56 | } else {
57 | // do not call the interrupt function COMPA anymore
58 | TIMSK0 &= ~_BV(OCIE0A);
59 | }
60 | }
61 |
62 | void setup()
63 | {
64 |
65 | Serial.begin(9600);
66 | Serial.print("Flow sensor test!");
67 |
68 | digitalWrite(SOLENOIDPIN,LOW); //ACTIVE HIGH RELAY PUT THIS FIRST TO ENSURE PIN IS IN CORRECT STATE BEFORE WE INIT IT
69 | digitalWrite(FLOWSENSORPIN, HIGH);
70 |
71 | pinMode(SOLENOIDPIN, OUTPUT);
72 | pinMode(FLOWSENSORPIN, INPUT);
73 |
74 |
75 | lcd.begin(16, 2); // start the library
76 |
77 | printBanner(3000); // show banner for 2 seconds
78 |
79 | lcd.clear();
80 |
81 | printLabels();
82 |
83 | lastflowpinstate = digitalRead(FLOWSENSORPIN);
84 | useInterrupt(true);
85 |
86 | }
87 | void loop()
88 | {
89 |
90 | while(current_volume < (target_volume - adjustment_volume))
91 | {
92 | dowork();
93 | }
94 |
95 | digitalWrite(SOLENOIDPIN,HIGH); //Close solenoid //normal low!!
96 |
97 | lcd.setCursor(0,0);
98 | lcd.print("Waschm. dosieren");
99 | lcd.setCursor(0,1);
100 | lcd.print(" Start druecken ");
101 |
102 | //Debug Messaging
103 | Serial.println(" VALVE CLOSED ");
104 | Serial.println(" TARGET HIT ");
105 |
106 | }
107 |
108 | void printBanner(int bannerdelay)
109 | {
110 | lcd.setCursor(0,0);
111 | lcd.print(" Waschmittel ");
112 | lcd.setCursor(0,1);
113 | lcd.print(" wird dosiert ");
114 | delay(bannerdelay);
115 | }
116 |
117 | void printLabels()
118 | {
119 | lcd.setCursor(0,0);
120 | lcd.print("Ziel: ");
121 | lcd.setCursor(0,1);
122 | lcd.print("Aktuell: ");
123 | }
124 |
125 | // read the buttons
126 | int read_LCD_buttons()
127 | {
128 | adc_key_in = analogRead(0);
129 | /* OLD BUTTONS at 3.3V
130 | if (adc_key_in > 1000) return btnNONE;
131 | if (adc_key_in < 50) return btnRIGHT;
132 | if (adc_key_in < 195) return btnSELECT;
133 | if (adc_key_in < 380) return btnUP;
134 | if (adc_key_in < 555) return btnDOWN;
135 | if (adc_key_in < 790) return btnLEFT;
136 | */
137 |
138 | if (adc_key_in > 1000) return btnNONE;
139 | if (adc_key_in < 50) return btnRIGHT;
140 | if (adc_key_in < 195) return btnUP;
141 | if (adc_key_in < 380) return btnDOWN;
142 | if (adc_key_in < 555) return btnLEFT;
143 | if (adc_key_in < 790) return btnSELECT;
144 |
145 | return btnNONE;
146 | }
147 |
148 | void dowork()
149 | {
150 |
151 | //Serial.print("Freq: "); Serial.println(flowrate); //Uncomment these two lines to monitor the freq/pulses
152 | //Serial.print("Pulses: "); Serial.println(pulses, DEC);
153 | float liters = pulses;
154 | liters /= 7.5;
155 | liters /= 60.0;
156 |
157 | current_volume = liters;
158 |
159 | //Debug Messaging
160 | Serial.print("Cur: "); Serial.println(current_volume);
161 | Serial.print("Tar: "); Serial.println(target_volume);
162 |
163 | //Print the target volume value in litres
164 | lcd.setCursor(11,0);
165 | lcd.print(target_volume,2);
166 | lcd.setCursor(15,0);
167 | lcd.print("L");
168 |
169 | //Print the current volume value in litres
170 | lcd.setCursor(11,1);
171 | lcd.print(current_volume,2);
172 | lcd.setCursor(15,1);
173 | lcd.print("L");
174 |
175 | lcd_key = read_LCD_buttons(); // read the buttons
176 |
177 |
178 | switch (lcd_key) // depending on which button was pushed, we perform an action
179 | {
180 | case btnRIGHT:
181 | {
182 | if (digitalRead(SOLENOIDPIN == HIGH))
183 | {
184 | digitalWrite(SOLENOIDPIN,LOW); //STOP FLOW
185 | }
186 |
187 |
188 | Serial.println("Solenoid Closed");
189 | break;
190 | }
191 |
192 | case btnLEFT:
193 | {
194 | if (digitalRead(SOLENOIDPIN == LOW))
195 | {
196 | digitalWrite(SOLENOIDPIN,HIGH); //START FLOW
197 | }
198 |
199 |
200 | Serial.println("Solenoid Open");
201 |
202 | break;
203 | }
204 |
205 | case btnUP:
206 | {
207 | if (target_volume >= hltSIZE) //don't go larger than the size of the vessel
208 | {
209 | target_volume = hltSIZE;
210 | break;
211 | }
212 | else
213 | {
214 | target_volume += 0.01;
215 | break;
216 | }
217 |
218 | break;
219 | }
220 |
221 | case btnDOWN:
222 | {
223 | if (target_volume <= 0) //don't go below zero
224 | {
225 | target_volume = 0;
226 | break;
227 | }
228 | else
229 | {
230 | target_volume -= 0.01;
231 | }
232 | break;
233 | }
234 |
235 |
236 | case btnNONE:
237 | {
238 | break;
239 | }
240 | }
241 |
242 | }
