1 | #!/usr/bin/python
2 |
3 | from flask import Flask
4 | from flask_restful import Resource, Api
5 | from flask_restful import reqparse
6 | from flask.ext.mysql import MySQL
7 |
8 |
9 |
10 | mysql = MySQL()
11 | app = Flask(__name__)
12 |
13 | # MySQL configurations
14 | app.config['MYSQL_DATABASE_USER'] = 'pi'
15 | app.config['MYSQL_DATABASE_PASSWORD'] = 'xxxxxxxx'
16 | app.config['MYSQL_DATABASE_DB'] = 'xxxxxxxx'
17 | app.config['MYSQL_DATABASE_HOST'] = 'localhost'
18 |
19 |
20 | mysql.init_app(app)
21 |
22 | api = Api(app)
23 |
24 | class test(Resource):
25 | def post(self):
26 | try:
27 | # Parse the arguments
28 |
29 | parser = reqparse.RequestParser()
30 | parser.add_argument('ID', type=str, help='Id of Item')
31 | args = parser.parse_args()
32 |
33 | id = str(args['ID'])
34 | conn = mysql.connect()
35 | cursor = conn.cursor()
36 | cursor.execute("SELECT * FROM `PowerSystem` WHERE ID=id")
37 |
38 |
39 |
40 | data = cursor.fetchall()
41 |
42 | items_list=[];
43 | for item in data:
44 | i = {
45 | 'ID':str(item[0]),
46 | 'Timestamp':str(item[1]),
47 | 'batteryVoltage':str(item[2]),
48 | 'batteryCurrent':str(item[3]),
49 | 'solarVoltage':str(item[4]),
50 | 'solarCurrent':str(item[5]),
51 | 'loadVoltage':str(item[6]),
52 | 'loadCurrent':str(item[7]),
53 | 'batteryPower':str(item[8]),
54 | 'solarPower':str(item[9]),
55 | 'loadPower':str(item[10]),
56 | 'batteryCharge':str(item[11])
57 | }
58 | items_list.append(i)
59 |
60 | return {'StatusCode':'200','Items':items_list}
61 |
62 | except Exception as e:
63 | return {'error': str(e)}
64 | api.add_resource(test, '/test')
65 |
66 |
67 | if __name__ == '__main__':
68 | app.run(debug=True,host='0.0.0.0')
69 |
70 | app.run(debug=True,host='0.0.0.0')
