1 | #include <Adafruit_NeoPixel.h>
2 | #include <avr/io.h>
3 | #include <avr/interrupt.h>
4 |
5 | #define NUMPIXELSA 5
6 | #define NUMPIXELSB 5
7 | #define NUMPIXELSC 5
8 |
9 | Adafruit_NeoPixel strip_A = Adafruit_NeoPixel(NUMPIXELSA, 0, NEO_GRB + NEO_KHZ800); // 3 Strips designed to be offset by 120 degrees on a wheel
10 | Adafruit_NeoPixel strip_B = Adafruit_NeoPixel(NUMPIXELSB, 1, NEO_GRB + NEO_KHZ800);
11 | Adafruit_NeoPixel strip_C = Adafruit_NeoPixel(NUMPIXELSC, 3, NEO_GRB + NEO_KHZ800);
12 |
13 | //uint32_t whiteA = strip_A.Color(255, 255, 255); disabled for testing purposes
14 | //uint32_t whiteB = strip_B.Color(255, 255, 255);
15 | //uint32_t whiteC = strip_C.Color(255, 255, 255);
16 |
17 | uint32_t offA = strip_A.Color(0, 0, 0);
18 | uint32_t offB = strip_B.Color(0, 0, 0);
19 | uint32_t offC = strip_C.Color(0, 0, 0);
20 |
21 | uint32_t whiteA = strip_A.Color(0, 0, 255); //Testcolor to better see it in the simulator ;)
22 | uint32_t whiteB = strip_B.Color(0, 0, 255);
23 | uint32_t whiteC = strip_C.Color(0, 0, 255);
24 |
25 | volatile unsigned long time = 0;
26 | volatile unsigned long time_last = 0;
27 | volatile unsigned int rpm_array[3] = {0, 0, 0}; // 3 samples averaged
28 | unsigned long refreshInterval = 10; // in ms, for LCD refresh timing
29 | unsigned long previousMillis = 0;
30 | volatile unsigned int rpm = 0;
31 | volatile unsigned int last_rpm = 0;
32 | unsigned int rotDelay = 0; // Calculated time based variable to control the duration and delay between LEDs switching on and off, integer instead of float to test and save processing time
33 | unsigned int rotDelayA = 0;
34 | void setup()
35 | {
36 | GIMSK = 0b01000000; // Enable INT0 External Interrupt
37 | MCUCR = 0b00000011; // Rising-Edge Triggered INT0
38 |
39 | DDRB &= ~(1<<PB5); //Set unused pins as input.
40 | DDRB &= ~(1<<PB4);
41 | PORTB |= (1 << PB5); // Enable pullup resistor
42 | PORTB |= (1 << PB4);
43 |
44 | strip_A.begin(); // Initialize Neopixel Strips
45 | strip_B.begin();
46 | strip_C.begin();
47 | strip_A.setBrightness(230); // Set Strips to approx 90% Brightness
48 | strip_B.setBrightness(230);
49 | strip_C.setBrightness(230);
50 | strip_A.show(); // Send empty data to strips to reset floating output turning all Neopixels off
51 | strip_B.show();
52 | strip_C.show();
53 |
54 | // for (int a = 0; a < NUMPIXELSA; a++) { // Strip Test
55 | // strip_A.setPixelColor(a, whiteA );
56 | // strip_A.show(); // Send data
57 | // delay(100); // Delay to test each strip
58 | // }
59 | // for (int a = 0; a < NUMPIXELSA; a++) {
60 | // strip_A.setPixelColor(a, offA );
61 | // strip_A.show();
62 | // }
63 | // for (int b = 0; b < NUMPIXELSB; b++) {
64 | // strip_B.setPixelColor(b, whiteB);
65 | // strip_B.show();
66 | // delay(100);
67 | // }
68 | // for (int b = 0; b < NUMPIXELSA; b++) {
69 | // strip_B.setPixelColor(b, offB );
70 | // strip_B.show();
71 | // }
72 | // for (int c = 0; c < NUMPIXELSC; c++) {
73 | // strip_C.setPixelColor(c, whiteC);
74 | // strip_C.show();
75 | // delay(100);
76 | // }
77 | // for (int c = 0; c < NUMPIXELSA; c++) {
78 | // strip_C.setPixelColor(c, offC );
79 | // strip_C.show();
80 | // }
81 | sei(); // Enable Interrupts
82 | }
83 | void update_rpm() {
84 | rpm = 60 * (1000000 / (time * 1));
85 | rotDelay = 360000 / (rpm * 20);
86 | rotDelayA = ((rotDelay / 3) / 3);
87 | }
88 | void strips () {
89 | for (int a = 0; a < NUMPIXELSA; a++) {
90 | strip_A.setPixelColor(a, whiteA );
91 | strip_A.show();
92 | delay(rotDelay);
93 | }
94 | for (int a = 0; a < NUMPIXELSA; a++) {
95 | strip_A.setPixelColor(a, offA );
96 | strip_A.show();
97 | delay(rotDelay); for (int a = 0; a < NUMPIXELSA; a++) {
98 | strip_A.setPixelColor(a, whiteA );
99 | strip_A.show();
100 | delay(rotDelay);
101 | }
102 | for (int a = 0; a < NUMPIXELSA; a++) {
103 | strip_A.setPixelColor(a, offA );
104 | strip_A.show();
105 | delay(rotDelay);
106 | }
107 | delay(rotDelayA);
108 | for (int b = 0; b < NUMPIXELSB; b++) {
109 | strip_B.setPixelColor(b, whiteB );
110 | strip_B.show();
111 | delay(rotDelay);
112 | }
113 | for (int b = 0; b < NUMPIXELSB; b++) {
114 | strip_B.setPixelColor(b, offB );
115 | strip_B.show();
116 | delay(rotDelay);
117 | }
118 | delay(rotDelayA);
119 | for (int c = 0; c < NUMPIXELSC; c++) {
120 | strip_C.setPixelColor(c, whiteC );
121 | strip_C.show();
122 | delay(rotDelay);
123 | }
124 | for (int c = 0; c < NUMPIXELSC; c++) {
125 | strip_C.setPixelColor(c, offC );
126 | strip_C.show();
127 | delay(rotDelay);
128 | }
129 | delay(rotDelayA);
130 | }
131 | delay(rotDelayA);
132 | for (int b = 0; b < NUMPIXELSB; b++) {
133 | strip_B.setPixelColor(b, whiteB );
134 | strip_B.show();
135 | delay(rotDelay);
136 | }
137 | for (int b = 0; b < NUMPIXELSB; b++) {
138 | strip_B.setPixelColor(b, offB );
139 | strip_B.show();
140 | delay(rotDelay);
141 | }
142 | delay(rotDelayA);
143 | for (int c = 0; c < NUMPIXELSC; c++) {
144 | strip_C.setPixelColor(c, whiteC );
145 | strip_C.show();
146 | delay(rotDelay);
147 | }
148 | for (int c = 0; c < NUMPIXELSC; c++) {
149 | strip_C.setPixelColor(c, offC );
150 | strip_C.show();
151 | delay(rotDelay);
152 | }
153 | delay(rotDelayA);
154 | }
155 | void loop() {
156 | update_rpm(); // sensor ISR will look for time period
157 | if (last_rpm - rpm != 0 ) { // update LCD only if there is a change of rpm
158 | last_rpm = rpm;
159 | // need to check the case that there is 0 rpm (full stop)
160 | unsigned long currentMillis = millis();
161 | if (currentMillis - previousMillis > refreshInterval) { // at a decent refresh rate
162 | previousMillis = currentMillis;
163 | }
164 | }
165 |
166 | }
167 |
168 | ISR(INT0_vect) //Capture Hall via Interrupt
169 | {
170 | time = (micros() - time_last);
171 | time_last = micros();
172 | strips();
173 |
174 | }
