1 | #include <avr/io.h>
2 | #include <util/delay.h>
3 | #include <i2cmaster.h>
4 |
5 |
6 | #define BAUD 9600
7 | #define MYUBRR ((uint16_t) ((F_CPU / ((BAUD) * 16.0)) + .5) - 1)
8 |
9 | #define rtc_clock 0x68
10 |
11 | // contains what the bluetooth module received
12 | uint8_t data;
13 |
14 | void USART_Init(unsigned int ubrr) {
15 | // set baud rate
16 | UBRR0H = (unsigned char)(ubrr>>8);
17 | UBRR0L = (unsigned char)(ubrr);
18 | // enable receiver, transmitter and interrupts for rx/tx
19 | UCSR0B = (1<<RXEN0) | (1<<TXEN0) | (1<<RXCIE0) | (1<< TXCIE0);
20 | }
21 |
22 |
23 |
24 | void USART_transmit(char c) {
25 | while ( !(UCSR0A & (1<<UDRE0)) ) {}
26 | UDR0 = c;
27 | }
28 |
29 |
30 |
31 | void transmit_char(char c) {
32 | USART_transmit(c);
33 | USART_transmit('\r');
34 | USART_transmit('\n');
35 | }
36 |
37 |
38 |
39 | void send_string(char s[]) {
40 | int i =0;
41 |
42 | while (s[i] != 0x00) {
43 | USART_transmit(s[i]);
44 | i++;
45 | }
46 | USART_transmit('\r');
47 | USART_transmit('\n');
48 |
49 | }
50 |
51 |
52 | // code for two status leds, to signal error and ok states
53 | // please dont look to closely....needs rewriting
54 |
55 | #define ERROR_LED_2 PB1
56 | #define ERROR_LED PB0
57 | #define OK_LED PB2
58 |
59 | #define ERROR_LED_2_PORT PORTB
60 | #define ERROR_LED_PORT PORTB
61 | #define OK_LED_PORT PORTB
62 |
63 |
64 | // turn the error led on and keep it on
65 | void error_led_on() {
66 | ERROR_LED_PORT |= (1 << ERROR_LED);
67 | }
68 |
69 | // turn it off
70 | void error_led_off() {
71 | ERROR_LED_PORT &= ~(1 << ERROR_LED);
72 | }
73 |
74 |
75 | void error_led2_on() {
76 | ERROR_LED_2_PORT |= (1 << ERROR_LED_2);
77 | }
78 |
79 | // turn it off
80 | void error_led2_off() {
81 | ERROR_LED_2_PORT &= ~(1 << ERROR_LED_2);
82 | }
83 |
84 |
85 | // flash the error led, fast
86 | void flash_fast(uint8_t count) {
87 | for (int n=1; n<=count; n++) {
88 | error_led_on();
89 | _delay_ms(300);
90 | error_led_off();
91 | _delay_ms(300);
92 | }
93 | }
94 |
95 | // ...normal
96 | void flash_normal(uint8_t count) {
97 | for (int n=1; n<=count; n++) {
98 | error_led_on();
99 | _delay_ms(1000);
100 | error_led_off();
101 | _delay_ms(1000);
102 | }
103 | }
104 |
105 | // second led to have more indicator for where we are stuck in the code
106 | void flash_normal_error_led_2(uint8_t count) {
107 | for (int n=1; n<=count; n++) {
108 | error_led2_on();
109 | _delay_ms(1000);
110 | error_led2_off();
111 | _delay_ms(1000);
112 | }
113 | }
114 | // ...slow
115 | void flash_slow(uint8_t count) {
116 | for (int n=1; n<=count; n++) {
117 | error_led_on();
118 | _delay_ms(3000);
119 | error_led_off();
120 | _delay_ms(3000);
121 | }
122 | }
123 |
124 | // a third led, can be used to signal ok states
125 | void flash_ok_led(uint8_t count) {
126 | for (uint8_t n=1; n <= count; n++) {
127 | OK_LED_PORT |= (1 << OK_LED);
128 | _delay_ms(1000);
129 | OK_LED_PORT &= ~(1 << OK_LED);
130 | _delay_ms(1000);
131 | }
132 | }
133 |
134 | // ---------------------------------- led code end
135 |
136 |
137 |
138 |
139 |
140 |
141 |
142 | uint8_t decToBcd(uint8_t val)
143 | {
144 | return( (val/10*16) + (val%10) );
145 | }
146 | // Convert binary coded decimal to normal decimal numbers
147 | uint8_t bcdToDec(uint8_t val)
148 | {
149 | return( (val/16*10) + (val%16) );
150 | }
151 |
152 |
153 |
154 |
155 | void setTime(uint8_t second, uint8_t minute, uint8_t hour, uint8_t dayOfWeek,
156 | uint8_t dayOfMonth, uint8_t month, uint8_t year) {
157 |
158 | flash_normal(1);
159 | // initialize, taken from peter fleurys i2c example (he wrote the i2c code)
160 | i2c_init();
161 | // connect to the device and tell it that we want to write to it
162 |
163 | uint8_t ret;
164 | //ret = i2c_start(rtc_clock+I2C_WRITE); // set device address and write mode
165 | ret = i2c_start(rtc_clock);
166 | // this line is never reached
167 | flash_normal(1);
168 |
169 | if ( ret ) {
170 | flash_normal(3);
171 | /* failed to issue start condition, possibly no device found */
172 | i2c_stop();
173 | // we can issue an error message here if the device failed to respond
174 |
175 | } else {
176 | flash_ok_led(3);
177 | // tell the device where we want to write to (address in ram)
178 | i2c_write(0x00);
179 |
180 | // set time
181 | i2c_write(decToBcd(second)); // set seconds
182 | i2c_write(decToBcd(minute)); // set minutes
183 | i2c_write(decToBcd(hour)); // set hours
184 | i2c_write(decToBcd(dayOfWeek)); // set day of week (1=Sunday, 7=Saturday)
185 | i2c_write(decToBcd(dayOfMonth)); // set date (1 to 31)
186 | i2c_write(decToBcd(month)); // set month
187 | i2c_write(decToBcd(year)); // set year (0 to 99)
188 | i2c_stop();
189 | }
190 | }
191 |
192 |
193 |
194 | uint8_t result;
195 |
196 | typedef struct {
197 | uint8_t sec;
198 | uint8_t min;
199 | uint8_t hour;
200 | uint8_t weekDay;
201 | uint8_t date;
202 | uint8_t month;
203 | uint8_t year;
204 | } rtc_t;
205 |
206 |
207 |
208 | rtc_t rtc;
209 |
210 | void getTime(void) {
211 | // receive 1 byte (seconds)
212 | flash_normal(3);
213 |
214 | uint8_t ret;
215 | ret = i2c_start(rtc_clock+I2C_WRITE); // set device address and write mode
216 | if ( ret ) {
217 | flash_normal(3);
218 | /* failed to issue start condition, possibly no device found */
219 | i2c_stop();
220 | // we can issue an error message here if the device failed to respond
221 |
222 | } else {
223 | flash_ok_led(1);
224 | /* issuing start condition ok, device accessible
225 | we can now use i2c_write() to talk to the device*/
226 |
227 |
228 |
229 | // request second ram adress (tell the chip at what adress we want to start reading)
230 | // 0x00 =
231 | i2c_write(0x00);
232 | i2c_stop();
233 |
234 | // _rep_start or _start? whats the difference?
235 | i2c_rep_start(rtc_clock);
236 | result = i2c_readAck();
237 | rtc.sec = i2c_readAck(); // read second and return Positive ACK
238 | rtc.min = i2c_readAck(); // read minute and return Positive ACK
239 | rtc.hour= i2c_readAck(); // read hour and return Negative/No ACK
240 | rtc.weekDay = i2c_readAck(); // read weekDay and return Positive ACK
241 | rtc.date= i2c_readAck(); // read Date and return Positive ACK
242 | rtc.month=i2c_readAck(); // read Month and return Positive ACK
243 | rtc.year =i2c_readNak(); // read Year and return Negative/No ACK
244 | i2c_stop();
245 | }
246 | }
247 |
248 |
249 |
250 |
251 | int main(void) {
252 | DDRB |= (1 << ERROR_LED);
253 | DDRB |= (1 << ERROR_LED_2);
254 |
255 | DDRB |= (1 << OK_LED);
256 |
257 | // test leds to see if they are connected and working
258 |
259 | flash_normal(1);
260 | flash_normal_error_led_2(1);
261 | flash_ok_led(1);
262 |
263 |
264 | i2c_init();
265 | uint8_t count = 0;
266 | setTime(30,42,21,4,26,11,14);
267 |
268 | while (1) {
269 |
270 |
271 | _delay_ms(3000);
272 |
273 | getTime();
274 | // flash the led for the ammount of seconds
275 | for (uint8_t n=0; n <= rtc.sec; n++) {
276 | flash_ok_led(1);
277 | }
278 | flash_normal(2);
279 |
280 | }
281 | }
