1 | void PWMSignalControl(void)
2 | {
3 |
4 | /* TIM1 channels Configuration in PWM mode */
5 | TIM_Config();
6 |
7 | /* COMP2 Configuration */
8 | COMP_Config();
9 |
10 | /* Infinite loop */
11 | while (1)
12 | {
13 | }
14 | }
15 | void TIM_Config(void)
16 | {
17 |
18 | TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
19 | TIM_OCInitTypeDef TIM_OCInitStructure;
20 | TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
21 | GPIO_InitTypeDef GPIO_InitStructure;
22 |
23 | /* GPIOA clock enable */
24 | RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
25 |
26 | /* TIM1 channels pin configuration:
27 | TIM1_CH1 -> PA8
28 | */
29 | GPIO_StructInit(&GPIO_InitStructure);
30 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
31 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
32 | GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
33 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
34 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
35 | GPIO_Init(GPIOA, &GPIO_InitStructure);
36 |
37 | /* Enable Alternate function on PA8 to be controlled by TIM1 */
38 | GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_2);
39 |
40 | /* TIM1 clock enable */
41 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
42 |
43 | /* Time Base configuration */
44 | TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
45 | TIM_TimeBaseStructure.TIM_Prescaler = 0;
46 | TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
47 | TIM_TimeBaseStructure.TIM_Period = 480;
48 | TIM_TimeBaseStructure.TIM_ClockDivision = 0;
49 | TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
50 | TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
51 |
52 | /* Channel 1 Configuration in PWM mode */
53 | TIM_OCStructInit(&TIM_OCInitStructure);
54 | TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
55 | TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
56 | TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
57 | TIM_OCInitStructure.TIM_Pulse = 240;
58 | TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
59 | TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
60 | TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
61 | TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
62 | TIM_OC1Init(TIM1, &TIM_OCInitStructure);
63 |
64 | /* Automatic Output enable, Break, dead time and lock configuration*/
65 | TIM_BDTRStructInit(&TIM_BDTRInitStructure);
66 | TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
67 | TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
68 | TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1;
69 | TIM_BDTRInitStructure.TIM_DeadTime = 11;
70 | TIM_BDTRInitStructure.TIM_Break = TIM_Break_Enable;
71 | TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;
72 | TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
73 | TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure);
74 |
75 | /* Main Output Enable */
76 | TIM_CtrlPWMOutputs(TIM1, ENABLE);
77 |
78 | /* TIM1 counter enable */
79 | TIM_Cmd(TIM1, ENABLE);
80 | }
81 |
82 | /**
83 | * @brief Configures COMP2: PA3 as COMP2 non inverting input
84 | * VREFINT as COMP2 inverting input
85 | * and COMP2 output to TIM2 BKIN.
86 | * @param None
87 | * @retval None
88 | */
89 | void COMP_Config(void)
90 | {
91 |
92 | COMP_InitTypeDef COMP_InitStructure;
93 | GPIO_InitTypeDef GPIO_InitStructure;
94 | /* GPIOA Peripheral clock enable */
95 | RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
96 |
97 | /* Configure PA3 in analog mode: PA3 is connected to COMP2 non inverting input */
98 | GPIO_StructInit(&GPIO_InitStructure);
99 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
100 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
101 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
102 | GPIO_Init(GPIOA, &GPIO_InitStructure);
103 |
104 | /* COMP Peripheral clock enable */
105 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
106 |
107 | /* COMP2 config */
108 | COMP_StructInit(&COMP_InitStructure);
109 | COMP_InitStructure.COMP_InvertingInput = COMP_InvertingInput_VREFINT;
110 | COMP_InitStructure.COMP_Output = COMP_Output_TIM1BKIN;
111 | COMP_InitStructure.COMP_Hysteresis = COMP_Hysteresis_No;
112 | COMP_InitStructure.COMP_Mode = COMP_Mode_HighSpeed;
113 | COMP_InitStructure.COMP_OutputPol = COMP_OutputPol_NonInverted;
114 | COMP_Init(COMP_Selection_COMP2, &COMP_InitStructure);
115 |
116 | /* Enable COMP2 */
117 | COMP_Cmd(COMP_Selection_COMP2, ENABLE);
