1 | #include <avr/io.h>
2 | #include <util/delay.h>
3 | #include <avr/interrupt.h>
4 | #include <stdlib.h>
5 | //
6 | //#ifndef F_CPU
7 | //#define F_CPU 1000000000UL
8 | //#endif
9 |
10 |
11 |
12 | int main(void)
13 | {
14 |
15 | DDRB |= (1 << PB2); // PWM output on PB2 - OC0A
16 | DDRB |= (1 << PB3); // PWM output on B3 - OC1A
17 | DDRB |= (1 << PB4); // PWM output on B4 - OC1B
18 |
19 | // Rot
20 | TCCR0A = (1<<COM0A1)|(1<<COM0A0)|(1<<WGM01)|(1<<WGM00);
21 | OCR0A = 0x10; // initial PWM pulse width
22 |
23 | //Blau
24 | DDRB |= (1 << PB3); // PWM output on PB2
25 | TCCR1A = (1 << COM1A1) | (1 << WGM00); // phase correct PWM mode
26 | OCR1A = 0x10; // initial PWM pulse width
27 |
28 | //Grün
29 | DDRB |= (1 << PB4); // PWM output on PB2
30 | TCCR1B = (1 << COM1B1) | (1 << WGM00); // phase correct PWM mode
31 | OCR1B = 0x10; // initial PWM pulse width
32 | TCCR0B = (1 << CS01); // clock source = CLK/8, start PWM
33 | //Rot
34 | PORTB |= (1 << PB1); // initializes the pull-up resistor on AVR pin PB1
35 | PORTB |= (1 << PB0); // initializes the pull-up resistor on AVR pin PB0
36 | PORTD |= (1 << PD6); // initializes the pull-up resistor on AVR pin PD2
37 |
38 | //Blau
39 | PORTB |= (1 << PB7); // initializes the pull-up resistor on AVR pin PB1
40 | PORTB |= (1 << PB6); // initializes the pull-up resistor on AVR pin PB0
41 | PORTD |= (1 << PB5); // initializes the pull-up resistor on AVR pin PD2
42 |
43 | //Grün
44 | PORTB |= (1 << PD3); // initializes the pull-up resistor on AVR pin PB1
45 | PORTB |= (1 << PD4); // initializes the pull-up resistor on AVR pin PB0
46 | PORTD |= (1 << PD5); // initializes the pull-up resistor on AVR pin PD2
47 |
48 |
49 | TCCR0B = (1 << CS01); // clock source = CLK/8, start PWM
50 |
51 | unsigned char PWM_R = 0; // 8-bit PWM value
52 | unsigned char PWM_G = 0; // 8-bit PWM value
53 | unsigned char PWM_B = 0; // 8-bit PWM value
54 | int Schalter[8] = {0,0,0,0,0,0,0,0};
55 |
56 |
57 | while(1)
58 | {
59 | // Schalter abfragen und Werte in Array ablegen
60 | // Rot
61 | if (bit_is_clear(PINB, PB1))
62 | { Schalter[0] = 1;}
63 | else { Schalter[0] = 0;}
64 |
65 | if (bit_is_clear(PINB, PB0))
66 | { Schalter[1] = 1;}
67 | else { Schalter[1] = 0;}
68 |
69 | if (bit_is_clear(PIND, PD6))
70 | { Schalter[2] = 1;}
71 | else { Schalter[2] = 0;}
72 |
73 | //Blau
74 | if (bit_is_clear(PINB, PB1))
75 | { Schalter[0] = 1;}
76 | else { Schalter[0] = 0;}
77 |
78 | if (bit_is_clear(PINB, PB0))
79 | { Schalter[1] = 1;}
80 | else { Schalter[1] = 0;}
81 |
82 | if (bit_is_clear(PIND, PD6))
83 | { Schalter[2] = 1;}
84 | else { Schalter[2] = 0;}
85 |
86 |
87 | //Grün
88 | if (bit_is_clear(PINB, PB1))
89 | { Schalter[0] = 1;}
90 | else { Schalter[0] = 0;}
91 |
92 | if (bit_is_clear(PINB, PB0))
93 | { Schalter[1] = 1;}
94 | else { Schalter[1] = 0;}
95 |
96 | if (bit_is_clear(PIND, PD6))
97 | { Schalter[2] = 1;}
98 | else { Schalter[2] = 0;}
99 |
100 | //Bedingungen abfragen und Ergebnis an PWM übergeben
101 | //Rot
102 | if (Schalter[0]==0 && Schalter[1]==0 && Schalter[2] == 0) //000
103 | { PWM_R = 0; }
104 |
105 | if (Schalter[0]==1 && Schalter[1]==0 && Schalter[2] == 0) //100
106 | { PWM_R = 85; }
107 | if (Schalter[0]==0 && Schalter[1]==1 && Schalter[2] == 0) //010
108 | { PWM_R = 85; }
109 | if (Schalter[0]==0 && Schalter[1]==0 && Schalter[2] == 1) //001
110 | { PWM_R = 85; }
111 |
112 | if (Schalter[0]==1 && Schalter[1]==1 && Schalter[2] == 0) //110
113 | { PWM_R = 170; }
114 | if (Schalter[0]==0 && Schalter[1]==1 && Schalter[2] == 1) //011
115 | { PWM_R = 170; }
116 | if (Schalter[0]==1 && Schalter[1]==0 && Schalter[2] == 1) //101
117 | { PWM_R = 170; }
118 |
119 | if (Schalter[0]==1 && Schalter[1]==1 && Schalter[2] == 1) //111
120 | { PWM_R = 255; }
121 |
122 | OCR0A = PWM_R; // write new PWM value
123 |
124 | //Blau
125 | if (Schalter[3]==0 && Schalter[4]==0 && Schalter[5] == 0) //000
126 | { PWM_B = 0; }
127 |
128 | if (Schalter[3]==1 && Schalter[4]==0 && Schalter[5] == 0) //100
129 | { PWM_B = 85; }
130 | if (Schalter[3]==0 && Schalter[4]==1 && Schalter[5] == 0) //010
131 | { PWM_B = 85; }
132 | if (Schalter[3]==0 && Schalter[4]==0 && Schalter[5] == 1) //001
133 | { PWM_B = 85; }
134 |
135 | if (Schalter[3]==1 && Schalter[1]==1 && Schalter[5] == 0) //110
136 | { PWM_B = 170; }
137 | if (Schalter[3]==0 && Schalter[4]==1 && Schalter[5] == 1) //011
138 | { PWM_B = 170; }
139 | if (Schalter[4]==1 && Schalter[4]==0 && Schalter[5] == 1) //101
140 | { PWM_B = 170; }
141 |
142 | if (Schalter[0]==1 && Schalter[4]==1 && Schalter[5] == 1) //111
143 | { PWM_B = 255; }
144 |
145 | OCR0A = PWM_B; // write new PWM value
146 |
147 |
148 | //Grün
149 | if (Schalter[6]==0 && Schalter[7]==0 && Schalter[8] == 0) //000
150 | { PWM_G = 0; }
151 |
152 | if (Schalter[6]==1 && Schalter[7]==0 && Schalter[8] == 0) //100
153 | { PWM_G = 85; }
154 | if (Schalter[6]==0 && Schalter[7]==1 && Schalter[8] == 0) //010
155 | { PWM_G = 85; }
156 | if (Schalter[6]==0 && Schalter[7]==0 && Schalter[8] == 1) //001
157 | { PWM_G = 85; }
158 |
159 | if (Schalter[6]==1 && Schalter[7]==1 && Schalter[8] == 0) //110
160 | { PWM_G = 170; }
161 | if (Schalter[6]==0 && Schalter[7]==1 && Schalter[8] == 1) //011
162 | { PWM_G = 170; }
163 | if (Schalter[6]==1 && Schalter[7]==0 && Schalter[8] == 1) //101
164 | { PWM_G = 170; }
165 |
166 | if (Schalter[6]==1 && Schalter[7]==1 && Schalter[8] == 1) //111
167 | { PWM_G = 255; }
168 |
169 | OCR0A = PWM_G; // write new PWM value
170 |
171 | }//while
172 | }//main
