1 | void FlashRead(XQspiPs *QspiPtr, u32 Address, u32 ByteCount, u8 Command,
2 | u8 *WriteBfrPtr, u8 *ReadBfrPtr)
3 | {
4 | u32 RealAddr;
5 | u32 RealByteCnt;
6 | u32 BankSel;
7 | u32 BufferIndex;
8 | u32 TotalByteCnt;
9 | u8 ShiftSize;
10 |
11 | /*
12 | * Retain the actual byte count
13 | */
14 | TotalByteCnt = ByteCount;
15 |
16 | while(((signed long)(ByteCount)) > 0) {
17 |
18 | /*
19 | * Translate address based on type of connection
20 | * If stacked assert the slave select based on address
21 | */
22 | RealAddr = GetRealAddr(QspiPtr, Address);
23 |
24 | /*
25 | * Select bank
26 | */
27 | if(Flash_Config_Table[FCTIndex].FlashDeviceSize > SIXTEENMB) {
28 | BankSel = RealAddr/SIXTEENMB;
29 | SendBankSelect(QspiPtr, WriteBfrPtr, BankSel);
30 | }
31 |
32 | /*
33 | * If data to be read spans beyond the current bank, then
34 | * calculate RealByteCnt in current bank. Else
35 | * RealByteCnt is the same as ByteCount
36 | */
37 | if((Address & BANKMASK) != ((Address+ByteCount) & BANKMASK)) {
38 | RealByteCnt = (Address & BANKMASK) + SIXTEENMB - Address;
39 | }else {
40 | RealByteCnt = ByteCount;
41 | }
42 |
43 |
44 | /*
45 | * Setup the write command with the specified address and data for the
46 | * Flash
47 | */
48 | WriteBfrPtr[COMMAND_OFFSET] = Command;
49 | WriteBfrPtr[ADDRESS_1_OFFSET] = (u8)((RealAddr & 0xFF0000) >> 16);
50 | WriteBfrPtr[ADDRESS_2_OFFSET] = (u8)((RealAddr & 0xFF00) >> 8);
51 | WriteBfrPtr[ADDRESS_3_OFFSET] = (u8)(RealAddr & 0xFF);
52 |
53 | if ((Command == FAST_READ_CMD) || (Command == DUAL_READ_CMD) ||
54 | (Command == QUAD_READ_CMD)) {
55 | RealByteCnt += DUMMY_SIZE;
56 | }
57 | /*
58 | * Send the read command to the Flash to read the specified number
59 | * of bytes from the Flash, send the read command and address and
60 | * receive the specified number of bytes of data in the data buffer
61 | */
62 | XQspiPs_PolledTransfer(QspiPtr, WriteBfrPtr,
63 | &(ReadBfrPtr[TotalByteCnt - ByteCount]),
64 | RealByteCnt + OVERHEAD_SIZE);
65 |
66 | /*
67 | * To discard the first 5 dummy bytes, shift the data in read buffer
68 | */
69 | if((Command == FAST_READ_CMD) || (Command == DUAL_READ_CMD) ||
70 | (Command == QUAD_READ_CMD)){
71 | ShiftSize = OVERHEAD_SIZE + DUMMY_SIZE;
72 | }else{
73 | ShiftSize = OVERHEAD_SIZE;
74 | }
75 |
76 | for(BufferIndex = (TotalByteCnt - ByteCount);
77 | BufferIndex < (TotalByteCnt - ByteCount) + RealByteCnt;
78 | BufferIndex++) {
79 | ReadBfrPtr[BufferIndex] = ReadBfrPtr[BufferIndex + ShiftSize];
80 | }
81 |
82 | /*
83 | * Increase address to next bank
84 | */
85 | Address = (Address & BANKMASK) + SIXTEENMB;
86 | /*
87 | * Decrease byte count by bytes already read.
88 | */
89 | if ((Command == FAST_READ_CMD) || (Command == DUAL_READ_CMD) ||
90 | (Command == QUAD_READ_CMD)) {
91 | ByteCount = ByteCount - (RealByteCnt - DUMMY_SIZE);
92 | }else {
93 | ByteCount = ByteCount - RealByteCnt;
94 | }
95 |
96 | }
97 |
98 | }
