So jetzt nochmals für alle die Originalen Quelltexte
Der AVR Quelltext ist schon etwas älter und ich habe diesen
mit AVRStudio4 und WINAVR-20090313 geschrieben besser gesagt dieser
kommt aus der lib und ist nur eingebunden.
1 | /** \ingroup util_crc
2 | Optimized CRC-16 calculation.
3 |
4 | Polynomial: x^16 + x^15 + x^2 + 1 (0xa001)<br>
5 | Initial value: 0xffff
6 |
7 | This CRC is normally used in disk-drive controllers.
8 |
9 | The following is the equivalent functionality written in C.
10 |
11 | \code
12 | uint16_t
13 | crc16_update(uint16_t crc, uint8_t a)
14 | {
15 | int i;
16 |
17 | crc ^= a;
18 | for (i = 0; i < 8; ++i)
19 | {
20 | if (crc & 1)
21 | crc = (crc >> 1) ^ 0xA001;
22 | else
23 | crc = (crc >> 1);
24 | }
25 |
26 | return crc;
27 | }
28 |
29 | \endcode */
30 |
31 | static __inline__ uint16_t
32 | _crc16_update(uint16_t __crc, uint8_t __data)
33 | {
34 | uint8_t __tmp;
35 | uint16_t __ret;
36 |
37 | __asm__ __volatile__ (
38 | "eor %A0,%2" "\n\t"
39 | "mov %1,%A0" "\n\t"
40 | "swap %1" "\n\t"
41 | "eor %1,%A0" "\n\t"
42 | "mov __tmp_reg__,%1" "\n\t"
43 | "lsr %1" "\n\t"
44 | "lsr %1" "\n\t"
45 | "eor %1,__tmp_reg__" "\n\t"
46 | "mov __tmp_reg__,%1" "\n\t"
47 | "lsr %1" "\n\t"
48 | "eor %1,__tmp_reg__" "\n\t"
49 | "andi %1,0x07" "\n\t"
50 | "mov __tmp_reg__,%A0" "\n\t"
51 | "mov %A0,%B0" "\n\t"
52 | "lsr %1" "\n\t"
53 | "ror __tmp_reg__" "\n\t"
54 | "ror %1" "\n\t"
55 | "mov %B0,__tmp_reg__" "\n\t"
56 | "eor %A0,%1" "\n\t"
57 | "lsr __tmp_reg__" "\n\t"
58 | "ror %1" "\n\t"
59 | "eor %B0,__tmp_reg__" "\n\t"
60 | "eor %A0,%1"
61 | : "=r" (__ret), "=d" (__tmp)
62 | : "r" (__data), "0" (__crc)
63 | : "r0"
64 | );
65 | return __ret;
66 | }
Diesen code habe ich auf einem STM32 implementiert
1 | /* This funtion is used Calculate the CRC
2 | *
3 | * data --> data to be transmitted
4 | * returns received value
5 | */
6 |
7 | uint16_t crc16_update(uint16_t crc, uint8_t a)
8 | {
9 | uint16_t i;
10 | crc ^= a;
11 | for (i = 0; i < 8; ++i)
12 | {
13 | if (crc & 1) crc = (crc >> 1) ^ 0xA001;
14 | else crc = (crc >> 1);
15 | }
16 | return crc;
17 | }
Und jetzt nochmals die Frage warum rechnet der STM32 bei gleichem
Startwert etwas anderes aus. Ich habe mit einem online CRC Calculator
mal
geschaut und ich bekomme das Ergebnis des STM32 nur hin wenn ich
die folgenden Parameter verwende
Input reflected: yes
Result reflected: yes
Polynomial: 0x8005
Initial Value: 0xffff
Final Xor Value: 0x0
In meinen Augen steht dort nichts anderes Sorry für das Nebelwerfen am
Anfang aber ich hab das von Unterwegs geschrieben.
EbbeSand
