1 | #include <util/delay.h>
2 | #include <stdint.h>
3 | #include <avr/io.h>
4 | #include <avr/wdt.h>
5 | #include <avr/interrupt.h>
6 | #include <avr/power.h>
7 | #include <avr/sleep.h>
8 |
9 | #if defined (__AVR_ATmega168__) || defined (__AVR_ATmega168P__)
10 | #define F_CPU 1000000UL
11 | #define TIM0_COMPA_vect TIMER0_COMPA_vect
12 | #define GIMSK PCICR
13 | #define PCIE PCIE0
14 | #define PCMSK PCMSK0
15 | #endif
16 |
17 | // PB0 - Switch (Input)
18 | // PB1 - NC (Output)
19 | // PB2 - NC (Output)
20 | // PB3 - NC (Output)
21 | // PB4 - Out (Output)
22 | // PB5 - NC (Output)
23 |
24 | #define SWITCH PB0
25 | #define SWITCH_ON ( !(PINB & (1 << SWITCH)) )
26 | #define SWITCH_OFF ( PINB & (1 << SWITCH) )
27 |
28 | #define OUT PB4
29 | #define OUT_ON PORTB |= (1 << OUT)
30 | #define OUT_OFF PORTB &= ~(1 << OUT)
31 | #define OUT_TOGGLE PORTB ^= (1 << OUT)
32 |
33 | #define MIN_PULSE_LEN 20
34 | #define MAX_PULSE_LEN1 200 // 250 debug
35 | #define MAX_PULSE_LEN2 250
36 | #define MAX_EVENT_LEN 500
37 |
38 | /*
39 | ATtiny13a
40 | ----
41 | PB5/Reset 1 -| |- 8 Vcc
42 | PB3 2 -| |- 7 PB2
43 | Out - PB4 3 -| |- 6 PB1
44 | GND 4 -|____|- 5 PB0 - Switch
45 |
46 |
47 | ATmega168P
48 | ----
49 | PC6/Reset 1 -| |- 28 PC5
50 | PD0/RxD 2 -| |- 27 PC4
51 | PD1/TxD 3 -| |- 26 PC3
52 | PD2 4 -| |- 25 PC2
53 | PD3 5 -| |- 24 PC1
54 | PD4 6 -| |- 23 PC0
55 | Vcc 7 -| |- 22 GND
56 | GND 8 -| |- 21 ARef
57 | PB6 9 -| |- 20 AVcc
58 | PB7 10 -| |- 19 PB5
59 | PD5 11 -| |- 18 PB4 - Out
60 | PD6 12 -| |- 17 PB3
61 | PD7 13 -| |- 16 PB2
62 | Switch - PB0 14 -|____|- 15 PB1
63 |
64 | */
65 |
66 | uint8_t flag0;
67 | uint8_t flag1;
68 | uint8_t flag2;
69 |
70 | uint16_t timer1;
71 | uint16_t timer2;
72 | uint16_t timer3;
73 |
74 | //**************************************************************************
75 |
76 | ISR(TIM0_COMPA_vect)
77 | {
78 | // Beginn des ersten Klicks
79 | if (SWITCH_ON && !flag1)
80 | {
81 | flag0 = 1; // Beginn des ersten Klicks erkannt
82 | timer1++; // Zähler für die Länge des ersten Klicks
83 | }
84 |
85 | if (flag0)
86 | {
87 | timer3++; // Zähler für die Gesamtlänge
88 | }
89 |
90 | // Ende des ersten Klicks
91 | if (SWITCH_OFF && !flag1 && (timer1 > MIN_PULSE_LEN) && (timer1 < MAX_PULSE_LEN1))
92 | {
93 | flag1 = 1; //Ende des ersten Klicks erkannt
94 | }
95 |
96 | // Beginn des zweiten Klicks
97 | if (SWITCH_ON && flag1)
98 | {
99 | flag2 = 1; // Beginn des zweiten Klicks erkannt
100 | timer2++; // Zähler für die Länge des zweiten Klicks
101 | }
102 |
103 | // Ende des zweiten Klicks
104 | if (SWITCH_OFF && flag1 && flag2 && (timer2 > MIN_PULSE_LEN) && (timer2 < MAX_PULSE_LEN2) && (timer3 < MAX_EVENT_LEN))
105 | {
106 | OUT_TOGGLE;
107 |
108 | flag0 = flag1 = flag2 = 0;
109 | timer1 = timer2 = timer3 = 0;
110 | }
111 |
112 | // Überprüfen auf Überlauf
113 | if (SWITCH_OFF && (timer3 >= MAX_EVENT_LEN))
114 | {
115 | flag0 = flag1 = flag2 = 0;
116 | timer1 = timer2 = timer3 = 0;
117 | }
118 | }
119 |
120 | //**************************************************************************
121 |
122 | void Timer0_Init(void)
123 | {
124 | TCCR0A = (1 << WGM00);
125 | TCCR0B = (0 << CS02) | (1 << CS01) | (1 << CS00); // prescaler 64
126 | OCR0A = (uint8_t)(F_CPU / (64.0 * 1e-3)); // 1 ms
127 | TIMSK0 = (1 << OCIE0A); // Interrupt für OCR aktivieren
128 | }
129 |
130 | //**************************************************************************
131 |
132 | int main(void)
133 | { GIMSK |= (1<<PCINT0);
134 | PORTB = 0;
135 | // Ausgänge definieren
136 | DDRB = (1 << DDB5) | (1 << DDB4) | (1 << DDB3) | (1 << DDB2) | (1 << DDB1);
137 |
138 | #if defined (__AVR_ATtiny13A__) || defined (__AVR_ATmega168__) || defined (__AVR_ATmega168P__)
139 | power_adc_disable();
140 | #endif
141 |
142 | flag0 = 0;
143 | flag1 = 0;
144 | flag2 = 0;
145 |
146 | timer1 = 0;
147 | timer2 = 0;
148 | timer3 = 0;
149 |
150 | Timer0_Init();
151 |
152 | sei(); // Interrupts aktivieren
153 |
154 | for(;;)
155 | {
156 | set_sleep_mode(SLEEP_MODE_IDLE);
157 | sleep_mode();
158 | }
159 |
160 | return 0; //nie erreicht
161 | }
