Moin Folgender Quelltext fragt eien AD Wandler ab. Nun ist aber das Problem das es immer mal wieder zu kommunikationsfehlern kommt bzw. der AD Wandler nicht angeschlossen ist. In diesem Fall hängt die Routine sich auf. Ich suche eine Lösung um nach ca. 2 sec. ohne Antwort die Messung abzubrechen. Da während der Messung die Interupts deaktiviert sind fällt der Timer interrupt leider aus. Kennt jemand eine andere/bessere Lösung ?
1 | uint32_t messung(uint8_t ch) |
2 | {
3 | cli(); |
4 | uint8_t address_w=0b11010000; |
5 | uint8_t address_r=0b11010001; |
6 | |
7 | uint8_t LowByte; |
8 | uint8_t HighByte; |
9 | |
10 | uint32_t out; |
11 | |
12 | _delay_ms(100); |
13 | |
14 | //OSR Register setzen
15 | |
16 | // send START condition
17 | TWCR = (1<<TWINT) | (1<<TWSTA) | (1<<TWEN); |
18 | while(!(TWCR & (1<<TWINT))); |
19 | // send device address
20 | TWDR = address_w; |
21 | TWCR = (1<<TWINT)| (1<<TWEN); |
22 | while(!(TWCR & (1<<TWINT))); |
23 | // send data
24 | switch (ch) |
25 | {
26 | case 1: |
27 | TWDR = 0x88; |
28 | break; |
29 | case 2: |
30 | TWDR = 0xA8; |
31 | break; |
32 | case 3: |
33 | TWDR = 0xC8; |
34 | break; |
35 | case 4: |
36 | TWDR = 0xE8; |
37 | break; |
38 | }
39 | TWCR = (1<<TWINT) | (1<<TWEN); |
40 | while(!(TWCR & (1<<TWINT))); |
41 | TWCR = (1<<TWINT) | (1<<TWEN) | (1<<TWSTO); //Stop |
42 | while((TWCR & (1<<TWINT))); |
43 | // send START condition
44 | TWCR = (1<<TWINT) | (1<<TWSTA) | (1<<TWEN); |
45 | while(!(TWCR & (1<<TWINT))); |
46 | // send device address
47 | TWDR = address_r; |
48 | TWCR = (1<<TWINT) | (1<<TWEN); |
49 | while(!(TWCR & (1<<TWINT))); |
50 | TWCR = (1<<TWINT) | (1<<TWEN) | (1<<TWEA); //Read and acknowledge |
51 | while(!(TWCR & (1<<TWINT))); |
52 | HighByte=TWDR; |
53 | TWCR = (1<<TWINT) | (1<<TWEN) | (1<<TWEA); //Read and acknowledge |
54 | while(!(TWCR & (1<<TWINT))); |
55 | LowByte=TWDR; |
56 | out = ( HighByte << 8 ) | LowByte; |
57 | TWCR = (1<<TWINT) | (1<<TWEN) | (1<<TWSTO); //Stop |
58 | while((TWCR & (1<<TWINT))); |
59 | sei(); |
60 | return out; |
61 | // return 23000;
62 | }
