1 | // Right now, PWM output only works on the pins with
2 | // hardware support. These are defined in the appropriate
3 | // pins_*.c file. For the rest of the pins, we default
4 | // to digital output.
5 | void analogWrite(uint8_t pin, int val)
6 | {
7 | // We need to make sure the PWM output is enabled for those pins
8 | // that support it, as we turn it off when digitally reading or
9 | // writing with them. Also, make sure the pin is in output mode
10 | // for consistenty with Wiring, which doesn't require a pinMode
11 | // call for the analog output pins.
12 | pinMode(pin, OUTPUT);
13 | if (val == 0)
14 | {
15 | digitalWrite(pin, LOW);
16 | }
17 | else if (val == 255)
18 | {
19 | digitalWrite(pin, HIGH);
20 | }
21 | else
22 | {
23 | switch(digitalPinToTimer(pin))
24 | {
25 | // XXX fix needed for atmega8
26 | #if defined(TCCR0) && defined(COM00) && !defined(__AVR_ATmega8__)
27 | case TIMER0A:
28 | // connect pwm to pin on timer 0
29 | sbi(TCCR0, COM00);
30 | OCR0 = val; // set pwm duty
31 | break;
32 | #endif
33 |
34 | #if defined(TCCR0A) && defined(COM0A1)
35 | case TIMER0A:
36 | // connect pwm to pin on timer 0, channel A
37 | sbi(TCCR0A, COM0A1);
38 | OCR0A = val; // set pwm duty
39 | break;
40 | #endif
41 |
42 | #if defined(TCCR0A) && defined(COM0B1)
43 | case TIMER0B:
44 | // connect pwm to pin on timer 0, channel B
45 | sbi(TCCR0A, COM0B1);
46 | OCR0B = val; // set pwm duty
47 | break;
48 | #endif
49 |
50 | #if defined(TCCR1A) && defined(COM1A1)
51 | case TIMER1A:
52 | // connect pwm to pin on timer 1, channel A
53 | sbi(TCCR1A, COM1A1);
54 | OCR1A = val; // set pwm duty
55 | break;
56 | #endif
57 |
58 | #if defined(TCCR1A) && defined(COM1B1)
59 | case TIMER1B:
60 | // connect pwm to pin on timer 1, channel B
61 | sbi(TCCR1A, COM1B1);
62 | OCR1B = val; // set pwm duty
63 | break;
64 | #endif
65 |
66 | #if defined(TCCR1A) && defined(COM1C1)
67 | case TIMER1C:
68 | // connect pwm to pin on timer 1, channel B
69 | sbi(TCCR1A, COM1C1);
70 | OCR1C = val; // set pwm duty
71 | break;
72 | #endif
73 |
74 | #if defined(TCCR2) && defined(COM21)
75 | case TIMER2:
76 | // connect pwm to pin on timer 2
77 | sbi(TCCR2, COM21);
78 | OCR2 = val; // set pwm duty
79 | break;
80 | #endif
81 |
82 | #if defined(TCCR2A) && defined(COM2A1)
83 | case TIMER2A:
84 | // connect pwm to pin on timer 2, channel A
85 | sbi(TCCR2A, COM2A1);
86 | OCR2A = val; // set pwm duty
87 | break;
88 | #endif
89 |
90 | #if defined(TCCR2A) && defined(COM2B1)
91 | case TIMER2B:
92 | // connect pwm to pin on timer 2, channel B
93 | sbi(TCCR2A, COM2B1);
94 | OCR2B = val; // set pwm duty
95 | break;
96 | #endif
97 |
98 | #if defined(TCCR3A) && defined(COM3A1)
99 | case TIMER3A:
100 | // connect pwm to pin on timer 3, channel A
101 | sbi(TCCR3A, COM3A1);
102 | OCR3A = val; // set pwm duty
103 | break;
104 | #endif
105 |
106 | #if defined(TCCR3A) && defined(COM3B1)
107 | case TIMER3B:
108 | // connect pwm to pin on timer 3, channel B
109 | sbi(TCCR3A, COM3B1);
110 | OCR3B = val; // set pwm duty
111 | break;
112 | #endif
113 |
114 | #if defined(TCCR3A) && defined(COM3C1)
115 | case TIMER3C:
116 | // connect pwm to pin on timer 3, channel C
117 | sbi(TCCR3A, COM3C1);
118 | OCR3C = val; // set pwm duty
119 | break;
120 | #endif
121 |
122 | #if defined(TCCR4A)
123 | case TIMER4A:
124 | //connect pwm to pin on timer 4, channel A
125 | sbi(TCCR4A, COM4A1);
126 | #if defined(COM4A0) // only used on 32U4
127 | cbi(TCCR4A, COM4A0);
128 | #endif
129 | OCR4A = val; // set pwm duty
130 | break;
131 | #endif
132 |
133 | #if defined(TCCR4A) && defined(COM4B1)
134 | case TIMER4B:
135 | // connect pwm to pin on timer 4, channel B
136 | sbi(TCCR4A, COM4B1);
137 | OCR4B = val; // set pwm duty
138 | break;
139 | #endif
140 |
141 | #if defined(TCCR4A) && defined(COM4C1)
142 | case TIMER4C:
143 | // connect pwm to pin on timer 4, channel C
144 | sbi(TCCR4A, COM4C1);
145 | OCR4C = val; // set pwm duty
146 | break;
147 | #endif
148 |
149 | #if defined(TCCR4C) && defined(COM4D1)
150 | case TIMER4D:
151 | // connect pwm to pin on timer 4, channel D
152 | sbi(TCCR4C, COM4D1);
153 | #if defined(COM4D0) // only used on 32U4
154 | cbi(TCCR4C, COM4D0);
155 | #endif
156 | OCR4D = val; // set pwm duty
157 | break;
158 | #endif
159 |
160 |
161 | #if defined(TCCR5A) && defined(COM5A1)
162 | case TIMER5A:
163 | // connect pwm to pin on timer 5, channel A
164 | sbi(TCCR5A, COM5A1);
165 | OCR5A = val; // set pwm duty
166 | break;
167 | #endif
168 |
169 | #if defined(TCCR5A) && defined(COM5B1)
170 | case TIMER5B:
171 | // connect pwm to pin on timer 5, channel B
172 | sbi(TCCR5A, COM5B1);
173 | OCR5B = val; // set pwm duty
174 | break;
175 | #endif
176 |
177 | #if defined(TCCR5A) && defined(COM5C1)
178 | case TIMER5C:
179 | // connect pwm to pin on timer 5, channel C
180 | sbi(TCCR5A, COM5C1);
181 | OCR5C = val; // set pwm duty
182 | break;
183 | #endif
184 |
185 | case NOT_ON_TIMER:
186 | default:
187 | if (val < 128) {
188 | digitalWrite(pin, LOW);
189 | } else {
190 | digitalWrite(pin, HIGH);
191 | }
192 | }
193 | }
194 | }
