Hi, I am relatively new to STM32 but already did a project with STMs Timers DMA... About the project: this STM32F103C8 chould handle 3 UART (not USART) ports with communication on 20Hz basis. Furthermore control a gear motor with a relay for direction and FET and PWM for speed. A PID should control the speed based on velocity from encoder. To compute the speed I want to get and 40Hz interrupt from Timer1 as all the other timers are busy. So as the clock is 72Mhz I set prescalar to 1800 and period to 1000. But when I look at the Interrupt calls with my Ozi, i get a much lower speed about 0,26 Hz. So I searched the net how this could be and eventually encovered, that there might be interference with UART1. So the odd part comes now: When I out comment the UART1 initialization (USART_Cmd) the frequency doubles to about 0,5Hz After adding comments to USART_DMACmd the frequency jumps to 0,18Hz... After 3 hours of searching and debugging I don't know what to do. Can anybody tell me what I am doing wrong here? Thanks in advance Noah Source code (PID not finished yet)
...Priority = 0x0F; Sets the lowest Priority for the Timers.
Hi, me once again. After another 2 hours of testing the UART :( I eventually figured out what the problem was. So for any other newbie how runs in this issue: After reading the datasheet another time I figured out, that TIM1 in comparision to TIM2 - 4 has a RepetitionCounter - which I didn't set. So the right initialization would be
1 | TIM_TimeBase_InitStructure.TIM_ClockDivision = TIM_CKD_DIV1; |
2 | TIM_TimeBase_InitStructure.TIM_CounterMode = TIM_CounterMode_Up; |
3 | TIM_TimeBase_InitStructure.TIM_Period = 999; |
4 | TIM_TimeBase_InitStructure.TIM_Prescaler = 1799; |
5 | TIM_TimeBase_InitStructure.TIM_RepetitionCounter = 0; |
6 | TIM_TimeBaseInit(TIM1, &TIM_TimeBase_InitStructure); |
My explanation for the strange behaviour with UART1 is that TIM_TimeBase_InitStructure is local and therefore on the stack or so. As RepetitionCounter never gets assigned it is what was at the stack before. This varys from the before function calls and their variables. So it has nothing to do with UART1, except that its initialization function was the last I called before Timer initialization... Hope I can prevent future confussions. Happy coding Noah PS.: @pegel you are right. But I'm not into this priority stuff right know. And therefore every interrupt gets the same priority... the lowest. My Motor is running smoothly now, though. And interrupt is very exact at 25ms so I don't care yet.
Noah schrieb: > I am relatively new to STM32 but already did a project with STMs Timers > DMA... So you are new to STM32 or to ARM-CORTEX in general? But the very first thing you do is trying to use DMA. And when I see the following:
1 | void USARTIRQHandler(void) |
2 | {
3 | /* RXNE handler */
4 | if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) |
5 | {
6 | /* If received 't', toggle LED and transmit 'T' */
7 | if((char)USART_ReceiveData(USART1) == 't') |
8 | {
9 | USART_SendData(USART1, 'T'); |
10 | /* Wait until Tx data register is empty, not really |
11 | * required for this example but put in here anyway. |
I become angry. You really wait inside a interrupt handler? A rather long time ago I posted here a little project with this STM32F103 and there you can see, how to handle all UART's and the USB-VCP without any DMA. And how to write a firmware, which does not wait inside of interrupt handlers. W.S.
