1 | C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v2 -PCOM3 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
2 |
3 | avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
4 | Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
5 | Copyright (c) 2007-2014 Joerg Wunsch
6 |
7 | System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
8 |
9 | Using Port : COM3
10 | Using Programmer : stk500v2
11 | AVR Part : ATmega328P
12 | Chip Erase delay : 9000 us
13 | PAGEL : PD7
14 | BS2 : PC2
15 | RESET disposition : dedicated
16 | RETRY pulse : SCK
17 | serial program mode : yes
18 | parallel program mode : yes
19 | Timeout : 200
20 | StabDelay : 100
21 | CmdexeDelay : 25
22 | SyncLoops : 32
23 | ByteDelay : 0
24 | PollIndex : 3
25 | PollValue : 0x53
26 | Memory Detail :
27 |
28 | Block Poll Page Polled
29 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
30 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------
31 | eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
32 | flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
33 | lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
34 | hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
35 | efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
36 | lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
37 | calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
38 | signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
39 |
40 | Programmer Type : STK500V2
41 | Description : Atmel STK500 Version 2.x firmware
42 | Programmer Model: STK500
43 | Hardware Version: 10
44 | Firmware Version Master : 2.10
45 | avrdude: stk500v2_command(): command failed
46 | avrdude: stk500v2_getparm(): failed to get parameter 0x9a
47 | Topcard : Unknown
48 | Vtarget : 5.0 V
49 | avrdude: stk500v2_command(): command failed
50 | avrdude: stk500v2_getparm(): failed to get parameter 0x95
51 | avrdude: stk500v2_command(): command failed
52 | avrdude: stk500v2_getparm(): failed to get parameter 0x96
53 | avrdude: stk500v2_command(): command failed
54 | avrdude: stk500v2_getparm(): failed to get parameter 0x97
55 | SCK period : 17.4 us
56 | Varef : 6.4 V
57 | Oscillator : 36.864 kHz
58 |
59 | avrdude: stk500v2_command(): command failed
60 | avrdude: initialization failed, rc=-1
61 | Double check connections and try again, or use -F to override
62 | this check.
63 |
64 |
65 | avrdude done. Thank you.
66 |
67 | Fehler beim Brennen des Bootloaders.
