Hallo an Alle, habe noch zwei Decision I/O Cards gefunden die ich nicht benötige, die ISA-Card war mal in einem Lungentest-Gerät in Betrieb. Die Karten sollten funktionieren, testen kann ich Sie Aufgrund mangelnder Hardware nicht. Es handelt sich um eine: Bus: 32-Bit PCI Bus PnP Assembly: 2 x 8255 (OKI-M82C55A-2) + 1 x 8254 (OKI M82C54-2 ) Connection: 2 x 40-Pin IDC Features: Programmable I/O control functions Up to 48 I/O lines TTL - 5V Three independent 16 bits counter Sixteen LED indicate when I/O is operating Provides DII device driver for PnP features ISA 8255N compatibly Englisch manual with configuration and Pin Assignment. Software/Driver: Windows-98/NT/2000/XP, Vista, WIN-7/WIN-8, Linux and DOS driver or sample for programming. Per shipping you receive freshly burned „Decision Computer Germany service CD“ with current drivers, manuals, installation guidances and German additional information. The extent depends on the product! Produktcode Taiwan: APCI8255 Label on board: PCI 8255 - DCI98120406 Size: 160 mm x 90 mm Und eine: Bus: ISA 8-Bit The 8255 I/O card is a programmable peripheral interface for PC/XT, PC/AT, 80386, 80486 or compatible. The interface card contains 8254 chip and 8255 chips, the 8254 chip provides programmable interval timer/counter function, and the 8255 chips provide programmable input/output functions. 2 x 8255 (OKI-M82C55A-2) - 1 x 8254 (OKI M82C54-2) 6 I/O Ports - 8 lines each Programmable l/O control functions Up to 48 I/O lines. TTL - 5V Three independent 16 bits counter. Connection with IDC-40-pin Optionally available :DB-37 adapter (ADAP37). Port address selectable. H1BO + H1FO (H300 + H360 special order) Software/Driver: German bulk manual and English manual with adjusting plan, terminal diagram, data sheets and sample programs Windows-98/NT/2000/XP, Linux, DOS driver or info Per shipping you receive freshly burned „Decision Computer Germany service CD“ with current drivers, manuals, installation guidances and German additional information. The extent depends on the product! Für die ISA Variante ist eine Selbstgebaute Taktgeber Platine mit 2MhZ dabei, leider habe ich für die ISA-Variante keine Doku und Software mehr. Die PCI-Variante ist Neu und ungebraucht sowie mit Doku und CDs. Dachte als Preis an 30€ Plus Versand für die ISA-Variante. Und 75€ für die PCI-Variante Plus Versand.
Hallo an Alle, liegt es den Karten? oder am Preis? das keiner Interesse hat? Gruß Stefan
Ich würde sagen teils teils.. Die ISA Karte kann kaum einer noch verwenden weil es die Slots in keinem noch laufenden Rechner gibt, und die PCI Karte wäre mir selbst höchstens einen 10er wert, selbst die Slots dafür sind heute unüblich. Ich wundere mich deshalb also nicht... Gruß, Holm
Stefan A. schrieb: > Hallo an Alle, > > liegt es den Karten? oder am Preis? das keiner Interesse hat? > > Gruß Stefan Was glaubst du denn, was für Schätze du da rumliegen hast? Verschenke die gegen Portoerstattung. Vielleicht kann sie ja noch jemand zum Ausschlachten gebrauchen. Oder entsorge das alte Gelumpe selbst.
Hallo holm, ja das war mir schon bewusst das die Schnittstellen nicht mehr so aktuell sind. Da es aber keine Bastler-Karten sind und diese selbst von mir in Lungenmessgeräten eingesetzt wurden und ich weiß das Arztpraxen nicht ständig Neue Geräte ordern dachte ich die könnte noch jemand für einen solchen Einsatz z.B. als Ersatzgerät benötigen. Hallo Thomas, klasse Hinweis, aber dann entsorge ich Sie lieber selbst auf einer anderen Plattform! Schönen 1. Advent an Alle
