1 | /* ===-- udivmoddi6.c - Implement __udivmoddi4 -----------------------------===
2 | *
3 | * The LLVM Compiler Infrastructure
4 | *
5 | * This file is dual licensed under the MIT and the University of Illinois Open
6 | * Source Licenses. See LICENSE.TXT for details.
7 | *
8 | * ===----------------------------------------------------------------------===
9 | *
10 | * This file implements __udivmoddi4 for the compiler_rt library.
11 | *
12 | * ===----------------------------------------------------------------------===
13 | */
14 |
15 | #include "int_lib.h"
16 |
17 | /* Effects: if rem != 0, *rem = a % b
18 | * Returns: a / b
19 | */
20 |
21 | /* Translated from Figure 3-40 of The PowerPC Compiler Writer's Guide */
22 |
23 | COMPILER_RT_ABI du_int
24 | __udivmoddi4(du_int a, du_int b, du_int* rem)
25 | {
26 | const unsigned n_uword_bits = sizeof(su_int) * CHAR_BIT;
27 | const unsigned n_udword_bits = sizeof(du_int) * CHAR_BIT;
28 | udwords n;
29 | n.all = a;
30 | udwords d;
31 | d.all = b;
32 | udwords q;
33 | udwords r;
34 | unsigned sr;
35 | /* special cases, X is unknown, K != 0 */
36 | if (n.s.high == 0)
37 | {
38 | if (d.s.high == 0)
39 | {
40 | /* 0 X
41 | * ---
42 | * 0 X
43 | */
44 | if (rem)
45 | *rem = n.s.low % d.s.low;
46 | return n.s.low / d.s.low;
47 | }
48 | /* 0 X
49 | * ---
50 | * K X
51 | */
52 | if (rem)
53 | *rem = n.s.low;
54 | return 0;
55 | }
56 | /* n.s.high != 0 */
57 | if (d.s.low == 0)
58 | {
59 | if (d.s.high == 0)
60 | {
61 | /* K X
62 | * ---
63 | * 0 0
64 | */
65 | if (rem)
66 | *rem = n.s.high % d.s.low;
67 | return n.s.high / d.s.low;
68 | }
69 | /* d.s.high != 0 */
70 | if (n.s.low == 0)
71 | {
72 | /* K 0
73 | * ---
74 | * K 0
75 | */
76 | if (rem)
77 | {
78 | r.s.high = n.s.high % d.s.high;
79 | r.s.low = 0;
80 | *rem = r.all;
81 | }
82 | return n.s.high / d.s.high;
83 | }
84 | /* K K
85 | * ---
86 | * K 0
87 | */
88 | if ((d.s.high & (d.s.high - 1)) == 0) /* if d is a power of 2 */
89 | {
90 | if (rem)
91 | {
92 | r.s.low = n.s.low;
93 | r.s.high = n.s.high & (d.s.high - 1);
94 | *rem = r.all;
95 | }
96 | return n.s.high >> __builtin_ctz(d.s.high);
97 | }
98 | /* K K
99 | * ---
100 | * K 0
101 | */
102 | sr = __builtin_clz(d.s.high) - __builtin_clz(n.s.high);
103 | /* 0 <= sr <= n_uword_bits - 2 or sr large */
104 | if (sr > n_uword_bits - 2)
105 | {
106 | if (rem)
107 | *rem = n.all;
108 | return 0;
109 | }
110 | ++sr;
111 | /* 1 <= sr <= n_uword_bits - 1 */
112 | /* q.all = n.all << (n_udword_bits - sr); */
113 | q.s.low = 0;
114 | q.s.high = n.s.low << (n_uword_bits - sr);
115 | /* r.all = n.all >> sr; */
116 | r.s.high = n.s.high >> sr;
117 | r.s.low = (n.s.high << (n_uword_bits - sr)) | (n.s.low >> sr);
118 | }
119 | else /* d.s.low != 0 */
120 | {
121 | if (d.s.high == 0)
122 | {
123 | /* K X
124 | * ---
125 | * 0 K
126 | */
127 | if ((d.s.low & (d.s.low - 1)) == 0) /* if d is a power of 2 */
128 | {
129 | if (rem)
130 | *rem = n.s.low & (d.s.low - 1);
131 | if (d.s.low == 1)
132 | return n.all;
133 | sr = __builtin_ctz(d.s.low);
134 | q.s.high = n.s.high >> sr;
135 | q.s.low = (n.s.high << (n_uword_bits - sr)) | (n.s.low >> sr);
136 | return q.all;
137 | }
138 | /* K X
139 | * ---
140 | * 0 K
141 | */
142 | sr = 1 + n_uword_bits + __builtin_clz(d.s.low) - __builtin_clz(n.s.high);
143 | /* 2 <= sr <= n_udword_bits - 1
144 | * q.all = n.all << (n_udword_bits - sr);
145 | * r.all = n.all >> sr;
146 | */
147 | if (sr == n_uword_bits)
148 | {
149 | q.s.low = 0;
150 | q.s.high = n.s.low;
151 | r.s.high = 0;
152 | r.s.low = n.s.high;
153 | }
154 | else if (sr < n_uword_bits) // 2 <= sr <= n_uword_bits - 1
155 | {
156 | q.s.low = 0;
157 | q.s.high = n.s.low << (n_uword_bits - sr);
158 | r.s.high = n.s.high >> sr;
159 | r.s.low = (n.s.high << (n_uword_bits - sr)) | (n.s.low >> sr);
160 | }
161 | else // n_uword_bits + 1 <= sr <= n_udword_bits - 1
162 | {
163 | q.s.low = n.s.low << (n_udword_bits - sr);
164 | q.s.high = (n.s.high << (n_udword_bits - sr)) |
165 | (n.s.low >> (sr - n_uword_bits));
166 | r.s.high = 0;
167 | r.s.low = n.s.high >> (sr - n_uword_bits);
168 | }
169 | }
170 | else
171 | {
172 | /* K X
173 | * ---
174 | * K K
175 | */
176 | sr = __builtin_clz(d.s.high) - __builtin_clz(n.s.high);
177 | /* 0 <= sr <= n_uword_bits - 1 or sr large */
178 | if (sr > n_uword_bits - 1)
179 | {
180 | if (rem)
181 | *rem = n.all;
182 | return 0;
183 | }
184 | ++sr;
185 | /* 1 <= sr <= n_uword_bits */
186 | /* q.all = n.all << (n_udword_bits - sr); */
187 | q.s.low = 0;
188 | if (sr == n_uword_bits)
189 | {
190 | q.s.high = n.s.low;
191 | r.s.high = 0;
192 | r.s.low = n.s.high;
193 | }
194 | else
195 | {
196 | q.s.high = n.s.low << (n_uword_bits - sr);
197 | r.s.high = n.s.high >> sr;
198 | r.s.low = (n.s.high << (n_uword_bits - sr)) | (n.s.low >> sr);
199 | }
200 | }
201 | }
202 | /* Not a special case
203 | * q and r are initialized with:
204 | * q.all = n.all << (n_udword_bits - sr);
205 | * r.all = n.all >> sr;
206 | * 1 <= sr <= n_udword_bits - 1
207 | */
208 | su_int carry = 0;
209 | for (; sr > 0; --sr)
210 | {
211 | /* r:q = ((r:q) << 1) | carry */
212 | r.s.high = (r.s.high << 1) | (r.s.low >> (n_uword_bits - 1));
213 | r.s.low = (r.s.low << 1) | (q.s.high >> (n_uword_bits - 1));
214 | q.s.high = (q.s.high << 1) | (q.s.low >> (n_uword_bits - 1));
215 | q.s.low = (q.s.low << 1) | carry;
216 | /* carry = 0;
217 | * if (r.all >= d.all)
218 | * {
219 | * r.all -= d.all;
220 | * carry = 1;
221 | * }
222 | */
223 | const di_int s = (di_int)(d.all - r.all - 1) >> (n_udword_bits - 1);
224 | carry = s & 1;
225 | r.all -= d.all & s;
226 | }
227 | q.all = (q.all << 1) | carry;
228 | if (rem)
229 | *rem = r.all;
230 | return q.all;
231 | }
