ESP8266 MQTT client über access Point
Gast #5328309
Seite 42 welcher Anleitung?
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
//const char* ssid = "........";
//const char* password = "........";
//const char* ssid = ".......";
//const char* ssid = "....."; //replace this with your WiFi network name
//const char* password = "......"; //replace this with your WiFi network password
const char* ssid = "......";
const char* mqtt_server = "192.xxx.xxx.xxx";
WiFiClient espClient;
PubSubClient client(espClient);
23
24
long lastMsg = 0;
25
char msg[50];
26
int value = 0;
27
28
void setup_wifi()
29
30
  delay(10);
31
  // We start by connecting to a WiFi network
32
  Serial.println();
33
  Serial.print("Connecting to ");
34
  Serial.println(ssid);
35
36
  WiFi.begin(ssid, password);
37
38
  while (WiFi.status() != WL_CONNECTED)
39
40
    delay(500);
41
    Serial.print(".");
42
43
44
  randomSeed(micros());
45
46
  Serial.println("");
47
48
49
  Serial.println("Connected.");
50
  Serial.print("MAC: ");
51
  Serial.println(WiFi.macAddress());
52
  Serial.print("IP:  ");
53
  Serial.println(WiFi.localIP());
54
  Serial.print("Subnet: ");
55
  Serial.println(WiFi.subnetMask());
56
  Serial.print("Gateway :");
57
  Serial.println(WiFi.gatewayIP());
58
  Serial.print("DNS: ");
59
  Serial.println(WiFi.dnsIP());
60
  Serial.print("Channel: ");
61
  Serial.println(WiFi.channel());
62
  Serial.print("Status: ");
63
  Serial.println(WiFi.status());
64
65
66
67
68
void callback(char* topic, byte* payload, unsigned int length)
69
70
  Serial.print("Message arrived [");
71
  Serial.print(topic);
72
  Serial.print("] ");
73
  for (int i = 0; i < length; i++)
74
75
    Serial.print((char)payload[i]);
76
77
  Serial.println();
78
79
  // Switch on the LED if an 1 was received as first character
80
  if ((char)payload[0] == '1')
81
82
    digitalWrite(2, LOW);   // Turn the LED on (Note that LOW is the voltage level
83
    // but actually the LED is on; this is because
84
    // it is acive low on the ESP-01)
85
  } else
86
87
    digitalWrite(2, HIGH);  // Turn the LED off by making the voltage HIGH
88
89
90
91
void reconnect()
92
93
  // Loop until we're reconnected
94
  while (!client.connected())
95
96
    Serial.print("Attempting MQTT connection...");
97
    // Create a random client ID
98
    String clientId = "ESP8266Client-";
99
    clientId += String(random(0xffff), HEX);
100
    // Attempt to connect
101
    if (client.connect(clientId.c_str(),"openhabian","mqtt"))
102
103
      Serial.println("connected");
104
      // Once connected, publish an announcement...
105
      client.publish("outTopic", "hello world");
106
      // ... and resubscribe
107
      client.subscribe("inTopic");
108
109
    else
110
111
      Serial.print("failed, rc=");
112
      Serial.print(client.state());
113
      Serial.println(" try again in 5 seconds");
114
      // Wait 5 seconds before retrying
115
      delay(5000);
116
117
118
119
120
void setup()
121
122
  pinMode(2, OUTPUT);     // Initialize the BUILTIN_LED pin as an output
123
  Serial.begin(115200);
124
  setup_wifi();
125
126
  client.setServer(mqtt_server, 1883);
127
  client.setCallback(callback);
128
129
130
void loop()
131
132
  if (!client.connected())
133
134
    reconnect();
135
136
  client.loop();
137
138
  long now = millis();
139
  if (now - lastMsg > 2000)
140
141
    lastMsg = now;
142
    ++value;
143
    snprintf (msg, 75, "hello world #%ld", value);
144
    Serial.print("Publish message: ");
145
    Serial.println(msg);
146
    client.publish("outTopic", msg);
147
148
Das Netzwerk ist so aufgebaut:
          ,- PC1
Fritzbox -|- Pc2
          '- TP Link Nano(als Access Point)--> ESP8266
          '- RaspberryPi(Mqtt Server)
Ich danke euch schon mal für den Versuch mir zu helfen.
Grüße Lars
Gast #5328328
Dann ist dein AP entweder nicht zum ESP8266 kompatibel oder falsch
konfiguriert.
Kannst du den MQTT Broker überhaupt über das WLAN Netz des TP-Link
Routers erreichen? Hast du das mal mit einem anderen gerät (Laptop oder
Smartphone) versucht?
Kann dein ESP8266 denn andere lokale Server oder das Internet erreichen?
Wird dem ESP8266 denn das richtige Gateway (in diesem Fall der TP-Link
Router) zugewiesen?
