Hallo, Mir wurde eben über den "Voltage Detector" MAX6376 berichtet. Wenn ich das richtig verstanden habe, ist dieses Bauteil ja nur ein "prellen unterdrücker" ? Beziehungsweise ist der OUTPUT solange auf High wenn der Input eine gewisse Thresholdspannung unterschreitet. (Datenblatt S3) Oder wird es auch zur Strombegrenzung verwendet, wenn zbsp der Input an einem Mikrocontroller Output verwendet wird ? lG Marcel
Hallo Marcel, was steht denn im Datenblatt? Es wird zwar verlinkt, aber hier ist das Datenblatt vom Anbieter: https://datasheets.maximintegrated.com/en/ds/MAX6375-MAX6380.pdf Auf der ersten Seite liest man: General Description The MAX6375–MAX6380 are ultra-low-power circuits used for monitoring battery, power-supply, and regulated system voltages. Each detector contains a precision bandgap reference, comparator, and internally trimmed resistors that set specified trip threshold voltages. These devices provide excellent circuit reliability and low cost by eliminating external components and adjustments when monitoring nominal system voltages from 2.5V to 5V. These circuits perform a single function: they assert an output signal whenever the VCC supply voltage falls below a preset threshold. The devices are differentiated by their output logic configurations and preset threshold voltages. The MAX6375/MAX6378 (push-pull) and MAX6377/MAX6380 (open-drain) have an active-low output (OUT is logic low when VCC is below VTH). The MAX6376/MAX6379 have an active-high push-pull output (OUT is logic high when VCC is below VTH). All parts are guaranteed to be in the correct output logic state for VCC down to 1V. The detector is designed to ignore fast transients on VCC. The MAX6375/MAX6376/ MAX6377 have voltage thresholds between 2.20V and 3.08V in approximately 100mV increments. The MAX6378/MAX6379/MAX6380 have voltage thresholds between 3.30V and 4.63V in approximately 100mV increments. Applications Precision Battery Monitoring Load Switching/Power Sequencing Power-Supply Monitoring in Digital/Analog Systems Portable/Battery-Powered Equipment Na wenn das nichts ist!
Karl M. schrieb: > These circuits perform a single function: they assert an output signal > whenever the VCC supply voltage falls below a preset threshold. The > devices are differentiated by their output logic configurations and > preset threshold voltages. Ja. Jedoch liegt bei mir am Output immer Low an, egal ob am Input High oder Low anliegt. Das sollte nicht so sein.
Kevin / Marcel, einigt Euch, wie Ihr heißt.
1 | Ebenso nicht erlaubt ist: |
2 | |
3 | ... |
4 | Beteiligung an einer Diskussion unter verschiedenen Namen |
https://www.mikrocontroller.net/user/conditions
