1 | pi@JojosRPi3-1:~ $ node-red-start
2 |
3 | Node-RED is not yet fully installed
4 |
5 | Fetching Node-RED update.
6 |
7 |
8 | This script will remove versions of Node.js prior to version 6.x, and Node-RED and
9 | if necessary replace them with Node.js 8.x LTS (carbon) and the latest Node-RED from Npm.
10 |
11 | It also moves any Node-RED nodes that are globally installed into your user
12 | ~/.node-red/node_modules directory, and adds them to your package.json, so that
13 | you can manage them with the palette manager.
14 |
15 | It also tries to run 'npm rebuild' to refresh any extra nodes you have installed
16 | that may have a native binary component. While this normally works ok, you need
17 | to check that it succeeds for your combination of installed nodes.
18 |
19 | To do all this it runs commands as root - please satisfy yourself that this will
20 | not damage your Pi, or otherwise compromise your configuration.
21 | If in doubt please backup your SD card first.
22 |
23 | Are you really sure you want to do this ? [y/N] ? y
24 |
25 |
26 | Running Node-RED update for user pi at /home/pi
27 |
28 | This can take 20-30 minutes on the slower Pi versions - please wait.
29 |
30 | Stop Node-RED ✔
31 | Remove old version of Node-RED ✔
32 | Remove old version of Node.js -
33 | Update Node.js LTS ✔ Node v9.7.1 Npm 5.6.0
34 | Clean npm cache ✔
35 | Install Node-RED core ✔ 0.18.7
36 | Move global nodes to local -
37 | Install extra Pi nodes -
38 | Npm rebuild existing nodes ✔
39 | Add menu shortcut ✔
40 | Update systemd script ✔
41 | id=Node-RED.desktop
42 | Update update script ✔
43 | Any errors will be logged to /var/log/nodered-install.log
44 |
45 |
46 | All done.
47 | You can now start Node-RED with the command node-red-start
48 | or using the icon under Menu / Programming / Node-RED
49 | Then point your browser to localhost:1880 or http://{your_pi_ip-address}:1880
50 |
51 | Started Fr 6. Jul 18:57:57 CEST 2018 - Finished Fr 6. Jul 19:00:35 CEST 2018
52 |
53 | Would you like to start Node-RED now (y/N) ? y
54 |
55 | Node-RED is not yet fully installed
56 |
57 | Fetching Node-RED update.
