1 | #include <SPI.h>
2 | #include <TFT_ILI9163C.h>
3 | #include <PID_v1.h>
4 | #include <EEPROM.h>
5 | #include "TimerOne.h"
6 | #include "definitions.h"
7 |
8 |
9 | /*
10 | * If your display stays white, uncomment this.
11 | * Cut reset trace (on THT on upper layer/0R), connect STBY_NO (A1) with reset of TFT (at 4050).
12 | * See also readme in mechanical folder for reference.
13 | */
14 | //#define USE_TFT_RESET
15 |
16 | /*
17 | * If red is blue and blue is red change this
18 | * If not sure, leave commented, you will be shown a setup screen
19 | */
20 | //#define HARDWARE_DEFINED_TFT 2
21 | /*
22 | * Based on your Hardware-Revision there may be modifications to the PCB.
23 | * In V3 and up is a second voltage measurement circuit.
24 | * HW REVS:
25 | * 1.5 - 2.8:
26 | * For THT this should be set to anything < 3
27 | * Normally leave this commented as it is stored in EEPROM
28 | */
29 |
30 | // V 1.5 - 2.11, Maiskolben THT
31 | //#define HARDWARE_REVISION 2
32 | // V 3.0 and 3.1
33 | //#define HARDWARE_REVISION 3
34 |
35 | /*
36 | * Only used for testing, do not use.
37 | */
38 | //#define INSTALL
39 | //#define TEST_ADC
40 |
41 | volatile boolean off = true, stby = true, stby_layoff = false, sw_stby_old = false, sw_up_old = false, sw_down_old = false, clear_display = true, store_invalid = true, menu = false;
42 | volatile uint8_t pwm, threshold_counter;
43 | volatile int16_t cur_t, last_measured;
44 |
45 |
46 | int16_t stored[3] = {300, 350, 450}, set_t = TEMP_MIN, set_t_old, cur_t_old, target_t;
47 | double pid_val, cur_td, set_td;
48 | uint8_t store_to = 255;
49 | p_source power_source, power_source_old = NO_INIT;
50 | boolean blink;
51 | uint16_t cnt_measure_voltage, cnt_compute, cnt_sw_poll, cnt_but_press, cnt_off_press, cnt_but_store;
52 | float v_c1, v_c2, v_c3, v_in, v;
53 | uint8_t array_index, array_count;
54 | uint32_t sendNext;
55 | uint32_t last_temperature_drop;
56 | uint32_t last_on_state;
57 | boolean wasOff = true, old_stby = false;
58 | boolean autopower = true, bootheat = false, fahrenheit = false;
59 | uint8_t revision = 1;
60 | boolean menu_dismissed = false;
61 | boolean autopower_repeat_under = false;
62 | boolean force_redraw = false;
63 | boolean power_down = false;
64 | uint16_t charge = 0;
65 | float adc_offset = ADC_TO_TEMP_OFFSET;
66 | float adc_gain = ADC_TO_TEMP_GAIN;
67 |
68 | #define RGB_DISP 0x0
69 | #define BGR_DISP 0x2
70 |
71 | #ifdef USE_TFT_RESET
72 | TFT_ILI9163C tft = TFT_ILI9163C(TFT_CS, TFT_DC, STBY_NO);
73 | #else
74 | TFT_ILI9163C tft = TFT_ILI9163C(TFT_CS, TFT_DC);
75 | #endif
76 | #define BLACK 0x0000
77 | #define BLUE 0x001F
78 | #define RED 0xF800
79 | #define GREEN 0x07E0
80 | #define CYAN 0x07FF
81 | #define MAGENTA 0xF81F
82 | #define YELLOW 0xFFE0
83 | #define WHITE 0xFFFF
84 | #define GRAY 0x94B2
85 |
86 | PID heaterPID(&cur_td, &pid_val, &set_td, kp, ki, kd, DIRECT);
87 |
88 | void setup(void) {
89 | digitalWrite(HEATER_PWM, LOW);
90 | pinMode(HEATER_PWM, OUTPUT);
91 | pinMode(POWER, INPUT_PULLUP);
92 | pinMode(HEAT_LED, OUTPUT);
93 | digitalWrite(HEAT_LED, HIGH);
94 | pinMode(TEMP_SENSE, INPUT);
95 | pinMode(SW_T1, INPUT_PULLUP);
96 | pinMode(SW_T2, INPUT_PULLUP);
97 | pinMode(SW_T3, INPUT_PULLUP);
98 | pinMode(SW_UP, INPUT_PULLUP);
99 | pinMode(SW_DOWN, INPUT_PULLUP);
100 | pinMode(STBY_NO, INPUT_PULLUP);
101 | pinMode(SW_STBY, INPUT_PULLUP);
102 | pinMode(TFT_CS, OUTPUT);
103 | digitalWrite(TFT_CS, HIGH);
104 | Serial.begin(115200);
105 |
106 | boolean force_menu = false;
107 | if (EEPROM.read(0) != EEPROM_CHECK) {
108 | EEPROM.update(0, EEPROM_CHECK);
109 | updateEEPROM();
110 | force_menu = true;
111 | }
112 | tft.begin();
113 | #ifdef HARDWARE_DEFINED_TFT
114 | #if HARDWARE_DEFINED_TFT == 1
115 | EEPROM.update(EEPROM_DISPLAY, RGB_DISP);
116 | setDisplayMode(0);
117 | #else
118 | EEPROM.update(EEPROM_DISPLAY, BGR_DISP);
119 | setDisplayMode(1);
120 | #endif
121 | #else
122 | if (force_menu || EEPROM.read(EEPROM_VERSION) < 23 || EEPROM.read(EEPROM_VERSION) == 255 || (EEPROM.read(EEPROM_DISPLAY) != BGR_DISP && EEPROM.read(EEPROM_DISPLAY) != RGB_DISP)) {
123 | tft.fillScreen(BLACK);
124 | setDisplayMode(1);
125 | tft.setTextSize(2);
126 | tft.setCursor(0,0);
127 | tft.setTextColor(WHITE);
128 | tft.print(F("What color is displayed?"));
129 | tft.setCursor(10,112);
130 | tft.setTextColor(RED);
131 | tft.print("RED BLUE");
132 | while (true) {
133 | if (!digitalRead(SW_T1)) {
134 | EEPROM.update(EEPROM_DISPLAY, BGR_DISP);
135 | setDisplayMode(1);
136 | break;
137 | }
138 | if (!digitalRead(SW_T3)) {
139 | EEPROM.update(EEPROM_DISPLAY, RGB_DISP);
140 | setDisplayMode(0);
141 | break;
142 | }
143 | }
144 | tft.fillScreen(BLACK);
145 | tft.setTextColor(YELLOW);
146 | tft.drawBitmap(0, 20, maiskolben, 160, 64, YELLOW);
147 | tft.setCursor(20,86);
148 | tft.setTextColor(YELLOW);
149 | tft.setTextSize(2);
150 | tft.print("Maiskolben");
151 | tft.setCursor(35,104);
152 | tft.print("Welcome!");
153 | delay(4000);
154 | while (!digitalRead(SW_T3) || !digitalRead(SW_T1)) delay(100);
155 | } else {
156 | setDisplayMode(EEPROM.read(EEPROM_DISPLAY) == BGR_DISP);
157 | }
158 | #endif
159 | #ifdef INSTALL
160 | if (EEPROM.read(EEPROM_INSTALL) != EEPROM_CHECK) {
161 | tft.fillScreen(BLACK);
162 | tft.setTextColor(RED, BLACK);
163 | tft.setCursor(0,0);
164 | tft.setTextSize(2);
165 | tft.println("Installation");
166 | for (int16_t i = -255; i < 256; i++) {
167 | analogWrite(HEAT_LED, 255-abs(i));
168 | delay(1);
169 | }
170 | uint16_t adc1 = 0, adc2 = 0;
171 | while (digitalRead(SW_STBY)) {
172 | int t = getTemperature();
173 | uint16_t adc = analogRead(TEMP_SENSE);
174 | Serial.println(t);
175 | digitalWrite(HEATER_PWM, !digitalRead(SW_T1) | !digitalRead(SW_T2) | !digitalRead(SW_T3)/* | !digitalRead(SW_UP) | !digitalRead(SW_DOWN)*/);
176 | if (!digitalRead(SW_DOWN)) {
177 | if (!adc) {
178 | digitalWrite(HEATER_PWM, HIGH);
179 | } else {
180 | adc1 = adc;
181 | }
182 | }
183 | if (!digitalRead(SW_UP)) {
184 | if (!adc) {
185 | digitalWrite(HEATER_PWM, HIGH);
186 | } else {
187 | adc2 = adc;
188 | }
189 | }
190 | tft.setCursor(0,18);
191 | tft.print(t);
192 | tft.println(" ");
193 | tft.print(adc);
194 | tft.println(" ");
195 | tft.println(adc * adc_gain + adc_offset);
196 | if (adc1 != 0 && adc2 != 0) {
197 | adc_gain = DELTA_REF_T / (float)(adc2 - adc1);
198 | adc_offset = REF_T1 - adc_gain * adc1;
199 | tft.println(adc_gain);
200 | tft.println(adc_offset);
201 | }
202 | delay(50);
203 | }
204 | EEPROM.update(EEPROM_OPTIONS, (fahrenheit << 2) | (bootheat << 1) | autopower);
205 | EEPROM.update(EEPROM_VERSION, EE_VERSION);
206 | EEPROM.update(EEPROM_INSTALL, EEPROM_CHECK);
207 | EEPROM.put(EEPROM_ADCTTG, adc_gain);
208 | EEPROM.put(EEPROM_ADCOFF, adc_offset);
209 |
210 | tft.println("done.");
211 | delay(1000);
212 | asm volatile("jmp 0");
213 | }
214 | #endif
215 | if (EEPROM.read(EEPROM_VERSION) != EE_VERSION) {
216 | force_menu = true;
217 | }
218 | tft.fillScreen(BLACK);
219 | uint8_t options = EEPROM.read(EEPROM_OPTIONS);
220 | autopower = options & 1;
221 | bootheat = options & 2;
222 | fahrenheit = options & 4;
223 | if (force_menu) optionMenu();
224 | else {
225 | updateRevision();
226 | tft.drawBitmap(0, 20, maiskolben, 160, 64, YELLOW);
227 | tft.setCursor(20,86);
228 | tft.setTextColor(YELLOW);
229 | tft.setTextSize(2);
230 | tft.print("Maiskolben");
231 | tft.setCursor(50,110);
232 | tft.setTextSize(1);
233 | tft.print("Version ");
234 | tft.print(VERSION);
235 | tft.setCursor(46,120);
236 | tft.print("HW Revision ");
237 | tft.print(revision);
238 | //Allow Options to be set at startup
239 | delay(100);
240 | attachInterrupt(digitalPinToInterrupt(SW_STBY), optionMenu, LOW);
241 | for (int i = 0; i < 10 && !menu_dismissed; i++) {
242 | digitalWrite(HEAT_LED, i % 2);
243 | delay(250);
244 | }
245 | detachInterrupt(digitalPinToInterrupt(SW_STBY));
246 | }
247 | /*
248 | * lower frequency = noisier tip
249 | * higher frequency = needs higher pwm
250 | */
251 | //PWM Prescaler = 1024 31Hz
252 | //TCCR2B = (TCCR2B & 0b11111000) | 7;
253 | //PWM Prescaler = 256 122Hz
254 | //TCCR2B = (TCCR2B & 0b11111000) | 6;
255 | //PWM Prescaler = 128 245Hz
256 | TCCR2B = (TCCR2B & 0b11111000) | 5;
257 | //PWM Prescaler = 64 490Hz
258 | //TCCR2B = (TCCR2B & 0b11111000) | 4
259 | //PWM Prescaler = 32 980Hz
260 | //TCCR2B = (TCCR2B & 0b11111000) | 3;
261 | //PWM Prescaler = 8 3.9kHz
262 | //TCCR2B = (TCCR2B & 0b11111000) | 2
263 | //PWM Prescaler = 1 31kHz - no Noise
264 | //TCCR2B = (TCCR2B & 0b11111000) | 1;
265 | stby = EEPROM.read(1);
266 | for (uint8_t i = 0; i < 3; i++) {
267 | stored[i] = EEPROM.read(2+i*2) << 8;
268 | stored[i] |= EEPROM.read(3+i*2);
269 | }
270 | set_t = EEPROM.read(EEPROM_SET_T) << 8;
271 | set_t |= EEPROM.read(EEPROM_SET_T+1);
272 |
273 | for (uint8_t i = 0; i < 50; i++)
274 | measureVoltage(); //measure average 50 times to get realistic results
275 |
276 | tft.fillScreen(BLACK);
277 | last_measured = getTemperature();
278 | Timer1.initialize(1000);
279 | Timer1.attachInterrupt(timer_isr);
280 | heaterPID.SetMode(AUTOMATIC);
281 | sendNext = millis();
282 | if (bootheat) {
283 | threshold_counter = TEMP_UNDER_THRESHOLD;
284 | setOff(false);
285 | }
286 | if (EEPROM.read(EEPROM_ADCTTG) == 255) { //Override unset values from older versions
287 | EEPROM.put(EEPROM_ADCTTG, adc_gain);
288 | EEPROM.put(EEPROM_ADCOFF, adc_offset);
289 | }
290 | EEPROM.get(EEPROM_ADCTTG, adc_gain);
291 | EEPROM.get(EEPROM_ADCOFF, adc_offset);
292 | }
293 |
294 | void updateRevision(void) {
295 | #if (HARDWARE_REVISION > 2)
296 | EEPROM.update(EEPROM_REVISION, HARDWARE_REVISION);
297 | revision = 3;
298 | #else
299 | if (EEPROM.read(EEPROM_VERSION) < 26 || EEPROM.read(EEPROM_REVISION) > 100) {
300 | EEPROM.update(EEPROM_REVISION, 2);
301 | revision = 2;
302 | } else {
303 | revision = EEPROM.read(EEPROM_REVISION);
304 | }
305 | #endif
306 | }
307 |
308 | void setDisplayMode(boolean bgr) {
309 | tft.colorSpace(bgr);
310 | tft.setRotation(3);
311 | }
312 |
313 | void optionMenu(void) {
314 | tft.fillScreen(BLACK);
315 | digitalWrite(HEAT_LED, LOW);
316 | tft.setTextSize(2);
317 | tft.setCursor(0,0);
318 | tft.setTextColor(WHITE);
319 | tft.println("Options\n");
320 | tft.setTextColor(WHITE);
321 | tft.setCursor(10,112);
322 | tft.print("ON OFF EXIT");
323 | uint8_t options = 3;
324 | uint8_t opt = 0;
325 | boolean redraw = true;
326 | while (true) {
327 | if (redraw) {
328 | tft.setCursor(0,36);
329 | #ifdef SHUTOFF_ACTIVE
330 | tft.setTextColor(autopower?GREEN:RED);
331 | #else
332 | tft.setTextColor(GRAY);
333 | #endif
334 | tft.println(" Autoshutdown");
335 | #ifdef BOOTHEAT_ACTIVE
336 | tft.setTextColor(bootheat?GREEN:RED);
337 | #else
338 | tft.setTextColor(GRAY);
339 | #endif
340 | tft.println(" Heat on boot");
341 | tft.setTextColor(fahrenheit?GREEN:RED);
342 | tft.println(" Fahrenheit");
343 |
344 | tft.setCursor(0, (opt+2)*18);
345 | tft.setTextColor(WHITE);
346 | tft.print(">");
347 | redraw = false;
348 | }
349 | if (!digitalRead(SW_UP)) {
350 | tft.setCursor(0, (opt+2)*18);
351 | tft.setTextColor(BLACK);
352 | tft.print(">");
353 | opt = (opt+options-1)%options;
354 | while (!digitalRead(SW_UP)) delay(100);
355 | redraw = true;
356 | }
357 | if (!digitalRead(SW_DOWN)) {
358 | tft.setCursor(0, (opt+2)*18);
359 | tft.setTextColor(BLACK);
360 | tft.print(">");
361 | opt = (opt+1)%options;
362 | while (!digitalRead(SW_DOWN)) delay(100);
363 | redraw = true;
364 | }
365 | if (!digitalRead(SW_T1)) {
366 | switch (opt) {
367 | case 0: autopower = 1; break;
368 | case 1: bootheat = 1; break;
369 | case 2: fahrenheit = 1; break;
370 | }
371 | redraw = true;
372 | }
373 | if (!digitalRead(SW_T2)) {
374 | switch (opt) {
375 | case 0: autopower = 0; break;
376 | case 1: bootheat = 0; break;
377 | case 2: fahrenheit = 0; break;
378 | }
379 | redraw = true;
380 | }
381 | if (!digitalRead(SW_T3)) break;
382 | }
383 | EEPROM.update(EEPROM_OPTIONS, (fahrenheit << 2) | (bootheat << 1) | autopower);
384 | updateRevision();
385 | EEPROM.update(EEPROM_VERSION, EE_VERSION);
386 | if (EEPROM.read(EEPROM_VERSION) < 30) {
387 | EEPROM.put(EEPROM_ADCTTG, ADC_TO_TEMP_GAIN);
388 | EEPROM.put(EEPROM_ADCOFF, ADC_TO_TEMP_OFFSET);
389 | }
390 | menu_dismissed = true;
391 | }
392 |
393 | void updateEEPROM(void) {
394 | EEPROM.update(1, stby);
395 | for (uint8_t i = 0; i < 3; i++) {
396 | EEPROM.update(2+i*2, stored[i] >> 8);
397 | EEPROM.update(3+i*2, stored[i] & 0xFF);
398 | }
399 | EEPROM.update(8, set_t >> 8);
400 | EEPROM.update(9, set_t & 0xFF);
401 | EEPROM.update(EEPROM_OPTIONS, (fahrenheit << 2) | (bootheat << 1) | autopower);
402 | }
403 |
404 | void powerDown(void) {
405 | if (power_source != POWER_LIPO) {
406 | power_down = false;
407 | return;
408 | }
409 | //Timer1.stop();
410 | setOff(true);
411 | delay(10);
412 | tft.fillScreen(BLACK);
413 | tft.setTextSize(4);
414 | tft.setTextColor(RED);
415 | tft.setCursor(50,40);
416 | tft.print("OFF");
417 | delay(3000);
418 | SPI.end();
419 | digitalWrite(POWER, LOW);
420 | pinMode(POWER, OUTPUT);
421 | delay(100);
422 | force_redraw = true;
423 | power_down = false;
424 | Timer1.start(); //unsuccessful
425 | }
426 |
427 | float toFahrenheit(float t) {
428 | return t * 1.8 + 32;
429 | }
430 |
431 | int getTemperature(void) {
432 | analogRead(TEMP_SENSE);//Switch ADC MUX
433 | uint16_t adc = median(TEMP_SENSE);
434 | #ifdef TEST_ADC
435 | Serial.println(adc);
436 | #endif
437 | if (adc >= 900) { //Illegal value, tip not plugged in - would be around 560deg
438 | analogWrite(HEATER_PWM, 0);
439 | if (!off)
440 | setError(NO_TIP);
441 | return 999;
442 | } else {
443 | analogWrite(HEATER_PWM, pwm); //switch heater back to last value
444 | }
445 | //return round(adc < 210 ? (((float)adc) * 0.530805 + 38.9298) : (((float)adc) * 0.415375 + 64.6123)); //old conversion
446 | return round(((float) adc) * adc_gain + adc_offset);
447 | }
448 |
449 | void measureVoltage(void) {
450 | analogRead(BAT_C1); //Switch analog MUX before measuring
451 | v_c1 = v_c1*.9+(analogRead(BAT_C1)*5/1024.0)*.1; //no divisor
452 | analogRead(BAT_C2);
453 | v_c2 = v_c2*.9+(analogRead(BAT_C2)*5/512.0)*.1; //divisor 1:1 -> /2
454 | analogRead(BAT_C3);
455 | v_c3 = v_c3*.9+(analogRead(BAT_C3)*(5.0*3.0)/1024.0)*.1; //maximum measurable is ~15V
456 | v = v_c3;
457 | if (revision < 3) return;
458 | #ifdef VIN
459 | analogRead(VIN);
460 | v_in = v_in*.9+(analogRead(VIN)*25/1024.0)*.1; //maximum measurable is ~24.5V
461 | v = v_in; //backwards compatibility
462 | #endif
463 | }
464 |
465 | uint16_t median(uint8_t analogIn) {
466 | uint16_t adcValue[3];
467 | for (uint8_t i = 0; i < 3; i++) {
468 | adcValue[i] = analogRead(analogIn); // read the input 3 times
469 | }
470 | uint16_t tmp;
471 | if (adcValue[0] > adcValue[1]) {
472 | tmp = adcValue[0];
473 | adcValue[0] = adcValue[1];
474 | adcValue[1] = tmp;
475 | }
476 | if (adcValue[1] > adcValue[2]) {
477 | tmp = adcValue[1];
478 | adcValue[1] = adcValue[2];
479 | adcValue[2] = tmp;
480 | }
481 | if (adcValue[0] > adcValue[1]) {
482 | tmp = adcValue[0];
483 | adcValue[0] = adcValue[1];
484 | adcValue[1] = tmp;
485 | }
486 | return adcValue[1];
487 | }
488 |
489 | void timer_sw_poll(void) {
490 | if (power_down) return;
491 | if (!digitalRead(SW_STBY)) {
492 | if (cnt_off_press == 100) {
493 | setOff(!off);
494 | }
495 | if (cnt_off_press == 200 && power_source == POWER_LIPO) {
496 | setOff(true);
497 | power_down = true;
498 | return;
499 | }
500 | cnt_off_press = min(201, cnt_off_press+1);
501 | } else {
502 | if (cnt_off_press > 0 && cnt_off_press <= 100) {
503 | setStandby(!stby);
504 | }
505 | cnt_off_press = 0;
506 | }
507 | boolean t1 = !digitalRead(SW_T1);
508 | boolean t2 = !digitalRead(SW_T2);
509 | boolean t3 = !digitalRead(SW_T3);
510 |
511 | //simultanious push of multiple buttons
512 | if (t1 + t2 + t3 > 1) {
513 | store_to = 255;
514 | store_invalid = true;
515 | } else if (error != NO_ERROR) {
516 | if (!(t1 | t2 | t3)) {
517 | store_invalid = false;
518 | } else if (!store_invalid && t3) {
519 | error = NO_ERROR; //dismiss
520 | set_t_old = 0; //refresh set_t display
521 | store_invalid = true; //wait for release
522 | }
523 | } else {
524 | //all buttons released
525 | if (!(t1 | t2 | t3)) {
526 | if (store_to != 255) {
527 | if (cnt_but_store <= 100) {
528 | set_t = stored[store_to];
529 | setStandby(false);
530 | updateEEPROM();
531 | }
532 | }
533 | store_to = 255;
534 | store_invalid = false;
535 | cnt_but_store = 0;
536 | } else
537 | //one button pressed
538 | if (!store_invalid) {
539 | store_to = t2 + 2*t3;
540 | if (cnt_but_store > 100) {
541 | if (set_t != stored[store_to] && !stby) {
542 | stored[store_to] = set_t;
543 | cnt_but_store = 100;
544 | updateEEPROM();
545 | }
546 | }
547 | cnt_but_store++;
548 | }
549 | }
550 | boolean sw_up = !digitalRead(SW_UP);
551 | boolean sw_down = !digitalRead(SW_DOWN);
552 | boolean sw_changed = (sw_up != sw_up_old) || (sw_down !=sw_down_old);
553 | sw_up_old = sw_up;
554 | sw_down_old = sw_down;
555 | if((sw_up && sw_down) || !(sw_up || sw_down)) {
556 | cnt_but_press = 0;
557 | return;
558 | }
559 | if(sw_up || sw_down) {
560 | cnt_but_press++;
561 | if((cnt_but_press >= 100) || sw_changed) {
562 | setStandby(false);
563 | if(sw_up && set_t < TEMP_MAX) set_t++;
564 | else if (sw_down && set_t > TEMP_MIN) set_t--;
565 | if(!sw_changed) cnt_but_press = 97;
566 | updateEEPROM();
567 | }
568 | }
569 | }
570 |
571 | void setStandby(boolean state) {
572 | if (stby_layoff) return;
573 | if (state == stby) return;
574 | stby = state;
575 | last_measured = cur_t;
576 | last_temperature_drop = millis();
577 | last_on_state = millis()/1000;
578 | EEPROM.update(1, stby);
579 | }
580 | void setStandbyLayoff(boolean state) {
581 | if (state == stby_layoff) return;
582 | stby_layoff = state;
583 | stby = false;
584 | last_measured = cur_t;
585 | last_on_state = millis()/1000;
586 | }
587 |
588 | void setOff(boolean state) {
589 | if (state == off) return;
590 | if (!state)
591 | analogWrite(HEATER_PWM, 0);
592 | else
593 | setStandby(false);
594 | if (power_source == POWER_USB && !state) {
595 | state = true; //don't switch on, if powered via USB
596 | setError(USB_ONLY);
597 | }
598 | last_on_state = millis()/1000;
599 | off = state;
600 | wasOff = true;
601 | last_measured = cur_t;
602 | }
603 |
604 | void printTemp(float t) {
605 | if (fahrenheit) {
606 | t = toFahrenheit(t);
607 | }
608 | if (t < 100) tft.write(' ');
609 | tft.print((int)t);
610 | }
611 |
612 | void display(void) {
613 | if (force_redraw) tft.fillScreen(BLACK);
614 | int16_t temperature = cur_t; //buffer volatile value
615 | boolean yell = stby || (stby_layoff && blink);
616 | tft.drawCircle(20,63,8, off?RED:yell?YELLOW:GREEN);
617 | tft.drawCircle(20,63,7,off?RED:yell?YELLOW:GREEN);
618 | tft.fillRect(19,55,3,3,BLACK);
619 | tft.drawFastVLine(20,53,10, off?RED:yell?YELLOW:GREEN);
620 | if (error != NO_ERROR) {
621 | if (error != error_old || force_redraw) {
622 | error_old = error;
623 | tft.setTextSize(1);
624 | tft.setTextColor(RED, BLACK);
625 | tft.setCursor(0,96);
626 | switch (error) {
627 | case EXCESSIVE_FALL:
628 | tft.print(F("Error: Temperature dropped\nTip slipped out?"));
629 | break;
630 | case NOT_HEATING:
631 | tft.print(F("Error: Not heating\nWeak power source or short"));
632 | break;
633 | case BATTERY_LOW:
634 | tft.print(F("Error: Battery low\nReplace or charge"));
635 | break;
636 | case USB_ONLY:
637 | tft.print(F("Error: Power too low\nConnect power >5V"));
638 | break;
639 | case NO_TIP:
640 | tft.print(F("Error: No tip connected\nTip slipped out?"));
641 | break;
642 | }
643 | tft.setTextSize(2);
644 | tft.setTextColor(YELLOW, BLACK);
645 | tft.setCursor(10,112);
646 | tft.print(F(" OK "));
647 |
648 | tft.setTextColor(RED, BLACK);
649 | tft.setCursor(36,26);
650 | tft.setTextSize(3);
651 | tft.print(F(" ERR "));
652 | }
653 | } else {
654 | if (error != error_old || force_redraw) {
655 | tft.fillRect(0, 96, 160, 16, BLACK);
656 | error_old = NO_ERROR;
657 | }
658 | tft.setTextSize(2);
659 | tft.setCursor(15,112);
660 | tft.setTextColor(WHITE, BLACK);
661 | printTemp(stored[0]);
662 | tft.write(' ');
663 | printTemp(stored[1]);
664 | tft.write(' ');
665 | printTemp(stored[2]);
666 |
667 | if (set_t_old != set_t || old_stby != (stby || stby_layoff) || force_redraw) {
668 | tft.setCursor(36,26);
669 | tft.setTextSize(3);
670 | if (stby || stby_layoff) {
671 | old_stby = true;
672 | tft.setTextColor(YELLOW, BLACK);
673 | tft.print(F("STBY "));
674 | } else {
675 | old_stby = false;
676 | set_t_old = set_t;
677 | tft.setTextColor(WHITE, BLACK);
678 | tft.write(' ');
679 | printTemp(set_t);
680 | tft.write(247);
681 | tft.write(fahrenheit?'F':'C');
682 | tft.fillTriangle(149, 50, 159, 50, 154, 38, (set_t < TEMP_MAX) ? WHITE : GRAY);
683 | tft.fillTriangle(149, 77, 159, 77, 154, 90, (set_t > TEMP_MIN) ? WHITE : GRAY);
684 | }
685 | }
686 | if (!off) {
687 | #ifdef SHUTOFF_ACTIVE
688 | if (autopower) {
689 | int16_t tout;
690 | if (stby || stby_layoff) {
691 | tout = min(max(0,(last_on_state + OFF_TIMEOUT - (millis())/1000)), OFF_TIMEOUT);
692 | } else {
693 | tout = min(max(0,(last_temperature_drop + STANDBY_TIMEOUT - (millis())/1000)), STANDBY_TIMEOUT);
694 | }
695 | tft.setTextColor(stby?RED:YELLOW, BLACK);
696 | tft.setTextSize(2);
697 | tft.setCursor(46,78);
698 | if (tout < 600) tft.write('0');
699 | tft.print(tout/60);
700 | tft.write(':');
701 | if (tout%60 < 10) tft.write('0');
702 | tft.print(tout%60);
703 | }
704 | #endif
705 | } else if (temperature != 999) {
706 | tft.fillRect(46, 78, 60, 20, BLACK);
707 | }
708 | }
709 | if (cur_t_old != temperature || force_redraw) {
710 | tft.setCursor(36,52);
711 | tft.setTextSize(3);
712 | if (temperature == 999) {
713 | tft.setTextColor(RED, BLACK);
714 | tft.print(F(" ERR "));
715 | tft.setCursor(44,76);
716 | tft.setTextSize(2);
717 | tft.print(F("NO TIP"));
718 | } else {
719 | if (cur_t_old == 999) {
720 | tft.fillRect(44,76,72,16,BLACK);
721 | }
722 | tft.setTextColor(off ? temperature < TEMP_COLD ? CYAN : RED : tft.Color565(min(10,abs(temperature-target_t))*25, 250 - min(10,max(0,(abs(temperature-target_t)-10)))*25, 0), BLACK);
723 | if (temperature < TEMP_COLD) {
724 | tft.print(F("COLD "));
725 | } else {
726 | tft.write(' ');
727 | printTemp(temperature);
728 | tft.write(247);
729 | tft.write(fahrenheit?'F':'C');
730 | }
731 | }
732 | if (temperature < cur_t_old)
733 | tft.fillRect(max(0, (temperature - TEMP_COLD)/2.4), 0, 160-max(0, (temperature - TEMP_COLD)/2.4), BAR_HEIGHT, BLACK);
734 | else if (cur_t != 999) {
735 | for (int16_t i = max(0, (cur_t_old - TEMP_COLD)/2.4); i < max(0, (temperature - TEMP_COLD)/2.4); i++) {
736 | tft.drawFastVLine(i, 0, BAR_HEIGHT, tft.Color565(min(255, max(0, i*5)), min(255, max(0, 450-i*2.5)), 0));
737 | }
738 | }
739 | cur_t_old = temperature;
740 | }
741 | if (v_c3 > 1.0) {
742 | tft.setTextColor(YELLOW, BLACK);
743 | tft.setCursor(122,5);
744 | tft.setTextSize(2);
745 | int power = min(15,v)*min(15,v)/4.8*pwm/255;
746 | if (power < 10) tft.write(' ');
747 | tft.print(power);
748 | tft.write('W');
749 |
750 | if (v < 5.0) {
751 | power_source = POWER_USB;
752 | } else if (v_c2 < 1.0) {
753 | power_source = POWER_CORD;
754 | } else {
755 | power_source = POWER_LIPO; //Set charging later to not redraw if charging mode toggles
756 | }
757 | if (power_source != power_source_old || force_redraw) {
758 | tft.fillRect(0, 5, 128, 20, BLACK);
759 | tft.fillRect(11, 25, 21, 20, BLACK);
760 | switch (power_source) {
761 | case POWER_CHARGING:
762 | case POWER_LIPO:
763 | for (uint8_t i = 0; i < 3; i++) {
764 | tft.drawRect(11, 5+i*14, 20, 12, WHITE);
765 | //tft.fillRect(12, 6+i*14, 18, 10, BLACK);
766 | tft.drawFastVLine(31,8+i*14,6,WHITE);
767 | }
768 | break;
769 | case POWER_USB:
770 | tft.setTextSize(1);
771 | tft.setTextColor(RED, BLACK);
772 | tft.setCursor(0,5);
773 | tft.print("USB power only\nConnect power supply.");
774 | if (!off) setError(USB_ONLY);
775 | break;
776 | }
777 | power_source_old = power_source;
778 | }
779 | if (power_source == POWER_CORD) {
780 | /*if (v > v_c3) {
781 | tft.setTextSize(2);
782 | tft.setTextColor(GREEN, BLACK);
783 | tft.setCursor(0,5);
784 | tft.print(v);
785 | tft.print("V ");
786 | } else {*/
787 | tft.drawBitmap(0, 5, power_cord, 24, 9, tft.Color565(max(0, min(255, (14.5-v)*112)), max(0, min(255, (v-11)*112)), 0));
788 | //}
789 | } else if (power_source == POWER_LIPO || power_source == POWER_CHARGING) {
790 | float volt[] = {v_c1, v_c2-v_c1, v_c3-v_c2};
791 | uint8_t volt_disp[] = {max(1,min(16,(volt[0]-3.0)*14.2)), max(1,min(16,(volt[1]-3.0)*14.2)), max(1,min(16,(volt[2]-3.0)*14.2))};
792 | if (power_source == POWER_CHARGING) {
793 | uint8_t p = min(16, (millis() / 100) % 20);
794 | for (uint8_t i = 0; i < 3; i++) {
795 | volt_disp[i] = max(0, min(volt_disp[i], p));
796 | }
797 | }
798 | for (uint8_t i = 0; i < 3; i++) {
799 | if (volt[i] < 3.20) {
800 | setError(BATTERY_LOW);
801 | tft.fillRect(13, 7+14*i, volt_disp[i], 8, blink?RED:BLACK);
802 | } else {
803 | tft.fillRect(13, 7+14*i, volt_disp[i], 8, tft.Color565(250-min(250, max(0, (volt[i]-3.4)*1000.0)), max(0,min(250, (volt[i]-3.15)*1000.0)), 0));
804 | }
805 | tft.fillRect(13+volt_disp[i], 7+14*i, 17-volt_disp[i], 8, BLACK);
806 | }
807 | }
808 | }
809 | #ifdef SHUTOFF_ACTIVE
810 | if (autopower) {
811 | if (!stby_layoff) {
812 | if (pwm > max(20, (cur_t-150)/50*round(25-min(15,v)))+5) {
813 | //if (target_t-cur_t > 0.715*exp(0.0077*target_t)) {
814 | //if (cur_t / (double)target_t < STANDBY_TEMPERATURE_DROP) {
815 | if (autopower_repeat_under || stby) {
816 | if (stby && !wasOff) {
817 | setStandby(false);
818 | } else {
819 | last_temperature_drop = millis()/1000;
820 | }
821 | }
822 | autopower_repeat_under = true;
823 | } else if (wasOff) {
824 | wasOff = false;
825 | } else {
826 | autopower_repeat_under = false; //over the max pwm for at least two times
827 | }
828 | }
829 | if (!off && !stby && millis()/1000 > (last_temperature_drop + STANDBY_TIMEOUT)) {
830 | setStandby(true);
831 | }
832 | if (!off && (stby || stby_layoff) && millis()/1000 > (last_on_state + OFF_TIMEOUT)) {
833 | setOff(true);
834 | }
835 | }
836 | #endif
837 | blink = !blink;
838 | force_redraw = false;
839 | }
840 |
841 | void compute(void) {
842 | #ifndef USE_TFT_RESET
843 | setStandbyLayoff(!digitalRead(STBY_NO)); //do not measure while heater is active, potential is not neccessary == GND
844 | #endif
845 | cur_t = getTemperature();
846 | if (off) {
847 | target_t = 0;
848 | if (cur_t < adc_offset + TEMP_RISE) {
849 | threshold_counter = TEMP_UNDER_THRESHOLD; //reset counter
850 | }
851 | } else {
852 | if (stby_layoff || stby) {
853 | target_t = TEMP_STBY;
854 | } else {
855 | target_t = set_t;
856 | }
857 | if (cur_t-last_measured <= -30 && last_measured != 999) {
858 | setError(EXCESSIVE_FALL); //decrease of more than 30 degree is uncommon, short of ring and gnd is possible.
859 | }
860 | if (cur_t < adc_offset + TEMP_RISE) {
861 | if (threshold_counter == 0) {
862 | setError(NOT_HEATING); //temperature is not reached in desired time, short of sensor and gnd too?
863 | } else {
864 | threshold_counter--;
865 | }
866 | } else {
867 | threshold_counter = THRES_MAX_DECEED; //reset counter to a smaller value to allow small oscillation of temperature
868 | }
869 | }
870 |
871 | set_td = target_t;
872 | cur_td = cur_t;
873 | last_measured = cur_t;
874 |
875 | heaterPID.Compute();
876 | if (error != NO_ERROR || off)
877 | pwm = 0;
878 | else
879 | pwm = min(255,pid_val*255);
880 | analogWrite(HEATER_PWM, pwm);
881 | }
882 |
883 | void timer_isr(void) {
884 | if (cnt_compute >= TIME_COMPUTE_IN_MS) {
885 | analogWrite(HEATER_PWM, 0); //switch off heater to let the low pass settle
886 |
887 | if (cnt_compute >= TIME_COMPUTE_IN_MS+DELAY_BEFORE_MEASURE) {
888 | compute();
889 | cnt_compute=0;
890 | }
891 | }
892 | cnt_compute++;
893 |
894 | if(cnt_sw_poll >= TIME_SW_POLL_IN_MS){
895 | timer_sw_poll();
896 | cnt_sw_poll=0;
897 | }
898 | cnt_sw_poll++;
899 |
900 | if(cnt_measure_voltage >= TIME_MEASURE_VOLTAGE_IN_MS) {
901 | measureVoltage();
902 | cnt_measure_voltage=0;
903 | }
904 | cnt_measure_voltage++;
905 | }
906 |
907 | void setError(error_type e) {
908 | error = e;
909 | setOff(true);
910 | }
911 |
912 | void loop(void) {
913 | analogWrite(HEAT_LED, pwm);
914 | //Switch to following if the oscillation of the led bothers you
915 | //digitalWrite(HEAT_LED, cur_t+5 < target || (abs((int16_t)cur_t-(int16_t)target) <= 5 && (millis()/(stby?1000:500))%2));
916 |
917 | if (sendNext <= millis()) {
918 | sendNext += 100;
919 | #ifndef TEST_ADC
920 | Serial.print(stored[0]);
921 | Serial.print(";");
922 | Serial.print(stored[1]);
923 | Serial.print(";");
924 | Serial.print(stored[2]);
925 | Serial.print(";");
926 | Serial.print(off?0:1);
927 | Serial.print(";");
928 | Serial.print(error);
929 | Serial.print(";");
930 | Serial.print(stby?1:0);
931 | Serial.print(";");
932 | Serial.print(stby_layoff?1:0);
933 | Serial.print(";");
934 | Serial.print(set_t);
935 | Serial.print(";");
936 | Serial.print(cur_t);
937 | Serial.print(";");
938 | Serial.print(pid_val);
939 | Serial.print(";");
940 | Serial.print(v_c2>1.0?v_c1:0.0);
941 | Serial.print(";");
942 | Serial.print(v_c2);
943 | Serial.print(";");
944 | Serial.println(v);
945 | #endif
946 | Serial.flush();
947 | display();
948 | }
949 | if (Serial.available()) {
950 | uint16_t t = 0;
951 | switch (Serial.read()) {
952 | //Set new Temperature (eg. S350 to set to 350C)
953 | case 'T':
954 | if (Serial.available() >= 3) {
955 | t = serialReadTemp();
956 | //Serial.println(t);
957 | if (t <= TEMP_MAX && t >= TEMP_MIN) {
958 | set_t = t;
959 | updateEEPROM();
960 | }
961 | }
962 | break;
963 | //Store new Preset (eg. P1200 to store 200C to Preset 1, NOT 0 indexed)
964 | case 'P':
965 | if (Serial.available() >= 4) {
966 | uint8_t slot = Serial.read()-'1';
967 | if (slot < 3) {
968 | t = serialReadTemp();
969 | if (t <= TEMP_MAX && t >= TEMP_MIN) {
970 | stored[slot] = t;
971 | updateEEPROM();
972 | }
973 | }
974 | }
975 | break;
976 | //Clear errors
977 | case 'C':
978 | error = NO_ERROR;
979 | break;
980 | //Set standby
981 | case 'S':
982 | setStandby(Serial.read() == '1');
983 | break;
984 | //Set on/off
985 | case 'O':
986 | setOff(Serial.read() == '0');
987 | break;
988 | }
989 | }
990 | delay(DELAY_MAIN_LOOP);
991 | if (power_down) {
992 | powerDown();
993 | }
994 | }
995 |
996 | uint16_t serialReadTemp() {
997 | uint16_t t;
998 | uint8_t n;
999 | n = Serial.read()-'0';
1000 | t = min(9, max(0, n))*100;
1001 | n = Serial.read()-'0';
1002 | t += min(9, max(0, n))*10;
1003 | n = Serial.read()-'0';
1004 | t += min(9, max(0, n))*1;
1005 | return t;
1006 | }
