1 | /*
2 | This program is free software: you can redistribute it and/or modify
3 | it under the terms of the GNU General Public License as published by
4 | the Free Software Foundation, either version 3 of the License, or
5 | (at your option) any later version.
6 |
7 | This program is distributed in the hope that it will be useful,
8 | but WITHOUT ANY WARRANTY; without even the implied warranty of
9 | MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
10 | GNU General Public License for more details.
11 |
12 | You should have received a copy of the GNU General Public License
13 | along with this program. If not, see <http://www.gnu.org/licenses/>.
14 | *
15 | * @ Project : MultiSensor
16 | * @ File Name :SBUS_usart.cpp
17 | * @ Date : 6/12/2013
18 | * @ Author : Bart Keser
19 | *
20 | */
21 |
22 | #include <avr/io.h>
23 | #include <avr/interrupt.h>
24 | #include <stdarg.h>
25 | #include <stdlib.h>
26 | #include <string.h>
27 |
28 | #include "myavr.h"
29 | #include "SBUS_usart.h"
30 | #include "usart.h"
31 |
32 |
33 | #define F_CPU 8000000
34 |
35 | #define SLOT_DATA_LENGTH 3
36 | #define NUMBER_OF_FRAMES 4
37 | #define NUMBER_OF_SLOT 32
38 | #define NUMBER_OF_SLOT_IN_FRAME 8
39 | #define SBUS_FRAME_SIZE 25
40 | #define SBUS_CHANNEL_SIZE 11
41 |
42 |
43 | #define UART_RXBUFSIZE 30
44 | #define FRAME_TIME_OUT 200 //ms
45 |
46 |
47 | #define TRANSMIT_PIN PIN_0 // digital IO C
48 | #define RECEIVE_PIN PIN_5 // digital IO B
49 | #define TRANSMIT_RECEIVE_ENABLE LOW
50 | #define TRANSMIT_RECEIVE_DISABLE HIGH
51 |
52 | #define SLOT_TIME 90 //165
53 | #define SLOT_TIME2 165
54 |
55 |
56 | uint8_t swaps_slot_bits[8] = {0,4,2,6,1,5,3,7};
57 |
58 | uint8_t toggle = 0;
59 |
60 |
61 | //static bool command_received = false;
62 | //static uint8_t command[UART_RXBUFSIZE];
63 | //static uint8_t command_length = 9;
64 |
65 | // 248 is around 1 ms
66 | uint8_t transmit_sequence_timer[15] = {250,250,SLOT_TIME2,SLOT_TIME,SLOT_TIME,SLOT_TIME,SLOT_TIME,SLOT_TIME,SLOT_TIME,SLOT_TIME,226,226,226,226,180};
67 | uint8_t receive_timeout_timer = ( uint8_t ) (248.0 * (FRAME_TIME_OUT / 1000.0));
68 | uint16_t overflow_counter = 0; // should not occur
69 |
70 | static volatile uint8_t rxbuf[UART_RXBUFSIZE];
71 | static volatile bool frame_ready = false;
72 | static volatile uint8_t gl_current_frame = 0;
73 | static volatile uint16_t uart_lost_frame = 0;
74 |
75 | typedef enum
76 | {
77 | EMPTY = 0,
78 | TRANSMITTING,
79 | AVAILABLE
80 | } SLOT_DATA_STATUS;
81 |
82 | typedef struct
83 | {
84 | volatile bool data_status;
85 | volatile uint8_t data[SLOT_DATA_LENGTH];
86 | } SLOT_RAW_DATA;
87 |
88 | // low resolution timer
89 | volatile uint8_t frameLength = 15;
90 | volatile int8_t previousFrame = 0;
91 | volatile uint32_t frameCounter = 0;
92 |
93 |
94 | volatile uint8_t tx_data_counter;
95 | volatile uint8_t buffer_index;
96 |
97 | volatile SLOT_DATA_STATUS transmit_data_per_slot_status[NUMBER_OF_SLOT];
98 | volatile uint8_t transmit_data_per_slot_data[NUMBER_OF_SLOT][SLOT_DATA_LENGTH];
99 | volatile uint8_t gl_slot;
100 |
101 | void sbus_uart_init();
102 | void sbus_timer_init();
103 | void start_receiving();
104 | void enable_receiving();
105 | void enable_transmiting();
106 | void disable_receiving();
107 | void disable_transmiting();
108 | void start_transmit_sequencer(uint8_t frame_number);
109 | void sbus2_send_slot(uint8_t slot);
110 |
111 | void ISR_receive_timeout();
112 | void ISR_transmit();
113 |
114 | volatile void (*do_servo_pulls)(uint32_t counter);
115 |
116 | volatile void (*timer_ISR)();
117 |
118 | //*****************************************************************************
119 | //
120 | void SBUS2_uart_setup (void (*start_pulse)(uint32_t))
121 | {
122 | uint32_t counter = 640000;
123 | uint8_t response = 0x00;
124 |
125 | noInterrupts();
126 | sbus_uart_init();
127 | sbus_timer_init();
128 |
129 | PinBasOutput(RECEIVE_PIN);
130 | PinCasOutput(TRANSMIT_PIN);
131 | PinCasOutput(PIN_4);
132 |
133 | disable_transmiting();
134 | disable_receiving();
135 |
136 | UDR = 0xAA;
137 | response = 0x00;
138 | while(!(UCSRA & (1 << UDRE)));
139 |
140 | while ((counter > 1) && ( response != 0x55 ))
141 | {
142 | response = UDR;
143 | while ( UCSRA & (1 << RXC) );
144 | counter--;
145 | }
146 |
147 | do_servo_pulls = (volatile void (*)(uint32_t))start_pulse;
148 | start_receiving();
149 |
150 | if(response != 0x55 )
151 | {
152 | enable_receiving();
153 | }
154 | interrupts();
155 |
156 | }
157 | /*
158 | void SBUS2_uart_command_length(uint8_t length )
159 | {
160 | command_length = length;
161 | }
162 | */
163 |
164 | void sbus_uart_init()
165 | {
166 | // set clock divider
167 | #undef BAUD
168 | #define BAUD USART_BAUD
169 |
170 | #include <util/setbaud.h>
171 |
172 | UBRRH = UBRRH_VALUE;
173 | UBRRL = UBRRL_VALUE;
174 |
175 | #if USE_2X
176 | UCSRA |= (1 << U2X); // enable double speed operation
177 | #else
178 | UCSRA &= ~(1 << U2X); // disable double speed operation
179 | #endif
180 |
181 | // set 8E2
182 | UCSRC = (1 << UCSZ1) | (1 << UCSZ0);
183 | UCSRB &= ~(1 << UCSZ2);
184 |
185 | UCSRC |= (1 << UPM1);
186 | UCSRC |= (1 << USBS);
187 |
188 | // flush receive buffer
189 | while ( UCSRA & (1 << RXC) ) UDR;
190 |
191 | UCSRB |= (1 << RXEN);
192 | UCSRB |= (1 << RXCIE);
193 | UCSRB |= (1 << TXEN);
194 | UCSRB |= (1 << TXCIE);
195 | }
196 |
197 | void sbus_timer_init()
198 | {
199 | //memset( (void*)transmit_data_per_slot, 0, sizeof(transmit_data_per_slot));
200 | for(uint8_t i = 0; i < 32; i++)
201 | {
202 | transmit_data_per_slot_status[i] = EMPTY;
203 | }
204 |
205 | TCCR2B = 0x00; //disable Timer2 while we set it up
206 | TCNT2 = 0; //Reset Timer 0
207 | TIFR2 = 0x02; //Timer2 INT Flag Reg: Clear Timer Overflow Flag
208 | TIMSK2 = 0x03; //Timer2 INT Reg: Timer2 compare A
209 | TCCR2A = 0x02; //Timer2 Control Reg A: CTC
210 | }
211 |
212 | uint8_t SBUS_get_frame(uint8_t *frame)
213 | {
214 | if( frame_ready )
215 | {
216 | memcpy(frame, (void*)rxbuf, SBUS_FRAME_SIZE);
217 | frame_ready = false;
218 | return true;
219 | }
220 | else
221 | {
222 | return false;
223 | }
224 | }
225 |
226 | void start_receiving()
227 | {
228 | TCCR2B = 0x00; //disable Timer2 while we set it up
229 | buffer_index = 0;
230 | timer_ISR = (volatile void (*)())ISR_receive_timeout;
231 | TCNT2 = 0; //Reset Timer 0
232 | OCR2A = receive_timeout_timer;
233 | }
234 |
235 | inline void disable_receiving()
236 | {
237 | PinBOutput( RECEIVE_PIN, TRANSMIT_RECEIVE_DISABLE);
238 | }
239 |
240 | inline void enable_receiving()
241 | {
242 | PinCOutput( TRANSMIT_PIN, TRANSMIT_RECEIVE_DISABLE);
243 | PinBOutput( RECEIVE_PIN, TRANSMIT_RECEIVE_ENABLE);
244 | }
245 |
246 | inline void disable_transmiting()
247 | {
248 | PinCOutput( TRANSMIT_PIN, TRANSMIT_RECEIVE_DISABLE);
249 | }
250 |
251 | inline void enable_transmiting()
252 | {
253 | PinBOutput( RECEIVE_PIN, TRANSMIT_RECEIVE_DISABLE);
254 | PinCOutput( TRANSMIT_PIN, TRANSMIT_RECEIVE_ENABLE);
255 | }
256 |
257 | ISR(TIMER2_COMPA_vect)
258 | {
259 | timer_ISR();
260 | }
261 |
262 | inline void IncreaseTimer( int8_t frameNumber)
263 | {
264 | int8_t temp = (frameNumber - previousFrame) % NUMBER_OF_FRAMES;
265 | if (temp <= 0 )
266 | temp += NUMBER_OF_FRAMES;
267 | if (temp > 1)
268 | uart_lost_frame++;
269 | frameCounter += temp;
270 | previousFrame = frameNumber;
271 | }
272 |
273 | ISR (USART_RX_vect)
274 | {
275 | uint8_t cdata = 0;
276 |
277 | frame_ready = false;
278 | TCNT2 = 0; //Reset Timer 2 for new usart time of char
279 | //enable Timer2 Control Reg B: for receive timeout this is done here because we can only start the timeout after first bye is received
280 | TCCR2B = 0x03;
281 | cdata = UDR;
282 | rxbuf[buffer_index] = cdata;
283 | buffer_index++;
284 | if (buffer_index == SBUS_FRAME_SIZE)
285 | {
286 | frame_ready = true;
287 | disable_receiving();
288 | IncreaseTimer((cdata&0x30) >> 4);
289 | start_transmit_sequencer(((cdata&0x30) >> 4)); // frame number needed to select correct telemetry slot
290 |
291 | if (do_servo_pulls != NULL )
292 | {
293 | do_servo_pulls(frameCounter * frameLength);
294 | }
295 | buffer_index = 0;
296 | }
297 | }
298 |
299 |
300 | // receive timeout check for set packed length
301 | void ISR_receive_timeout()
302 | {
303 | /* if ( buffer_index == command_length )
304 | {
305 | // -1 don't add crc in crc :-)
306 | uint8_t crc = 0;
307 | //crc = crc_cal( (uint8_t*)rxbuf, command_length -1);
308 |
309 | if ( (crc == rxbuf[command_length -1]) || true )
310 | {
311 | disable_receiving(); // this puts the module in setup mode
312 | // setup command
313 | memcpy(command, (void*)rxbuf, command_length);
314 | command_received = true;
315 | }
316 | }
317 | */
318 | buffer_index = 0;
319 | }
320 |
321 | //****************************************************************
322 | //* TRANSMIT SEQUENCER
323 | //****************************************************************
324 |
325 | void ISR_transmit()
326 | {
327 | static uint8_t sequence_count = 1; // first sequence step delay will be filled in when the transmit sequence is enabled
328 | //Increments the interrupt counter
329 | TCNT2 = 0; // reset at the beginning so that there is no delay for the next segment of the sequence
330 |
331 | interrupts();
332 |
333 | if (sequence_count < 2 )
334 | {
335 | // don't do anything this is delay to the transmission slots
336 | OCR2A = transmit_sequence_timer[sequence_count];
337 | }
338 | else if (sequence_count < 10 ) // transmit slots
339 | {
340 | OCR2A = transmit_sequence_timer[sequence_count]; // first set next slot interrupt
341 | sbus2_send_slot((sequence_count-2) + (gl_current_frame * NUMBER_OF_SLOT_IN_FRAME) );
342 | }
343 | else if (sequence_count < 11 )
344 | {
345 | OCR2A = transmit_sequence_timer[sequence_count];
346 |
347 | }
348 | else if (sequence_count < 14 )
349 | {
350 | // delay to enabling receive again
351 | OCR2A = transmit_sequence_timer[sequence_count];
352 | }
353 | else if (sequence_count < 15 )
354 | {
355 | // delay to enabling receive again
356 | OCR2A = transmit_sequence_timer[sequence_count];
357 | frame_ready = false; // this will give ms to collect the servo data
358 | }
359 | else
360 | {
361 | // reset transmit sequencer
362 | TCCR2B = 0x00; //Disbale Timer2 while we set it up
363 | sequence_count = 0; // first sequence step delay will be filled in when the transmit sequence is enabled
364 |
365 | enable_receiving();
366 | start_receiving();
367 | }
368 | sequence_count++;
369 |
370 | TIFR2 = 0x00; //Timer2 INT Flag Reg: Clear Timer Overflow Flag
371 | };
372 |
373 | ISR(TIMER2_OVF_vect)
374 | {
375 | // for debugging should not occur
376 | overflow_counter++;
377 | };
378 |
379 |
380 | void start_transmit_sequencer(uint8_t frame_number)
381 | {
382 | //set transmit ISR
383 | timer_ISR = (volatile void (*)())ISR_transmit;
384 |
385 | OCR2A = transmit_sequence_timer[0]; //set first delay value
386 | TCCR2B = 0x03; //enable Timer2 Control Reg B: Timer Prescaler set to 128
387 |
388 | gl_current_frame = frame_number;
389 | }
390 |
391 |
392 | //****************************************************************
393 | //* TRANSMIT usart send
394 | //****************************************************************
395 | void sbus2_send_slot(uint8_t slot)
396 | {
397 | // if data available in slot then send it
398 | if ( transmit_data_per_slot_status[slot] == AVAILABLE )
399 | {
400 |
401 | transmit_data_per_slot_status[slot] = TRANSMITTING;
402 | enable_transmiting();
403 | //sending_slot = &transmit_data_per_slot[slot];
404 | gl_slot = slot;
405 | //send first byte
406 | UDR = transmit_data_per_slot_data[gl_slot][0]; // the reset will be done by TX ISR
407 | tx_data_counter = 1;
408 | }
409 | }
410 |
411 | ISR (USART_TX_vect)
412 | {
413 | interrupts();
414 | if (transmit_data_per_slot_status[gl_slot] != EMPTY)
415 | {
416 | if ( tx_data_counter < SLOT_DATA_LENGTH )
417 | {
418 | UDR = transmit_data_per_slot_data[gl_slot][tx_data_counter];
419 | tx_data_counter++;
420 | }
421 | else
422 | {
423 | // disable transmitter line and set data status to empty so that it can be written again
424 | disable_transmiting();
425 | transmit_data_per_slot_status[gl_slot] = EMPTY;
426 | }
427 | }
428 | }
429 |
430 | void SBUS2_transmit_telemetry_data( uint8_t slot, uint8_t data[SLOT_DATA_LENGTH] )
431 | {
432 | uint8_t swapped_slot = 0;
433 | if ( transmit_data_per_slot_status[slot] != TRANSMITTING )
434 | {
435 | //swap slot ID
436 | swapped_slot = swaps_slot_bits[slot % 8] << 5;
437 | memcpy( (void*)transmit_data_per_slot_data[slot], data, SLOT_DATA_LENGTH);
438 | transmit_data_per_slot_data[slot][0] &= 0x1F; // reset frame slot ID
439 | transmit_data_per_slot_data[slot][0] |= swapped_slot;
440 |
441 | transmit_data_per_slot_status[slot] = AVAILABLE;
442 | }
443 | }
444 |
445 | bool SBUS2_get_all_servo_data( uint16_t channels[16] )
446 | {
447 | if ( frame_ready )
448 | {
449 | uint8_t byte_in_sbus = 1;
450 | uint16_t bit_in_sbus = 0;
451 | uint8_t ch = 0;
452 | uint16_t bit_in_channel = 0;
453 | //uint16_t temp;
454 | uint8_t channel_data[UART_RXBUFSIZE];
455 | //noInterrupts();
456 | memcpy(channel_data, (void*)rxbuf, 24);
457 | //interrupts();
458 |
459 | for (uint8_t i=0; i<16; i++)
460 | channels[i] = 0;
461 |
462 | // process actual sbus data
463 | for (uint8_t i=0; i<176; i++)
464 | {
465 | //temp = 1<<bit_in_sbus;
466 | if (channel_data[byte_in_sbus] & (1<<bit_in_sbus))
467 | {
468 | //temp = (1<<bit_in_channel);
469 | channels[ch] |= (1<<bit_in_channel);
470 | }
471 | bit_in_sbus++;
472 | bit_in_channel++;
473 |
474 | if (bit_in_sbus == 8)
475 | {
476 | bit_in_sbus =0;
477 | byte_in_sbus++;
478 | }
479 | if (bit_in_channel == 11)
480 | {
481 | bit_in_channel =0;
482 | ch++;
483 | }
484 | }
485 | // DigiChannel 1
486 | if (channel_data[23] & (1<<0))
487 | {
488 | channels[16] = 1;
489 | }
490 | else
491 | {
492 | channels[16] = 0;
493 | }
494 | // DigiChannel 2
495 | if (channel_data[23] & (1<<1))
496 | {
497 | channels[17] = 1;
498 | }
499 | else
500 | {
501 | channels[17] = 0;
502 | }
503 |
504 | return true;
505 | }
506 | else
507 | {
508 | return false;
509 | }
510 | }
511 |
512 |
513 | void SBUS2_get_status( uint16_t *uart_dropped_frame, bool *transmision_dropt_frame, bool *failsave )
514 | {
515 | if (frameCounter < 60)
516 | {
517 | uart_lost_frame = 0;
518 | }
519 | *uart_dropped_frame = uart_lost_frame;
520 | *transmision_dropt_frame = rxbuf[23] & 0x20 ? true : false;
521 | *failsave = rxbuf[23] & 0x10 ? true : false;
522 | }
523 |
524 | /*
525 | bool SBUS2_get_command( uint8_t *p_command )
526 | {
527 | if (command_received)
528 | {
529 | memcpy(p_command, command, command_length);
530 | command_received = false;
531 |
532 | return true;
533 | }
534 | return false;
535 | }
536 |
537 |
538 | void SBUS2_send_command( uint8_t *p_command )
539 | {
540 | int index = 0;
541 |
542 | for( index = 0; index < command_length; index++)
543 | {
544 | while( !(UCSRA & (1<<UDRE))){}
545 | UDR = p_command[index];
546 | }
547 | }
548 | */
549 |
550 | int16_t SBUS2_get_servo_data( uint8_t channel )
551 | {
552 | uint8_t byte_in_sbus = 1;
553 | uint16_t bit_in_sbus = 0;
554 | uint8_t ch = 0;
555 | uint16_t bit_in_channel = 0;
556 | uint8_t channel_data[UART_RXBUFSIZE];
557 |
558 | uint16_t servo = 0;
559 | uint8_t start_bit = 0;
560 |
561 | //noInterrupts();
562 | memcpy(channel_data, (void*)rxbuf, 24);
563 | //interrupts();
564 |
565 | if ( frame_ready )
566 | {
567 | start_bit = channel * SBUS_CHANNEL_SIZE ;
568 | bit_in_sbus = start_bit % 8;
569 | byte_in_sbus = (start_bit / 8) + 1;
570 |
571 | // process actual sbus data
572 | for (uint8_t i=start_bit; i<(start_bit+11); i++)
573 | {
574 | if (channel_data[byte_in_sbus] & (1<<bit_in_sbus))
575 | {
576 | servo |= (1<<bit_in_channel);
577 | }
578 | bit_in_sbus++;
579 | bit_in_channel++;
580 |
581 | if (bit_in_sbus == 8)
582 | {
583 | bit_in_sbus =0;
584 | byte_in_sbus++;
585 | }
586 | if (bit_in_channel == 11)
587 | {
588 | bit_in_channel =0;
589 | ch++;
590 | }
591 | }
592 | return (int16_t)servo;
593 | }
594 | else
595 | {
596 | return -1;
597 | }
598 | }
