1 | // ----------------------------------------------------------------------
2 |
3 | #include <SPI.h>
4 | #include <Ethernet.h>
5 | #include <stdio.h>
6 | #define MAX_PIN 13 //UNO
7 |
8 | // IP AND MAC ADRESS
9 | #define PORT 7777 //-> Type this under "TCP-Port" in the App
10 | byte mac[] = {0x90, 0xA2, 0xDA, 0x10, 0xC1, 0x9C}; //If you're using more than one Arduino, set different Mac adresses for each board!
11 | IPAddress ip(192, 168,1, 168);
12 |
13 | String inputstream = "";
14 | String answer = "";
15 | String text = "";
16 | String command = "";
17 | String serialInput = "";
18 |
19 | int pin = 0;
20 | unsigned long value = 0;
21 | unsigned long ticks[MAX_PIN]; //TICKS FOR EACH OUTPUT. USED IF AN OFFTIMER FOR AN OUTPUT HAS BEEN SET. 1 TICK = 100ms
22 | unsigned long ticks_at_command; //IF WE GET NO COMMAND FOR XX SECONDS, THEN STOP CLIENT.
23 |
24 |
25 | char charBuf[250];
26 |
27 | EthernetServer server = (PORT);
28 | boolean verbunden = false;
29 | EthernetClient client;
30 |
31 | boolean pwm[MAX_PIN];
32 |
33 | //Variables for the PWM-Values. The PWM-Values are always between 0 and 255, no matter, what Min/Max-Values you have set in the App.
34 | //NEVER CHANGE!!! The Position of the slider depends on that value.
35 | //(You can't read pwm values directly from a pin.)
36 | int pwm_value[MAX_PIN];
37 |
38 |
39 |
40 | //________________________________________________________________________________________________________________________________________________
41 | void setup() {
42 |
43 | /*
44 | Arduino communicates with the shield using the SPI bus.
45 | This is on digital pins 11, 12, and 13 on the Uno and pins 50, 51, and 52 on the Mega.
46 | On both boards, pin 10 is used as SS.
47 | On the Mega, the hardware SS pin, 53, is not used to select the W5500, but it must be kept as an output or the SPI interface won't work.
48 | */
49 |
50 |
51 | //SET ALL DIGITAL PINS AS OUTPUT
52 | //ATTENTION: DO NOT USE 11,12,13 ON THE UNO WITH ETHERNET SHIELD!
53 |
54 | for (int i = 0;i<MAX_PIN;i++){
55 | if ((i < 10) || (i >13)) pinMode(i, OUTPUT);
56 | ticks[i] = 0;
57 | }
58 |
59 | // start the Ethernet connection:
60 | Ethernet.begin(mac,ip);
61 | server.begin();
62 |
63 | //START SERIAL 0 (Debug Port)
64 | //Serial.begin(2400); //The Serial Port occupies Outputs 0 & 1
65 |
66 | }
67 |
68 |
69 |
70 |
71 | //________________________________________________________________________________________________________________________________________________
72 | void loop() {
73 |
74 | client = server.available();
75 |
76 |
77 | if(client.available())
78 | {
79 |
80 | ticks_at_command = millis();
81 |
82 | char zeichen = client.read();
83 |
84 | inputstream += zeichen;
85 |
86 |
87 | while (inputstream.indexOf(';')>0){
88 |
89 |
90 | inputstream.trim();
91 |
92 | //ALL COMMANDS COMING FROM THE APP ARE CONSTRUCTED AS FOLLOWS:
93 | // 4 CHARS COMMAND (SETD = Set digital Pin ,GETD = Get digital Pin, OFFT = Set Offtimer,SETP = Set PWM, GETP = Get PWM)
94 | // x CHARS PIN (0,1,2,3...51,52,53)
95 | // 1 POINT .
96 | // x CHARS VALUE (0 = Off, 1 = On, 0-255 = PWM Value)
97 | // 1 SEMICOLON ;
98 |
99 | //FOR EXAMPLE:
100 |
101 | //SETD1.1; Set digital Pin 1 on
102 | //SETD3.0; Set digital Pin 3 off
103 | //SETP15.255; Set PWM for Pin 15 to 255
104 | //OFFT17.200; Set offtimer for pin 17 to 200ticks (20 seconds)
105 | //GETA5; Get value of analogue Pin 5
106 |
107 | command = inputstream.substring(0,4);
108 | value = 0;
109 | pin = -1;
110 |
111 |
112 | value = inputstream.substring(inputstream.lastIndexOf('.')+1).toInt();
113 | pin = inputstream.substring(4,inputstream.lastIndexOf('.')).toInt();
114 |
115 |
116 | //UNKNOWN COMMAND?
117 | if ((command != "SETD" && command != "GETD" && command != "SETP" && command != "GETA" && command != "OFFT" && command != "GETP") || pin == -1 ){
118 | inputstream = "";
119 | command = "";
120 | value = 0;
121 | pin = 0;
122 | }
123 |
124 |
125 |
126 | //GET STATE OF DIGITAL OUTPUT (GETDXX). ANSWER: "DXX.0;" OR "DXX.1;"
127 | if (command == "GETD"){
128 | answer += "D" + String(pin) + "." + digitalRead(pin) + ";";
129 | }
130 |
131 | //GET STATE OF ANALOG INPUT (GETAXX). ANSWER: "AXX.YYY;" YYY = 0 to 1023
132 | else if (command == "GETA"){
133 | answer += "A" + String(pin) + "." + analogRead(pin) + ";";
134 | }
135 | //SET DIGITAL OUTPUT ON (SETDXX.1) OR OFF (SETDXX.0). ANSWER: "DXX.0;" OR "DXX.1;"
136 | else if (command == "SETD"){
137 | ticks[pin] = 0;
138 | digitalWrite(pin,value);
139 | answer += "D" + String(pin) + "." + digitalRead(pin)+";";
140 |
141 | }
142 |
143 | //SET OFFTIMER FOR A DIGITAL OUTPUT (OFFTXX.SS) <- XX = PIN, SS = 1/10Sec (1 SECOND = 10), ANSWER: "DXX.1;"
144 | else if (command == "OFFT"){
145 | digitalWrite(pin,1);
146 | ticks[pin] = millis() + (value*100);
147 | answer += "D" + String(pin) + ".1;";//digitalRead(pin);
148 | }
149 |
150 | //SET PWM VALUE (SETPXX.YYY)
151 | else if (command == "SETP"){
152 | analogWrite(pin,value);
153 | pwm_value[pin] = value;
154 | answer += "P" + String(pin) + "." + String(pwm_value[pin], DEC) + ";";
155 |
156 |
157 | }
158 | //GET PWM VALUE (GETPXX). ANSWER: "PXX.YYY;"
159 | else if (command == "GETP"){
160 |
161 | answer += "P" + String(pin) + "." + String(pwm_value[pin], DEC) + ";";
162 |
163 | }
164 |
165 |
166 | inputstream = inputstream.substring(inputstream.indexOf(';')+1);
167 |
168 | }loop;//<-(While inputstream Contains ';')
169 |
170 |
171 | //clear Input Buffer
172 | client.flush();
173 |
174 |
175 | }//<-End if(client.available())
176 |
177 |
178 | //NO COMMANDS FOR 5 SECONDS->RESTART ETHERNET SERVER. (just "client.stop()" may cause problems)
179 | if ((millis() > ticks_at_command + 5000) && ticks_at_command > 0) {
180 | ticks_at_command = 0;
181 | client.stop();
182 | Ethernet.begin(mac,ip);
183 | server.begin();
184 | }
185 |
186 |
187 | //CHECK FOR OFFTIMERS
188 | for (int i = 0; i< MAX_PIN; i++){
189 | if ((millis() >= ticks[i]) && (ticks[i] > 0)){
190 | ticks[i] = 0;
191 | digitalWrite(i,0);
192 | text = String(i);
193 | answer +="D" + text + ".0;";
194 | }
195 | }
196 |
197 |
198 | //SEND ANSWER TO PHONE
199 | if (answer != ""){
200 |
201 | answer.toCharArray(charBuf, answer.length()+1);
202 | server.write(charBuf,answer.length()); //Writes to all Clients connected
203 | answer = "";
204 |
205 | }
206 |
207 | }//<-MAIN LOOP
208 |
209 | //________________________________________________________________________
