Die Installation endet untr Linux mint und nach dem Starten des Installers mit folgendem Log: ----------------------------------------- [2019-03-23 11:09:24] Executing bootstrap tasks [2019-03-23 11:09:24] Java(TM) SE Runtime Environment 8.0.5.25 - pxa6480sr5fp25-20181030_01(SR5 FP25) [2019-03-23 11:09:24] Product org.eclipse.papyrusrt.products.papyrus-rt.current [2019-03-23 11:09:24] Bundle org.eclipse.oomph.setup 1.8.0.v20170408-0745, build=3098, branch=e12ba4db800d8f30e47fd2525429e2f55baf9396 [2019-03-23 11:09:24] Bundle org.eclipse.oomph.setup.core 1.8.0.v20170531-0903, build=3098, branch=e12ba4db800d8f30e47fd2525429e2f55baf9396 [2019-03-23 11:09:24] Bundle org.eclipse.oomph.setup.p2 1.8.0.v20170318-0419, build=3098, branch=e12ba4db800d8f30e47fd2525429e2f55baf9396 [2019-03-23 11:09:24] Performing P2 Director (Papyrus-RT) [2019-03-23 11:09:24] Offline = false [2019-03-23 11:09:24] Mirrors = true [2019-03-23 11:09:24] Resolving 18 requirements from 8 repositories to /home/rfr/eclipse/papyrus-rt-current/Papyrus-RT [2019-03-23 11:09:24] Requirement org.eclipse.papyrus.sdk.feature.feature.group [3.0.0,3.0.1) [2019-03-23 11:09:24] Requirement org.eclipse.platform.ide [2019-03-23 11:09:24] Requirement org.eclipse.platform.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.rcp.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.oomph.setup.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.papyrusrt.feature.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.papyrusrt.codegen-feature.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.papyrusrt.umlrt.cpp.feature.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.papyrusrt.xtumlrt.xtext.feature.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.papyrusrt.rts-feature.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.papyrusrt.umlrt.migration.rsa.feature.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.papyrusrt.umlrt.tooling.compare.feature.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.cdt.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.egit.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.emf.compare.diagram.papyrus.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.emf.compare.egit.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.emf.compare.rcp.ui.feature.group [2019-03-23 11:09:24] Requirement org.eclipse.papyrus.sdk.feature.feature.group [2019-03-23 11:09:24] Repository http://download.eclipse.org/papyrus-rt/updates/releases/oxygen/ [2019-03-23 11:09:24] Repository http://download.eclipse.org/modeling/emf/compare/updates/logical/emf.compare/integration/3.3.1.201707041528/ [2019-03-23 11:09:24] Repository http://download.eclipse.org/egit/updates/ [2019-03-23 11:09:24] Repository http://download.eclipse.org/releases/oxygen/ [2019-03-23 11:09:24] Repository http://download.eclipse.org/modeling/mdt/papyrus/components/designer/neon/1.0.4_papyrus-designer-neon_494/ [2019-03-23 11:09:24] Repository http://download.eclipse.org/modeling/mdt/papyrus/interoperability/rsa/updates/oxygen/1.4.0/ [2019-03-23 11:09:24] Repository http://download.eclipse.org/oomph/updates/release/latest/ [2019-03-23 11:09:24] Repository http://download.eclipse.org/oomph/updates/milestone/latest [2019-03-23 11:09:26] ERROR: org.eclipse.equinox.p2.metadata.repository code=1000 No repository found at http://download.eclipse.org/modeling/mdt/papyrus/interoperability/rsa/updates/oxygen/1.4.0/. at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryMan ager.fail(AbstractRepositoryManager.java:395) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.jav a:90) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessor Impl.java:55) at java.lang.reflect.Method.invoke(Method.java:508) at org.eclipse.oomph.util.ReflectUtil.invokeMethod(ReflectUtil.java:117) at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.fail(Caching RepositoryManager.java:353) at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadReposito ry(CachingRepositoryManager.java:244) at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager$Metadata.loa dRepository(CachingRepositoryManager.java:476) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryMa nager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryMa nager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$RepositoryLoad er$Worker.perform(ProfileTransactionImpl.java:1613) at org.eclipse.oomph.util.WorkerPool$Worker.run(WorkerPool.java:428) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56) [2019-03-23 11:09:26] ------------------------------------ Was muss ich tun, um diesen Fehler zu beheben? Gruss Robert
Muss man das Ding überhaupt installieren? Runterladen, entpacken und im Prinzip ist man schon fertig. Und java braucht man dafür.
Der installer wird wohl ohne Java nicht laufen, wenn er aber Fehlerlistings produzieren kann, tut er genau das. Der Wurm steckt also woanders.
R. F. schrieb: > [2019-03-23 11:09:26] ERROR: org.eclipse.equinox.p2.metadata.repository > code=1000 No repository found at > http://download.eclipse.org/modeling/mdt/papyrus/interoperability/rsa/updates/oxygen/1.4.0/. repositories nicht mehr vorhanden?
zitter_ned_aso schrieb: > Runterladen, entpacken und im > Prinzip ist man schon fertig. Das habe ich jetzt selbst noch mal ausprobiert. Du brauchst wirklich keinen Installer, Repositories, etc.. 1) java manuell installieren Bei mir liefert
1 | java -version |
die Ausgabe:
1 | openjdk version "10.0.2" 2018-07-17 |
2) von der Webseite https://www.eclipse.org/downloads/packages/ Package "Eclipse IDE for C/C++ Developers" (Linux) runterladen, entpacken und schon ist man fertig. Du kannst dann in das eclipse-Verzeichnis wechselt und mit ./eclipse das Programm starten. Aktualisieren kannst du es übers Hilfe-Menü (Help->Check for Updates). Willst du das Programm per Desktop-Launcher starten, dann kannst du dir die Skripts hier anschauen: https://wiki.ubuntuusers.de/Eclipse/ Da kann man auch das Home-Verzeichnis festlegen. Obwohl Eclipse von sich aus beim Starten nach diesem Verzeichnis fragt.
also: Terminal und dann: rfr@rfr-Mint:~$ java -version java version "1.8.0_191" Java(TM) SE Runtime Environment (build 8.0.5.25 - pxa6480sr5fp25-20181030_01(SR5 FP25)) IBM J9 VM (build 2.9, JRE 1.8.0 Linux amd64-64-Bit Compressed References 20181029_400846 (JIT enabled, AOT enabled) OpenJ9 - c5c78da OMR - 3d5ac33 IBM - 8c1bdc2) JCL - 20181022_01 based on Oracle jdk8u191-b26 hab ich versucht, eigentlich sollte es gehen, aber das openjdk ist nicht drauf. Was fehlt? Gruss Robert
