Hallo ich habe hier im LAN einen Arduino (Mega) mit Ethernet-Lan W5100, der seine Zeit von einem Zeitserver der auf einem Raspberry im gleichen lan installiert ist, bekommen soll hängen im 192.168.2.0 LAN alle h Auf dem Raspberry sieht die ntp.con so aus # /etc/ntp.conf, configuration for ntpd; see ntp.conf(5) for help driftfile /var/lib/ntp/ntp.drift # Enable this if you want statistics to be logged. #statsdir /var/log/ntpstats/ statistics loopstats peerstats clockstats filegen loopstats file loopstats type day enable filegen peerstats file peerstats type day enable filegen clockstats file clockstats type day enable # You do need to talk to an NTP server or two (or three). #server ntp.your-provider.example # pool.ntp.org maps to about 1000 low-stratum NTP servers. Your server will # pick a different set every time it starts up. Please consider joining the # pool: <http://www.pool.ntp.org/join.html> pool ntp1.hetzner.de iburst pool ntp2.hetzner.com iburst pool 0.de.pool.ntp.org iburst pool 1.de.pool.ntp.org iburst # Access control configuration; see /usr/share/doc/ntp-doc/html/accopt.html for # details. The web page <http://support.ntp.org/bin/view/Support/AccessRestrictions> # might also be helpful. # # Note that "restrict" applies to both servers and clients, so a configuration # that might be intended to block requests from certain clients could also end # up blocking replies from your own upstream servers. # By default, exchange time with everybody, but don't allow configuration. restrict -4 default kod notrap nomodify nopeer noquery limited restrict -6 default kod notrap nomodify nopeer noquery limited # Local users may interrogate the ntp server more closely. restrict 127.0.0.1 restrict ::1 # Needed for adding pool entries restrict source notrap nomodify noquery # Clients from this (example!) subnet have unlimited access, but only if # cryptographically authenticated. restrict 192.168.2.0 mask 255.255.255.0 notrust # If you want to provide time to your local subnet, change the next line. # (Again, the address is an example only.) broadcast 192.168.2.255 # If you want to listen to time broadcasts on your local subnet, de-comment the # next lines. Please do this only if you trust everybody on the network! #disable auth #broadcastclient mit tcpdump erhalte ich folgendes sudo tcpdump -vvveni any udp port 123 tcpdump: listening on any, link-type LINUX_SLL (Linux cooked), capture size 262144 bytes 16:42:54.783503 In de:ad:be:ef:fe:ed ethertype IPv4 (0x0800), length 92: (tos 0x0, ttl 128, id 10574, offset 0, flags [DF], proto UDP (17), length 76) 192.168.2.9.8888 > 192.168.2.10.123: [udp sum ok] NTPv4, length 48 Client, Leap indicator: clock unsynchronized (192), Stratum 0 (unspecified), poll 6 (64s), precision -20 Root Delay: 0.000000, Root dispersion: 0.000000, Reference-ID: (unspec) Reference Timestamp: 0.000000000 Originator Timestamp: 0.000000000 Receive Timestamp: 0.000000000 Transmit Timestamp: 0.000000000 Originator - Receive Timestamp: 0.000000000 Originator - Transmit Timestamp: 0.000000000 16:43:05.844961 In de:ad:be:ef:fe:ed ethertype IPv4 (0x0800), length 92: (tos 0x0, ttl 128, id 10576, offset 0, flags [DF], proto UDP (17), length 76) 192.168.2.9.8888 > 192.168.2.10.123: [udp sum ok] NTPv4, length 48 Client, Leap indicator: clock unsynchronized (192), Stratum 0 (unspecified), poll 6 (64s), precision -20 Root Delay: 0.000000, Root dispersion: 0.000000, Reference-ID: (unspec) Reference Timestamp: 0.000000000 Originator Timestamp: 0.000000000 Receive Timestamp: 0.000000000 Transmit Timestamp: 0.000000000 Originator - Receive Timestamp: 0.000000000 Originator - Transmit Timestamp: 0.000000000 16:43:08.558536 Out b8:27:eb:67:ec:f4 ethertype IPv4 (0x0800), length 92: (tos 0xb8, ttl 64, id 37665, offset 0, flags [DF], proto UDP (17), length 76) 192.168.2.10.123 > 192.168.2.255.123: [bad udp cksum 0x86a3 -> 0xf154!] NTPv4, length 48 Broadcast, Leap indicator: (0), Stratum 3 (secondary reference), poll 6 (64s), precision -18 Root Delay: 0.021270, Root dispersion: 0.056213, Reference-ID: 94.16.115.123 Reference Timestamp: 3766487654.572646037 (2019/05/10 16:34:14) Originator Timestamp: 0.000000000 Receive Timestamp: 0.000000000 Transmit Timestamp: 3766488188.558358062 (2019/05/10 16:43:08) Originator - Receive Timestamp: 0.000000000 Originator - Transmit Timestamp: 3766488188.558358062 (2019/05/10 16:43:08) 16:43:16.906417 In de:ad:be:ef:fe:ed ethertype IPv4 (0x0800), length 92: (tos 0x0, ttl 128, id 10578, offset 0, flags [DF], proto UDP (17), length 76) 192.168.2.9.8888 > 192.168.2.10.123: [udp sum ok] NTPv4, length 48 Client, Leap indicator: clock unsynchronized (192), Stratum 0 (unspecified), poll 6 (64s), precision -20 Root Delay: 0.000000, Root dispersion: 0.000000, Reference-ID: (unspec) Reference Timestamp: 0.000000000 Originator Timestamp: 0.000000000 Receive Timestamp: 0.000000000 Transmit Timestamp: 0.000000000 Originator - Receive Timestamp: 0.000000000 Originator - Transmit Timestamp: 0.000000000 der Code auf dem arduino sieht so aus /* Udp NTP Client Get the time from a Network Time Protocol (NTP) time server Demonstrates use of UDP sendPacket and ReceivePacket For more on NTP time servers and the messages needed to communicate with them, see http://en.wikipedia.org/wiki/Network_Time_Protocol created 4 Sep 2010 by Michael Margolis modified 9 Apr 2012 by Tom Igoe modified 02 Sept 2015 by Arturo Guadalupi This code is in the public domain. */ #include <SPI.h> #include <Ethernet.h> #include <EthernetUdp.h> // Enter a MAC address for your controller below. // Newer Ethernet shields have a MAC address printed on a sticker on the shield byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; IPAddress ip(192, 168, 2, 9); IPAddress gateway(192,168,2, 1); IPAddress subnet(255, 255, 255, 0); IPAddress dnsServer(192,168,2, 1); EthernetClient client; unsigned int localPort = 8888; // local port to listen for UDP packets const char timeServer[] = "printer2"; // time.nist.gov NTP server const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets // A UDP instance to let us send and receive packets over UDP EthernetUDP Udp; void setup() { // You can use Ethernet.init(pin) to configure the CS pin Ethernet.init(10); // Most Arduino shields //Ethernet.init(5); // MKR ETH shield //Ethernet.init(0); // Teensy 2.0 //Ethernet.init(20); // Teensy++ 2.0 //Ethernet.init(15); // ESP8266 with Adafruit Featherwing Ethernet //Ethernet.init(33); // ESP32 with Adafruit Featherwing Ethernet // Open serial communications and wait for port to open: Serial.begin(9600); while (!Serial) { ; // wait for serial port to connect. Needed for native USB port only } // start Ethernet and UDP Ethernet.begin(mac, ip, dnsServer, gateway, subnet); Udp.begin(localPort); } void loop() { sendNTPpacket(timeServer); // send an NTP packet to a time server // wait to see if a reply is available delay(1000); if (Udp.parsePacket()) { // We've received a packet, read the data from it Udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer // the timestamp starts at byte 40 of the received packet and is four bytes, // or two words, long. First, extract the two words: unsigned long highWord = word(packetBuffer[40], packetBuffer[41]); unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]); // combine the four bytes (two words) into a long integer // this is NTP time (seconds since Jan 1 1900): unsigned long secsSince1900 = highWord << 16 | lowWord; Serial.print("Seconds since Jan 1 1900 = "); Serial.println(secsSince1900); // now convert NTP time into everyday time: Serial.print("Unix time = "); // Unix time starts on Jan 1 1970. In seconds, that's 2208988800: const unsigned long seventyYears = 2208988800UL; // subtract seventy years: unsigned long epoch = secsSince1900 - seventyYears; // print Unix time: Serial.println(epoch); // print the hour, minute and second: Serial.print("The UTC time is "); // UTC is the time at Greenwich Meridian (GMT) Serial.print((epoch % 86400L) / 3600); // print the hour (86400 equals secs per day) Serial.print(':'); if (((epoch % 3600) / 60) < 10) { // In the first 10 minutes of each hour, we'll want a leading '0' Serial.print('0'); } Serial.print((epoch % 3600) / 60); // print the minute (3600 equals secs per minute) Serial.print(':'); if ((epoch % 60) < 10) { // In the first 10 seconds of each minute, we'll want a leading '0' Serial.print('0'); } Serial.println(epoch % 60); // print the second } // wait ten seconds before asking for the time again delay(10000); Ethernet.maintain(); } // send an NTP request to the time server at the given address void sendNTPpacket(const char * address) { // set all bytes in the buffer to 0 memset(packetBuffer, 0, NTP_PACKET_SIZE); // Initialize values needed to form NTP request // (see URL above for details on the packets) packetBuffer[0] = 0b11100011; // LI, Version, Mode packetBuffer[1] = 0; // Stratum, or type of clock packetBuffer[2] = 6; // Polling Interval packetBuffer[3] = 0xEC; // Peer Clock Precision // 8 bytes of zero for Root Delay & Root Dispersion packetBuffer[12] = 49; packetBuffer[13] = 0x4E; packetBuffer[14] = 49; packetBuffer[15] = 52; // all NTP fields have been given values, now // you can send a packet requesting a timestamp: Udp.beginPacket(address, 123); // NTP requests are to port 123 Udp.write(packetBuffer, NTP_PACKET_SIZE); Udp.endPacket(); } im Terminal erhalte ich jedoch keine Ausgabe. Er bekommt also irgendwie die Zeit nicht korrekt sieht da jemand den Fehler den ich machte? Grüße Jürgen
Jürgen schrieb: > der Code auf dem arduino Du hattest keine Lust, deinen Code in einem File an dein Posting zu hängen. Dann wäre er gut leserlich von der Forensoftware dargestellt worden. Einrückungen sind für dich auch Luxus. So ist das alles deutlich schlechter lesbar und macht dein Posting auch noch elendig lang. Erwartest du dann Lust beim Leser, sich das genau anzusehen?
Hallo, "printer2" als Timeserver ist nicht gerade ein RFC-gerechter Name. Sicher das der von dem DNS im Stack aufgelöst werden kann? Sascha
Vermutlich kann der TO kein Englisch. Sonst waere er wohl schon selber auf die Fehler in seiner Konfiguration gekommen. > "printer2" als Timeserver ist nicht gerade ein RFC-gerechter Name. > Sicher das der von dem DNS im Stack aufgelöst werden kann? Das scheint ja noch zu klappen.
Sascha W. schrieb: > "printer2" als Timeserver ist nicht gerade ein RFC-gerechter Name. > Sicher das der von dem DNS im Stack aufgelöst werden kann? mmmhh... ok da kannst du recht haben das meine lokale Namensauflösung nicht funktioniert. vom Win7 Rechner kann ich diesen Namen jedenfalls anpingen. Ganz ehrlich ... ich wusste nicht genau wie ich die IP-Adresse der Variablen korrekt mitteile. Werde ich gleich ändern wenn ich weiss wie ich die zeile ändern muss const char timeServer[] = "printer2"; // time.nist.gov NTP server ps. sorry für den langen unformatierten Text... wusste nicht das wenn ich es als File hochlade es dann sauber in den Text formatiert wird...
... schrieb: > Vermutlich kann der TO kein Englisch. Sonst waere er wohl schon > selber auf die Fehler in seiner Konfiguration gekommen. dann gebe mir doch bitte einen tipp wonach ich suchen soll ... ich vermute es liegt wohl an der ntp.conf beim Raspberry oder? Kleine Hilfe von Dir möglich?
... schrieb: > Vermutlich kann der TO kein Englisch. Sonst waere er wohl schon > selber auf die Fehler in seiner Konfiguration gekommen. ok ok... habe wahrscheinlich ein paar dicke Fehler in der ntp.conf habe nun in der ntp.conf das geändert... # If you want to listen to time broadcasts on your local subnet, de-comment the # next lines. Please do this only if you trust everybody on the network! disable auth broadcastclient nun kommt in der tcpdump ausgabe folgendes 192.168.2.10.123 > 144.76.60.190.123: [bad udp cksum 0x9006 -> 0x7f94!] NTPv4, length 48 Client, Leap indicator: (0), Stratum 3 (secondary reference), poll 6 (64s), precision -18 Root Delay: 0.016799, Root dispersion: 0.199172, Reference-ID: 195.50.171.101 Reference Timestamp: 3766505836.883575895 (2019/05/10 21:37:16) Originator Timestamp: 3766505896.881202259 (2019/05/10 21:38:16) Receive Timestamp: 3766505896.888573260 (2019/05/10 21:38:16) Transmit Timestamp: 3766505898.871441292 (2019/05/10 21:38:18) Originator - Receive Timestamp: +0.007371001 Originator - Transmit Timestamp: +1.990239033 21:38:18.888973 In 5c:49:79:67:0e:eb ethertype IPv4 (0x0800), length 92: (tos 0x0, ttl 54, id 11264, offset 0, flags [DF], proto UDP (17), length 76) 144.76.60.190.123 > 192.168.2.10.123: [udp sum ok] NTPv4, length 48 Server, Leap indicator: (0), Stratum 2 (secondary reference), poll 6 (64s), precision -24 Root Delay: 0.011550, Root dispersion: 0.031661, Reference-ID: 131.188.3.221 Reference Timestamp: 3766504772.918602548 (2019/05/10 21:19:32) Originator Timestamp: 3766505898.871441292 (2019/05/10 21:38:18) Receive Timestamp: 3766505898.881186940 (2019/05/10 21:38:18) Transmit Timestamp: 3766505898.881243871 (2019/05/10 21:38:18) Originator - Receive Timestamp: +0.009745648 Originator - Transmit Timestamp: +0.009802579 21:38:20.871560 Out b8:27:eb:67:ec:f4 ethertype IPv4 (0x0800), length 92: (tos 0xb8, ttl 64, id 57525, offset 0, flags [DF], proto UDP (17), length 76) 192.168.2.10.123 > 144.76.60.190.123: [bad udp cksum 0x9006 -> 0x6fc3!] NTPv4, length 48 Client, Leap indicator: (0), Stratum 3 (secondary reference), poll 6 (64s), precision -18 Root Delay: 0.016799, Root dispersion: 0.199203, Reference-ID: 195.50.171.101 Reference Timestamp: 3766505836.883575895 (2019/05/10 21:37:16) Originator Timestamp: 3766505898.881243871 (2019/05/10 21:38:18) Receive Timestamp: 3766505898.888976272 (2019/05/10 21:38:18) Transmit Timestamp: 3766505900.871440106 (2019/05/10 21:38:20) Originator - Receive Timestamp: +0.007732400 Originator - Transmit Timestamp: +1.990196234 21:38:20.890073 In 5c:49:79:67:0e:eb ethertype IPv4 (0x0800), length 92: (tos 0x0, ttl 54, id 11490, offset 0, flags [DF], proto UDP (17), length 76) 144.76.60.190.123 > 192.168.2.10.123: [udp sum ok] NTPv4, length 48 Server, Leap indicator: (0), Stratum 2 (secondary reference), poll 6 (64s), precision -24 Root Delay: 0.011550, Root dispersion: 0.031692, Reference-ID: 131.188.3.221 Reference Timestamp: 3766504772.918602548 (2019/05/10 21:19:32) Originator Timestamp: 3766505900.871440106 (2019/05/10 21:38:20) Receive Timestamp: 3766505900.881166210 (2019/05/10 21:38:20) Transmit Timestamp: 3766505900.881216619 (2019/05/10 21:38:20) Originator - Receive Timestamp: +0.009726104 Originator - Transmit Timestamp: +0.009776513 21:38:28.689154 In de:ad:be:ef:fe:ed ethertype IPv4 (0x0800), length 92: (tos 0x0, ttl 128, id 6, offset 0, flags [DF], proto UDP (17), length 76) 192.168.2.9.8888 > 192.168.2.10.123: [udp sum ok] NTPv4, length 48 Client, Leap indicator: clock unsynchronized (192), Stratum 0 (unspecified), poll 6 (64s), precision -20 Root Delay: 0.000000, Root dispersion: 0.000000, Reference-ID: (unspec) Reference Timestamp: 0.000000000 Originator Timestamp: 0.000000000 Receive Timestamp: 0.000000000 Transmit Timestamp: 0.000000000 Originator - Receive Timestamp: 0.000000000 Originator - Transmit Timestamp: 0.000000000 das scheint es aber noch nicht ganz gewesen zu sein....
... schrieb: > Vermutlich kann der TO kein Englisch. Sonst waere er wohl schon > selber auf die Fehler in seiner Konfiguration gekommen. es geht nun... muss nur noch was am Adruino ändern da die Zeit nicht die EU-ZEIT ist... und brauch auch noch das Datum
restrict 192.168.2.0 mask 255.255.255.0 notrust ===> restrict 192.168.2.0 mask 255.255.255.0
Tippgeber schrieb: > restrict 192.168.2.0 mask 255.255.255.0 Tippgeber schrieb: > restrict 192.168.2.0 mask 255.255.255.0 Danke kann mir jemand erklären wie ich das zu verstehen habe wenn mein Zeitserver schon die korrekte EU-Zeit hat, der Arduino den Zeitserver abfragt und er dann immer noch keine Sommerzeit ausgibt? ich vermute das hat was mit der UNIX-zeit zu tun die dann wohl erst vom Arduino umgerechnet wird. gibt es hierfür einen einfache lib die ich dazwischenschalten kann die dies übernimmt?
NTP macht immer UTC. Auch die Systemzeit (RTC) sollte immer UTC sein. Alles andere führt ins Chaos. Erst eine gesetzte TZ in Verbindung mit dem System zeigt lokale Zeit.
