Im trying to generate PWM signals. Why its not showing any contents' in
ILA core?
Differential clock(sysclk_p and n) is 100Mhz and clk_out1 is 100mhz.
Contraint file
## Clock Signal
set_property -dict {PACKAGE_PIN AD11 IOSTANDARD LVDS} [get_ports
sysclk_n]
set_property -dict {PACKAGE_PIN AD12 IOSTANDARD LVDS} [get_ports
sysclk_p]
## Buttons
set_property -dict {PACKAGE_PIN E18 IOSTANDARD LVCMOS25} [get_ports
reset_n]
set_property -dict {PACKAGE_PIN M19 IOSTANDARD LVCMOS25} [get_ports
decrease_duty]
set_property -dict {PACKAGE_PIN B19 IOSTANDARD LVCMOS25} [get_ports
increase_duty]
set_property -dict {PACKAGE_PIN R19 IOSTANDARD LVCMOS25} [get_ports
cpu_resetn]
## LEDs
set_property -dict {PACKAGE_PIN T28 IOSTANDARD LVCMOS25} [get_ports
PWM_OUT]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[11]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[25]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[21]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[12]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[3]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[19]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[17]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[9]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[10]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[24]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[26]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[15]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[4]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[1]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[20]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[0]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[23]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[16]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[8]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[22]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[13]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[14]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[5]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[6]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[27]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[2]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[7]}]
set_property MARK_DEBUG true [get_nets {counter_debounce_reg[18]}]
set_property MARK_DEBUG true [get_nets {counter_PWM_reg__0[7]}]
set_property MARK_DEBUG true [get_nets {counter_PWM_reg__0[4]}]
set_property MARK_DEBUG true [get_nets {counter_PWM_reg__0[3]}]
set_property MARK_DEBUG true [get_nets {counter_PWM_reg__0[1]}]
set_property MARK_DEBUG true [get_nets {counter_PWM_reg__0[0]}]
set_property MARK_DEBUG true [get_nets {counter_PWM_reg__0[5]}]
set_property MARK_DEBUG true [get_nets {counter_PWM_reg__0[2]}]
set_property MARK_DEBUG true [get_nets {counter_PWM_reg__0[6]}]
set_property MARK_DEBUG true [get_nets {DUTY_CYCLE[6]}]
set_property MARK_DEBUG true [get_nets {DUTY_CYCLE[7]}]
set_property MARK_DEBUG true [get_nets {DUTY_CYCLE[5]}]
set_property MARK_DEBUG true [get_nets {DUTY_CYCLE[2]}]
set_property MARK_DEBUG true [get_nets {DUTY_CYCLE[1]}]
set_property MARK_DEBUG true [get_nets {DUTY_CYCLE[0]}]
set_property MARK_DEBUG true [get_nets {DUTY_CYCLE[4]}]
set_property MARK_DEBUG true [get_nets {DUTY_CYCLE[3]}]
set_property MARK_DEBUG true [get_nets decrease_duty_IBUF]
set_property MARK_DEBUG true [get_nets increase_duty_IBUF]
set_property MARK_DEBUG true [get_nets PWM_OUT_OBUF]
create_debug_core u_ila_0 ila
set_property ALL_PROBE_SAME_MU true [get_debug_cores u_ila_0]
set_property ALL_PROBE_SAME_MU_CNT 1 [get_debug_cores u_ila_0]
set_property C_ADV_TRIGGER false [get_debug_cores u_ila_0]
set_property C_DATA_DEPTH 1024 [get_debug_cores u_ila_0]
set_property C_EN_STRG_QUAL false [get_debug_cores u_ila_0]
set_property C_INPUT_PIPE_STAGES 0 [get_debug_cores u_ila_0]
set_property C_TRIGIN_EN false [get_debug_cores u_ila_0]
set_property C_TRIGOUT_EN false [get_debug_cores u_ila_0]
set_property port_width 1 [get_debug_ports u_ila_0/clk]
connect_debug_port u_ila_0/clk [get_nets [list clk_gen/inst/clk_out]]
set_property PROBE_TYPE DATA_AND_TRIGGER [get_debug_ports
u_ila_0/probe0]
set_property port_width 28 [get_debug_ports u_ila_0/probe0]
connect_debug_port u_ila_0/probe0 [get_nets [list
{counter_debounce_reg[0]} {counter_debounce_reg[1]}
{counter_debounce_reg[2]} {counter_debounce_reg[3]}
{counter_debounce_reg[4]} {counter_debounce_reg[5]}
{counter_debounce_reg[6]} {counter_debounce_reg[7]}
{counter_debounce_reg[8]} {counter_debounce_reg[9]}
{counter_debounce_reg[10]} {counter_debounce_reg[11]}
{counter_debounce_reg[12]} {counter_debounce_reg[13]}
{counter_debounce_reg[14]} {counter_debounce_reg[15]}
{counter_debounce_reg[16]} {counter_debounce_reg[17]}
{counter_debounce_reg[18]} {counter_debounce_reg[19]}
{counter_debounce_reg[20]} {counter_debounce_reg[21]}
{counter_debounce_reg[22]} {counter_debounce_reg[23]}
{counter_debounce_reg[24]} {counter_debounce_reg[25]}
{counter_debounce_reg[26]} {counter_debounce_reg[27]}]]
create_debug_port u_ila_0 probe
u_ila_0/probe1]
set_property port_width 8 [get_debug_ports u_ila_0/probe1]
connect_debug_port u_ila_0/probe1 [get_nets [list {DUTY_CYCLE[0]}
{DUTY_CYCLE[1]} {DUTY_CYCLE[2]} {DUTY_CYCLE[3]} {DUTY_CYCLE[4]}
{DUTY_CYCLE[5]} {DUTY_CYCLE[6]} {DUTY_CYCLE[7]}]]
u_ila_0/probe2]
set_property port_width 8 [get_debug_ports u_ila_0/probe2]
connect_debug_port u_ila_0/probe2 [get_nets [list
{counter_PWM_reg__0[0]} {counter_PWM_reg__0[1]} {counter_PWM_reg__0[2]}
{counter_PWM_reg__0[3]} {counter_PWM_reg__0[4]} {counter_PWM_reg__0[5]}
{counter_PWM_reg__0[6]} {counter_PWM_reg__0[7]}]]
u_ila_0/probe3]
set_property port_width 1 [get_debug_ports u_ila_0/probe3]
connect_debug_port u_ila_0/probe3 [get_nets [list decrease_duty_IBUF]]
u_ila_0/probe4]
set_property port_width 1 [get_debug_ports u_ila_0/probe4]
connect_debug_port u_ila_0/probe4 [get_nets [list increase_duty_IBUF]]
u_ila_0/probe5]
set_property port_width 1 [get_debug_ports u_ila_0/probe5]
connect_debug_port u_ila_0/probe5 [get_nets [list PWM_OUT_OBUF]]
set_property C_CLK_INPUT_FREQ_HZ 300000000 [get_debug_cores dbg_hub]
set_property C_ENABLE_CLK_DIVIDER false [get_debug_cores dbg_hub]
set_property C_USER_SCAN_CHAIN 1 [get_debug_cores dbg_hub]
connect_debug_port dbg_hub/clk [get_nets clk]
Adira N. schrieb: > Im trying to generate PWM signals. Why its not showing any contents' in > ILA core? Maybe because it has been optimized to zero, becaus the ila has no (visible) output port. See map report file, try atributes KEEP and/or NOPRUNE, depending on the synhtesis tool you're playing with.
