1 | #define F_CPU 16000000
2 |
3 | #include <avr/io.h>
4 | #include <avr/interrupt.h>
5 |
6 | #define BAUD 9600
7 | #define MYUBRR F_CPU/16/BAUD-1
8 |
9 | unsigned char UART_receive( void );
10 | void UART_send( char data);
11 |
12 | void AVR_init(void) {
13 |
14 | /* Clock init done by FUSES, CLK = 16 MHz ext. Oscillator */
15 |
16 | /*LED PIN*/
17 | /*---------------------------------------------------------*/
18 | DDRB = (1 << PINB5);
19 |
20 | /* init UART asynchronous 9600 8Bits 1Stop */
21 | /*---------------------------------------------------------*/
22 | /*Set baud rate registers according to MYUBRR definition*/
23 | UBRR0H = (unsigned char) (MYUBRR >> 8);
24 | UBRR0L = MYUBRR;
25 |
26 | /* Enable receiver and transmitter */
27 | UCSR0B = (1 << RXEN0) | (1 << TXEN0);
28 |
29 | /* Set frame format: 8data, 1stop bit */
30 | UCSR0C = (0 << UMSEL00);
31 | UCSR0C |= (0 << UCSZ00) | (1 << UCSZ01) | (1 << UCSZ00);
32 |
33 | /*init PWM, Timer*/
34 | /*---------------------------------------------------------*/
35 | /*Timer/Counte0 as PWM Waveform Generator on PD6/PD5 OC0A/OC0B (Arduino Pin 6, 5) (FAST PWM MODE 3)*/
36 | DDRD = (1 << PIND6);
37 | DDRD = (1 << PIND5);
38 |
39 | TCCR0A = (1 << COM0A1) | (0 << COM0A0);
40 | TCCR0A |= (1 << COM0B1) | (0 << COM0B0);
41 |
42 | /*MODE 3: Fast PWM TOPP = 0xFF*/
43 | TCCR0A |= (1 << WGM01) | (1 << WGM00);
44 |
45 | /* MODE 7 */
46 | TCCR0B |= (0 << WGM02);
47 |
48 | /*Select CLK Source and Prescaler*/
49 | /*Prescaler 1, 8, 64, 256, 1024*/
50 | TCCR0B |= (0 << CS02) | (1 << CS01) | (0 << CS00);
51 | // HIER GEHT WAS SCHIEF sobald ein CS0x bit gesetzt wird
52 |
53 | /*Interrupt enable*/
54 | TIMSK0 = (1 << OCIE0A) | (1 << OCIE0B);
55 |
56 | /*This Register defines compare Match => Duty Cycle PWM Channel A in MODE 3 activated*/
57 | /*This Register defines compare Match => Periode PWM Channel A in MODE 7 activated*/
58 | OCR0A = 128;
59 |
60 | /*This Register defines compare Match => Duty Cycle PWM Channel B in MODE 3 activated*/
61 | /*This Register defines compare Match => Duty Cycle PWM Channel A in MODE 7 activated*/
62 | OCR0B = 64;
63 |
64 | /* MODE3: Output Waveform Frequency = F_CPU/Prescaler/256 */
65 | /* MODE7: Output Waveform Frequency = F_CPU/2/Prescaler/(OCR0A+1) */
66 |
67 | sei();
68 | };
69 |
70 | int main(void){
71 |
72 | AVR_init();
73 |
74 | while( 1 ) {
75 | UART_send( UART_receive() );
76 | }
77 | }
78 |
79 | unsigned char UART_receive(void){
80 | /* Wait for data to be received */
81 | while (!(UCSR0A & (1<<RXC0)));
82 | /* Get and return received data from buffer */
83 | return UDR0;
84 | };
85 |
86 | void UART_send( char data){
87 | /* Wait for empty transmit buffer */
88 | while (!(UCSR0A & (1<<UDRE0)));
89 | /* Put data into buffer, sends the data */
90 | UDR0 = data;
91 | };
