1 | #include <ESP8266WiFi.h>
2 | #include <PubSubClient.h>
3 | const char* ssid = "SSID";
4 | const char* password = "PASSWORD";
5 | const char* mqtt_server = "192.168.178.31";
6 | const char* deviceID = "WEMOSD1mini";
7 |
8 | WiFiClient wifiClient; //create an instance of the WiFi client
9 | PubSubClient MQTTclient(wifiClient); //create an instance of the MQTT client, based on the WiFi client
10 |
11 | long lastMsgTime = 0; //The time (from millis()) at which last message was published
12 | char msg[64]; //A buffer to hold messages to be sent/have been received
13 | char topic[32]; //The topic in which to publish a message
14 | int pulseCount = 0; //Counter for number of heartbeat pulses sent
15 |
16 | void setup() {
17 | //PIN für LED & Anschalten dieser, um boot Vorgang anzuzeigen
18 | pinMode(D3, OUTPUT);
19 | digitalWrite(D3, HIGH);
20 |
21 | wifiSetup(); //WIFI-Connection
22 | mqttSetup(); //MQTT-Connection
23 |
24 | //LED kurze Blinken & ausschalten (zum Anzeigen, dass Boot-Vorgang abgeschlossen ist
25 | for (int i = 0; i < 4; i++){
26 | digitalWrite(D3, HIGH);
27 | delay(250);
28 | digitalWrite(D3, LOW);
29 | delay(250);
30 | }
31 | }
32 |
33 | void loop() {
34 | mqttLoop();
35 | LED();
36 | }
37 |
38 | void mqttCallback(char* topic, byte* payload, unsigned int length) { //Callback function each time a message is published in any of the topics to which this client is subscribed
39 | ...
40 | }
41 |
42 | void mqttLoop() {
43 | if (MQTTclient.connected()) {
44 | MQTTclient.loop(); //call the main loop to check for and publish messages
45 | }
46 | }
47 |
48 | void mqttReconnect() {
49 | if (!MQTTclient.connected()) {
50 | Serial.print("\nAttempting to connect to MQTT broker at (30sek) ");
51 | Serial.print(mqtt_server);
52 |
53 | MQTTclient.connect(deviceID);
54 | unsigned long currentF = millis();
55 | unsigned long previousF = currentF;
56 |
57 | //der Versuch, sich neu zu verbinden soll maximal 45 Sekunden dauern, da er im Zweifel nicht 5h in dieser Schleife hängen soll. (Ich habe vor, mithilfe einer Variable im EEPROM-Speicher, bei jedem 5. Reboot hintereinander, ersteinmal eine Pause von z.B. 15min zu lassen. Denn wenn nach 5 Versuchen keine Verbindung gelingt, liegt das Problem eher am Router
58 | while (!MQTTclient.connected() && currentF - previousF <= 45000) {
59 | delay(100);
60 | Serial.print("-");
61 | MQTTclient.connect(deviceID);
62 | currentF = millis();
63 | }
64 | if (!MQTTclient.connected()) {
65 | //Serial.print(MQTTclient.state()); //Debug Info
66 | Serial.write("\nMQTT-Reconnect fehlgeschlagen. Automatischer Neustart in 3 sek!\n");
67 | delay(3000);
68 | ESP.restart();
69 | }
70 | else {
71 | Serial.println("\nConnected to MQTT broker\n"); //Debug info
72 |
73 | //hier stehen alle subscriptions
74 | }
75 | }
76 | }
77 |
78 | void WiFiReconnect() {
79 | if (WiFi.status() != WL_CONNECTED) {
80 | Serial.print("\nVersuch, eine WLan Verbindung aufzustellen bei (30sek): ");
81 | Serial.print(ssid);
82 |
83 | WiFi.begin(ssid, password);
84 | unsigned long currentH = millis();
85 | unsigned long previousH = currentH;
86 |
87 | //der Versuch, sich neu zu verbinden soll maximal 45 Sekunden dauern, da er im Zweifel nicht 5h in dieser Schleife hängen soll
88 | while (WiFi.status() != WL_CONNECTED && currentH - previousH <= 45000) {
89 | delay(500);
90 | Serial.print(".");
91 | currentH = millis();
92 | }
93 | if (!MQTTclient.connected()) {
94 | //Serial.print(MQTTclient.state()); //Debug Info
95 | Serial.write("\nWLan-Reconnect fehlgeschlagen. Automatischer Neustart in 10 sek!\n");
96 | delay(10000);
97 | ESP.restart();
98 | }
99 | else {
100 | Serial.println("\nConnected to WiFi\n"); //Debug info
101 | Serial.println("MQTT Verbindung wird hergestellt...");
102 | mqttReconnect();
103 | }
104 | }
105 | }
106 |
107 | void mqttSetup() {
108 | MQTTclient.setServer(mqtt_server, 1883);
109 | MQTTclient.setCallback(mqttCallback);
110 |
111 | Serial.print("Attempting to connect to MQTT broker at (20sek) ");
112 | Serial.println(mqtt_server);
113 |
114 | MQTTclient.connect(deviceID);
115 | unsigned long currentG = millis();
116 | unsigned long previousG = currentG;
117 |
118 | //der Versuch, sich neu zu verbinden soll maximal 20 Sekunden dauern, da er im Zweifel nicht 5h in dieser Schleife hängen soll
119 | while (!MQTTclient.connected() && currentG - previousG <= 20000) {
120 | delay(100);
121 | Serial.print("-");
122 | MQTTclient.connect(deviceID);
123 | currentG = millis();
124 | }
125 | if (!MQTTclient.connected()) {
126 | //Serial.print(MQTTclient.state()); //Debug Info
127 | Serial.write("\nMQTT-Verbindung fehlgeschlagen. Automatischer Neustart in 3sek!\n");
128 | delay(3000);
129 | ESP.restart();
130 | }
131 | else {
132 | Serial.println("\nConnected to MQTT broker"); //Debug info
133 |
134 | //hier stehen alle subscriptions
135 | }
136 | }
137 |
138 | void wifiSetup() {
139 | if (!Serial) {
140 | Serial.begin(9600); //Start the Serial connection
141 | Serial.println("\nESP gestartet");
142 | }
143 |
144 | Serial.print("Ausgewähltes Wlan-Netzwerk: "); //Connect to the specified WiFi network
145 | Serial.println(ssid);
146 | WiFi.begin(ssid, password);
147 | unsigned long currentH = millis();
148 | unsigned long previousH = currentH;
149 |
150 | Serial.print("Verbidung wird hergestellt (15sek) ..."); //progress while we wait to connect
151 | while (WiFi.status() != WL_CONNECTED && currentH - previousH <= 15000) { //wenn keine Verbindung und weniger als 15 Sekunden vorbei: h < 15000
152 | delay(500);
153 | Serial.print(".");
154 | currentH = millis();
155 | }
156 | if (WiFi.status() != WL_CONNECTED) {
157 | Serial.write("\n Wlan Verbindung fehlgeschlagen. Auto Restart\n");
158 | ESP.restart();
159 | }
160 | else {
161 | delay(1500); //give the WiFi a couple of seconds to initialize
162 | Serial.println();
163 |
164 | Serial.print("Verbunden! IP-Adresse: ");
165 | Serial.println(WiFi.localIP());
166 | }
167 | }
168 |
169 | void LED() {
170 | if (WiFi.status() != WL_CONNECTED) {
171 | digitalWrite(D3, HIGH);
172 | Serial.print("\nWlan Verbindung verloren");
173 | WiFiReconnect();
174 | }
175 | else if (!MQTTclient.connected()) {
176 | digitalWrite(D3, HIGH);
177 | Serial.print("\nMQTT Verbindung Verloren");
178 | mqttReconnect();
179 | }
180 | else {
181 | digitalWrite(D3, LOW);
182 | }
183 | }
