How to speed update time of IDR Register STM32?
OP #6080108
I have a question about the IDR Register of STM32 I set the pin0 of the
ODR Register to 1 in my code below and i want to check, if the pin0 in
the IDR register is set to 1. The problem is, after setting the pin to
1, i musst wait 1 second until the pin in the IDR register is set to 1.
How can i read the pin state without waiting. How can i handle this
problem? ''' void init_pins(void) {
GPIOG->OTYPER |= (0x01 << 0); // Pin 0 as open drain
GPIOG->OTYPER &= ~(0x01 << 1); // Pin 1 as push - pull
GPIOG->BSRRL  =  0x01 << 1; // Pin 1 to High
GPIOG->BSRRL  =  0x01 << 0; // Pin 0 to High
microsecond_Delay(1000000);
if( !(GPIOG->IDR & 0x01) )
    errorCode = -1 ; //Error Code for Bus not floating
#6080114
The datasheet/reference manual of (for instance) STM32F10x says about
the IDR registers: "These bits are read only and can be accessed in Word
mode only. They contain the input value of the corresponding I/O port."
Maybe they can only be used if the pin is configured as input pin? That
needs to be discussed.
Gast #6080429
Your problem is possibly, that the Pin needs a while to change it's
voltage level from low to high.
You must wait a little, that is sure, but far less than a second. A
lower Pull-Up resistor makes it faster.
