hoffe Ihr habt alle frohe Festtage !
Ich versuche gerade über den Seriellen Monitor in eine Switch-CASE zu
springen.
jedoch funktioniert das nicht ganz. Der Compiler meldet folgendes:
1  | sketch_dec26a:18:10: error: expected identifier before 'case'
2  |
3  |      goto case 1;
4  |
5  |           ^
6  |
7  | sketch_dec26a:18:10: error: expected ';' before 'case'
8  |
9  | sketch_dec26a:18:10: error: case label '1' not within a switch statement
10  |
11  | sketch_dec26a:18:16: error: expected ':' before ';' token
12  |
13  |      goto case 1;
14  |
15  |                 ^
hier mein Code:
1  | byte Case = 1;
2  |
3  | unsigned long Millis;
4  |
5  | void setup() {
6  |   Serial.begin(115200);
7  |   Millis = millis();
8  |
9  | }
10  |
11  | void loop() {
12  |
13  |   if (Serial.available() > 0) {
14  |
15  |     const char a = Serial.read();
16  |
17  |     if (a == '1') {
18  |     goto case 1;
19  |     }
20  |     else if (a == '2') {}
21  |     else if (a == '3') {}
22  |     else if (a == '4') {}
23  |     else if (a == '5') {}
24  |     else if (a == '6') {}
25  |
26  |   }
27  | }
28  |
29  | if (millis() - Millis >= 10000) {
30  |   switch (Case) {
31  |
32  |     case 1:
33  |       Serial.println("Case 1");
34  |
35  |       Case = 2;
36  |       Millis = millis();
37  |
38  |       break;
39  |
40  |     case 2:
41  |       Serial.println("Case 2");
42  |
43  |       Case = 3;
44  |       Millis = millis();
45  |
46  |       break;
47  |
48  |     case 3:
49  |       Serial.println("Case 3");
50  |
51  |       Case = 4;
52  |       Millis = millis();
53  |
54  |       break;
55  |
56  |     case 4:
57  |       Serial.println("Case 4");
58  |
59  |       Case = 5;
60  |       Millis = millis();
61  |
62  |       break;
63  |
64  |     case 5:
65  |       Serial.println("Case 5");
66  |
67  |       Case = 6;
68  |       Millis = millis();
69  |
70  |       break;
71  |
72  |     case 6:
73  |       Serial.println("Case 6");
74  |
75  |       Case = 1;
76  |       Millis = millis();
77  |
78  |       break;
79  |   }
80  | }
81  | }
Was mache ich falsch?
Mfg
