1 | // PIC18F25K50 Configuration Bit Settings
2 |
3 | // 'C' source line config statements
4 |
5 | // CONFIG1L
6 | #pragma config PLLSEL = PLL3X // PLL Selection (3x clock multiplier)
7 | #pragma config CFGPLLEN = ON // PLL Enable Configuration bit (PLL Enabled)
8 | #pragma config CPUDIV = NOCLKDIV// CPU System Clock Postscaler (CPU uses system clock (no divide))
9 | #pragma config LS48MHZ = SYS48X8// Low Speed USB mode with 48 MHz system clock (System clock at 48 MHz, USB clock divider is set to 8)
10 |
11 | // CONFIG1H
12 | #pragma config FOSC = HSH // Oscillator Selection (HS oscillator, high power 16MHz to 25MHz)
13 | #pragma config PCLKEN = OFF // Primary Oscillator Shutdown (Primary oscillator shutdown firmware controlled)
14 | #pragma config FCMEN = OFF // Fail-Safe Clock Monitor (Fail-Safe Clock Monitor disabled)
15 | #pragma config IESO = OFF // Internal/External Oscillator Switchover (Oscillator Switchover mode disabled)
16 |
17 | // CONFIG2L
18 | #pragma config nPWRTEN = ON // Power-up Timer Enable (Power up timer enabled)
19 | #pragma config BOREN = ON // Brown-out Reset Enable (BOR controlled by firmware (SBOREN is enabled))
20 | #pragma config BORV = 285 // Brown-out Reset Voltage (BOR set to 2.85V nominal)
21 | #pragma config nLPBOR = ON // Low-Power Brown-out Reset (Low-Power Brown-out Reset enabled)
22 |
23 | // CONFIG2H
24 | #pragma config WDTEN = SWON // Watchdog Timer Enable bits (WDT controlled by firmware (SWDTEN enabled))
25 | #pragma config WDTPS = 256 // Watchdog Timer Postscaler (1:256)
26 |
27 | // CONFIG3H
28 | #pragma config CCP2MX = RC1 // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
29 | #pragma config PBADEN = ON // PORTB A/D Enable bit (PORTB<5:0> pins are configured as analog input channels on Reset)
30 | #pragma config T3CMX = RC0 // Timer3 Clock Input MUX bit (T3CKI function is on RC0)
31 | #pragma config SDOMX = RB3 // SDO Output MUX bit (SDO function is on RB3)
32 | #pragma config MCLRE = ON // Master Clear Reset Pin Enable (MCLR pin enabled; RE3 input disabled)
33 |
34 | // CONFIG4L
35 | #pragma config STVREN = ON // Stack Full/Underflow Reset (Stack full/underflow will cause Reset)
36 | #pragma config LVP = ON // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled if MCLRE is also 1)
37 | #pragma config ICPRT = OFF // Dedicated In-Circuit Debug/Programming Port Enable (ICPORT disabled)
38 | #pragma config XINST = OFF // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled)
39 |
40 | // CONFIG5L
41 | #pragma config CP0 = ON // Block 0 Code Protect (Block 0 is code-protected)
42 | #pragma config CP1 = OFF // Block 1 Code Protect (Block 1 is not code-protected)
43 | #pragma config CP2 = OFF // Block 2 Code Protect (Block 2 is not code-protected)
44 | #pragma config CP3 = OFF // Block 3 Code Protect (Block 3 is not code-protected)
45 |
46 | // CONFIG5H
47 | #pragma config CPB = OFF // Boot Block Code Protect (Boot block is not code-protected)
48 | #pragma config CPD = OFF // Data EEPROM Code Protect (Data EEPROM is not code-protected)
49 |
50 | // CONFIG6L
51 | #pragma config WRT0 = ON // Block 0 Write Protect (Block 0 (0800-1FFFh) is write-protected)
52 | #pragma config WRT1 = OFF // Block 1 Write Protect (Block 1 (2000-3FFFh) is not write-protected)
53 | #pragma config WRT2 = OFF // Block 2 Write Protect (Block 2 (04000-5FFFh) is not write-protected)
54 | #pragma config WRT3 = OFF // Block 3 Write Protect (Block 3 (06000-7FFFh) is not write-protected)
55 |
56 | // CONFIG6H
57 | #pragma config WRTC = ON // Configuration Registers Write Protect (Configuration registers (300000-3000FFh) are write-protected)
58 | #pragma config WRTB = ON // Boot Block Write Protect (Boot block (0000-7FFh) is write-protected)
59 | #pragma config WRTD = OFF // Data EEPROM Write Protect (Data EEPROM is not write-protected)
60 |
61 | // CONFIG7L
62 | #pragma config EBTR0 = ON // Block 0 Table Read Protect (Block 0 is protected from table reads executed in other blocks)
63 | #pragma config EBTR1 = OFF // Block 1 Table Read Protect (Block 1 is not protected from table reads executed in other blocks)
64 | #pragma config EBTR2 = OFF // Block 2 Table Read Protect (Block 2 is not protected from table reads executed in other blocks)
65 | #pragma config EBTR3 = OFF // Block 3 Table Read Protect (Block 3 is not protected from table reads executed in other blocks)
66 |
67 | // CONFIG7H
68 | #pragma config EBTRB = OFF // Boot Block Table Read Protect (Boot block is not protected from table reads executed in other blocks)
69 |
70 | // #pragma config statements should precede project file includes.
71 | // Use project enums instead of #define for ON and OFF.
72 |
73 | #include <xc.h>
