1 | C:\Users\alex\esp\esp-idf>openocd -f interface/ftdi/c232hm.cfg -f board/esp-wroom-32.cfg
2 | Open On-Chip Debugger v0.10.0-esp32-20191114 (2019-11-14-14:19)
3 | Licensed under GNU GPL v2
4 | For bug reports, read
5 | http://openocd.org/doc/doxygen/bugs.html
6 | WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
7 | Info : Configured 2 cores
8 | adapter speed: 1000 kHz
9 | Info : Listening on port 6666 for tcl connections
10 | Info : Listening on port 4444 for telnet connections
11 | Error: type 'esp32' is missing virt2phys
12 | Info : clock speed 1000 kHz
13 | Info : JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
14 | Info : JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
15 | Info : esp32: Debug controller 0 was reset.
16 | Info : esp32: Core 0 was reset.
17 | Info : esp32: Debug controller 1 was reset.
18 | Info : esp32: Core 1 was reset.
19 | Info : Listening on port 3333 for gdb connections
20 | Info : accepting 'gdb' connection on tcp/3333
21 | Error: No symbols for FreeRTOS
22 | Info : Target halted. CPU0: PC=0x40147B52 (active)
23 | Info : Target halted. CPU1: PC=0x40147B52
24 | Info : cpu0: Target halted, PC=0x400916EA, debug_reason=00000001
25 | Info : Flash mapping 0: 0x10020 -> 0x3f400020, 100 KB
26 | Info : Flash mapping 1: 0x30020 -> 0x400d0020, 486 KB
27 | Info : cpu0: Target halted, PC=0x400916EA, debug_reason=00000001
28 | Info : Auto-detected flash bank 'esp32.flash' size 4096 KB
29 | Info : Using flash bank 'esp32.flash' size 4096 KB
30 | Info : cpu0: Target halted, PC=0x400916EA, debug_reason=00000001
31 | Info : Flash mapping 0: 0x10020 -> 0x3f400020, 100 KB
32 | Info : Flash mapping 1: 0x30020 -> 0x400d0020, 486 KB
33 | Info : Using flash bank 'esp32.irom' size 488 KB
34 | Info : cpu0: Target halted, PC=0x400916EA, debug_reason=00000001
35 | Info : Flash mapping 0: 0x10020 -> 0x3f400020, 100 KB
36 | Info : Flash mapping 1: 0x30020 -> 0x400d0020, 486 KB
37 | Info : Using flash bank 'esp32.drom' size 104 KB
38 | Warn : negative reply, retrying
39 | Warn : negative reply, retrying
40 | esp32 arp_examine ['allow-defer']
41 | esp32 arp_halt
42 | esp32 arp_halt_gdb
43 | esp32 arp_poll
44 | esp32 arp_reset
45 | esp32 arp_waitstate
46 | esp32 esp32 flashbootstrap none|1.8|3.3|high|low
47 | esp32 examine_deferred
48 | esp32 flashbootstrap none|1.8|3.3|high|low
49 | esp32 was_examined
50 | ftdi_layout_init data direction
51 | jtag arp_init-reset
52 | jtag_reset trst_active srst_active
53 | power_restore
54 | program <filename> [address] [verify] [reset] [exit]
55 | program_esp <filename> [address] [verify] [reset] [exit]
56 | program_esp32 <filename> [address] [verify] [reset] [exit]
57 | reset [run|halt|init]
58 | reset_config [none|trst_only|srst_only|trst_and_srst]
59 | [srst_pulls_trst|trst_pulls_srst|combined|separate]
60 | [srst_gates_jtag|srst_nogate] [trst_push_pull|trst_open_drain]
61 | [srst_push_pull|srst_open_drain]
62 | [connect_deassert_srst|connect_assert_srst]
63 | reset_nag ['enable'|'disable']
64 | soft_reset_halt
65 | srst_deasserted
