Forum: PC Hard- und Software Special Character Keyboard
von Maximilian D. (ddkus)
I have a question. Is there a Keyboard/Keypad out there for special
Charaters for programming and/or Engeneering.
Or is there a good thread for a DIY solution. I already found a USB to
USB converter but that one is too expensive for me.
And I found a remapper with an Arduino Nano. That is a cool project but
I want to know if there is a other solution out there.
Thanks
von TR.0LL (Gast)
Thanks, thats good. I am going to have a look at it. But I was wandering
if there is a finished product.
von Matthias L. (limbachnet)
There IS a finished Product:
https://www.amazon.de/Expertkeys-EK-20-frei-programmierbare-Tastatur/dp/B00JR4WVMA
I know, it's quite expensive...
You may as well look after a used Keyboard of a cashier's desk, these
are normally programmable, too.
von Hannes J. (pnuebergang)
Get a cheap numpad keyboard or one of these cheap single-hand gaming
keyboards like https://de.aliexpress.com/item/33057396509.html Or even a
second normal keyboard should work.
Then get a free software called LuaMacros
http://www.hidmacros.eu/download.php. Then curse for some time about the
abomination of a scripting language it uses. Here is some tutorial to
get started
https://wtp-web.com/blog/installing-and-using-luamacros-for-your-2nd-keyboard/
An alternative would be to use a software for Android which turns your
phone into a programmable keyboard
https://play.google.com/store/apps/details?id=com.suchbyte.macrodeckclient
Hi, thanks for the tips. That is what i am doing right now.
(AutoHotkey). My Problem is that i can´t use it on other Computers
without installing the program and transvering my macro skript.
I was wandering if someone knows a solution that can just work by being
plugged in. And i can build something myself (usb to usb converter) but
i was wandering if there is something to buy like that.
ok maybe i have to refrase my post. What are you guys using when you
need special Characters like Omega. Lamda, squareroute, integral or
something like this.
> plugged in.
Yes. The additional keyboard posted above ist to be programmed once and
can afterwards be used at any other computer without additional
coftware.
von Ralf D. (doeblitz)
I just type C-x 8 RET to call insert-char and then type the unicode code
point in hex or the unicode character name. Emacs rulez ?
For one or two characters I press Win+; (Win+. on some keyboards) to
start the character picker, select the symbol category and select the
character I need. Ωλ√∫₯₲φʭ℗‱♪※↯↸↪?✔
Older versions of Windows had the character map which was a PITA.
If I need to write a longer section, and if it isn't top-secret, I write
a skeleton with https://math.typeit.org/ and copy-paste.
von sid (Gast)
Any keyboard with any number of extra keys can be used really..
you only need a macro that takes the input of one of those special keys
and converts it to your predefined special character;
usually the bundled software can do that..
else even a simple script (like autoIT) can take care of that for you.
I once had tool that remapped my keyboard when caps lock was engaged,
(to not switch case but remap the numpad to predefined keys)
but since it's a third party tool that constantly checks the keypresses
it somewhere in the early 2000 was masked as keylogger by my antivirus
software and well that was more trouble than use to make it work again.
Talking of which... dedicated gaming keypads are usually configurable
beyond expectations
so that you can map almost anything you want (from special characters up
to full char sequences)
and I bet they're not too expensive either ;)
'sid
von Uwe S. (lzmr)
Take a look at programmable Keyboards for POS Systems.
A PrehKeyTec Keyboard with 64 free programmable keys can be
as low as 20€ at eBay. The benefit is: you can change the caps
of the keys and the mapping is storred in the Keyboard Flash
you will need no Special Driver and the Software to map the keys
to any Charakter is free.
Cool thanks. That one look good. I´m going to try and work with that.
Thanks to all for now. I will update you if I find something else.
