1 | /*********************************************************************
2 | * SEGGER Microcontroller GmbH *
3 | * The Embedded Experts *
4 | **********************************************************************
5 | * *
6 | * (c) 2014 - 2020 SEGGER Microcontroller GmbH *
7 | * *
8 | * www.segger.com Support: support@segger.com *
9 | * *
10 | **********************************************************************
11 | * *
12 | * All rights reserved. *
13 | * *
14 | * Redistribution and use in source and binary forms, with or *
15 | * without modification, are permitted provided that the following *
16 | * conditions are met: *
17 | * *
18 | * - Redistributions of source code must retain the above copyright *
19 | * notice, this list of conditions and the following disclaimer. *
20 | * *
21 | * - Neither the name of SEGGER Microcontroller GmbH *
22 | * nor the names of its contributors may be used to endorse or *
23 | * promote products derived from this software without specific *
24 | * prior written permission. *
25 | * *
26 | * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND *
27 | * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, *
28 | * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
29 | * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE *
30 | * DISCLAIMED. *
31 | * IN NO EVENT SHALL SEGGER Microcontroller GmbH BE LIABLE FOR *
32 | * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR *
33 | * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT *
34 | * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; *
35 | * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF *
36 | * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT *
37 | * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE *
38 | * USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH *
39 | * DAMAGE. *
40 | * *
41 | **********************************************************************
42 |
43 | -------------------------- END-OF-HEADER -----------------------------
44 |
45 | File : main.c
46 | Purpose : Generic application start
47 |
48 | */
49 |
50 | //#include <stdio.h>
51 | //#include <stdlib.h>
52 |
53 | #include <stm32f4xx.h>
54 | #include "SEGGER_SYSVIEW.h"
55 |
56 | void ClockInit(void)
57 | {
58 | uint32_t timeout = 1000000;
59 |
60 | // enable flash prefetch
61 | FLASH->ACR |= FLASH_ACR_PRFTEN;
62 | // set 5 wait states (needed for high PLL frequency)
63 | FLASH->ACR &= ~FLASH_ACR_LATENCY_Msk;
64 | FLASH->ACR |= FLASH_ACR_LATENCY_5WS;
65 | do
66 | {
67 | timeout--;
68 | } while (((FLASH->ACR & FLASH_ACR_LATENCY_Msk) != FLASH_ACR_LATENCY_5WS) && (timeout > 0));
69 |
70 | // switch on external clock, bypass HSE with it and wait for clock to be ready
71 | RCC->CR |= (RCC_CR_HSEON | RCC_CR_HSEBYP);
72 | timeout = 1000000;
73 | do
74 | {
75 | timeout--;
76 | } while (((RCC->CR & RCC_CR_HSERDY_Msk) != RCC_CR_HSERDY) && (timeout > 0));
77 |
78 | // configure (HSE as clock source, M = 4, N = 180, P = 2), enable and wait for PLL
79 | RCC->PLLCFGR = (RCC_PLLCFGR_PLLSRC_HSE | (4 << RCC_PLLCFGR_PLLM_Pos) | (180 << RCC_PLLCFGR_PLLN_Pos));
80 | RCC->CR |= RCC_CR_PLLON;
81 | timeout = 1000000;
82 | do
83 | {
84 | timeout--;
85 | } while (((RCC->CR & RCC_CR_PLLRDY_Msk) != RCC_CR_PLLRDY) && (timeout > 0));
86 |
87 | // configure rest of clock tree
88 | RCC->CFGR &= ~(RCC_CFGR_PPRE2_Msk | RCC_CFGR_PPRE1_Msk | RCC_CFGR_HPRE_Msk);
89 | RCC->CFGR |= (RCC_CFGR_PPRE2_DIV2 | RCC_CFGR_PPRE1_DIV4 | RCC_CFGR_HPRE_DIV1);
90 |
91 | // set PLL as clock source and wait until clock is ready
92 | RCC->CFGR &= ~(RCC_CFGR_SW_Msk);
93 | RCC->CFGR |= RCC_CFGR_SW_PLL;
94 | timeout = 1000000;
95 | do
96 | {
97 | timeout--;
98 | } while (((RCC->CFGR & RCC_CFGR_SWS_Msk) != RCC_CFGR_SWS_PLL) && (timeout > 0));
99 |
100 | SystemCoreClockUpdate();
101 |
102 | // enable GPIOA, ADC1, TIM1 and TIM2 clocks
103 | RCC->AHB1ENR |= RCC_AHB1ENR_GPIOAEN;
104 | RCC->APB2ENR |= RCC_APB2ENR_ADC1EN;
105 | RCC->APB1ENR |= RCC_APB1ENR_TIM2EN;
106 | }
107 |
108 | void TimerInit(void)
109 | {
110 | // counter direction down, generate update event only on underflow
111 | TIM2->CR1 |= (TIM_CR1_DIR | TIM_CR1_URS);
112 | // set update event as trigger source
113 | TIM2->CR2 &= ~TIM_CR2_MMS_Msk;
114 | TIM2->CR2 |= TIM_CR2_MMS_1;
115 | // enable update interrupt
116 | TIM2->DIER |= TIM_DIER_UIE;
117 | // set timer and reload value for update generation every 1000 ms
118 | TIM2->ARR = TIM2->CNT = 90000000;
119 | }
120 |
121 | void TimerStart(void)
122 | {
123 | TIM2->CR1 |= TIM_CR1_CEN;
124 | }
125 |
126 | void AdcInit(void)
127 | {
128 | // PA3 as analog input
129 | GPIOA->MODER |= GPIO_MODER_MODE3;
130 | // set clock prescaler to 4 -> 22,5 MHz
131 | ADC123_COMMON->CCR |= ADC_CCR_ADCPRE_0;
132 | // enable timer 2 trigger event as start trigger on rising edge and generate EOC interrupt after each conversion
133 | ADC1->CR2 |= (ADC_CR2_EXTSEL_2 | ADC_CR2_EXTSEL_1 | ADC_CR2_EXTEN_0 | ADC_CR2_EOCS);
134 | // set 480 cycles sample time for channel 3
135 | ADC1->SMPR2 |= ADC_SMPR2_SMP3;
136 | // set channel 3 as first (any only) regular channel
137 | ADC1->SQR3 |= (ADC_SQR3_SQ1_2 | ADC_SQR3_SQ1_1);
138 | // enable EOC interrupt
139 | ADC1->CR1 |= ADC_CR1_EOCIE;
140 | // enable ADC
141 | ADC1->CR2 |= ADC_CR2_ADON;
142 | }
143 |
144 | void InterruptInit(void)
145 | {
146 | // Timer 2
147 | NVIC_SetPriority(TIM2_IRQn, 3);
148 | NVIC_ClearPendingIRQ(TIM2_IRQn);
149 | NVIC_EnableIRQ(TIM2_IRQn);
150 | // ADC
151 | NVIC_SetPriority(ADC_IRQn, 2);
152 | NVIC_ClearPendingIRQ(ADC_IRQn);
153 | NVIC_EnableIRQ(ADC_IRQn);
154 | }
155 |
156 | void TIM2_IRQHandler(void)
157 | {
158 | SEGGER_SYSVIEW_RecordEnterISR();
159 | NVIC_ClearPendingIRQ(TIM2_IRQn);
160 | TIM2->SR &= ~TIM_SR_UIF;
161 | }
162 |
163 | void ADC_IRQHandler(void)
164 | {
165 | uint16_t Value;
166 | SEGGER_SYSVIEW_RecordEnterISR();
167 | Value = ADC1->DR;
168 | NVIC_ClearPendingIRQ(ADC_IRQn);
169 | }
170 |
171 | int main(void)
172 | {
173 | ClockInit();
174 |
175 | SEGGER_SYSVIEW_Conf();
176 |
177 | TimerInit();
178 | AdcInit();
179 | InterruptInit();
180 |
181 | TimerStart();
182 | while(1);
183 | }
184 |
185 | /*************************** End of file ****************************/
