Hallo Linux Freunde, wollte mir die VNA QT-Software bauen. siehe: https://github.com/nanovna/NanoVNA-QT bauen. bekomme leider vom Compiler folgende Fehlermeldung: In file included from /usr/include/math.h:37, from /usr/include/c++/9/cmath:45, from utility.H:6, from impedancedisplay.C:1: /usr/include/bits/types.h:145:25: error: conflicting declaration ‘typedef long unsigned int __dev_t’ 145 | __STD_TYPE __DEV_T_TYPE __dev_t; /* Type of device numbers. */ Build wird mit QT-Creator erstellt. 11:57:12: Running steps for project vna_qt... 11:57:12: Configuration unchanged, skipping qmake step. 11:57:12: Starting: "/usr/bin/make" -j8 /usr/lib64/qt5/bin/qmake -o Makefile vna_qt.pro -spec linux-g++ g++ -c -pipe -Wextra -std=c++11 -DEIGEN_DONT_VECTORIZE -DEIGEN_DISABLE_UNALIGNED_ARRAY_ASSERT -O2 -Wall -Wextra -D_REENTRANT -fPIC -DQT_DEPRECATED_WARNINGS -DQT_NO_DEBUG -DQT_CHARTS_LIB -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I../include -isystem /usr/local/include -isystem /usr/include/qt5 -isystem /usr/include/qt5/QtCharts -isystem /usr/include/qt5/QtSvg -isystem /usr/include/qt5/QtWidgets -isystem /usr/include/qt5/QtGui -isystem /usr/include/qt5/QtCore -I. -I. -I/usr/lib64/qt5/mkspecs/linux-g++ -o polarview.o polarview.C g++ -c -pipe -Wextra -std=c++11 -DEIGEN_DONT_VECTORIZE -DEIGEN_DISABLE_UNALIGNED_ARRAY_ASSERT -O2 -Wall -Wextra -D_REENTRANT -fPIC -DQT_DEPRECATED_WARNINGS -DQT_NO_DEBUG -DQT_CHARTS_LIB -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I../include -isystem /usr/local/include -isystem /usr/include/qt5 -isystem /usr/include/qt5/QtCharts -isystem /usr/include/qt5/QtSvg -isystem /usr/include/qt5/QtWidgets -isystem /usr/include/qt5/QtGui -isystem /usr/include/qt5/QtCore -I. -I. -I/usr/lib64/qt5/mkspecs/linux-g++ -o mainwindow.o mainwindow.C g++ -c -pipe -Wextra -std=c++11 -DEIGEN_DONT_VECTORIZE -DEIGEN_DISABLE_UNALIGNED_ARRAY_ASSERT -O2 -Wall -Wextra -D_REENTRANT -fPIC -DQT_DEPRECATED_WARNINGS -DQT_NO_DEBUG -DQT_CHARTS_LIB -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I../include -isystem /usr/local/include -isystem /usr/include/qt5 -isystem /usr/include/qt5/QtCharts -isystem /usr/include/qt5/QtSvg -isystem /usr/include/qt5/QtWidgets -isystem /usr/include/qt5/QtGui -isystem /usr/include/qt5/QtCore -I. -I. -I/usr/lib64/qt5/mkspecs/linux-g++ -o main.o main.C g++ -c -pipe -Wextra -std=c++11 -DEIGEN_DONT_VECTORIZE -DEIGEN_DISABLE_UNALIGNED_ARRAY_ASSERT -O2 -Wall -Wextra -D_REENTRANT -fPIC -DQT_DEPRECATED_WARNINGS -DQT_NO_DEBUG -DQT_CHARTS_LIB -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I../include -isystem /usr/local/include -isystem /usr/include/qt5 -isystem /usr/include/qt5/QtCharts -isystem /usr/include/qt5/QtSvg -isystem /usr/include/qt5/QtWidgets -isystem /usr/include/qt5/QtGui -isystem /usr/include/qt5/QtCore -I. -I. -I/usr/lib64/qt5/mkspecs/linux-g++ -o markerslider.o markerslider.C g++ -c -pipe -Wextra -std=c++11 -DEIGEN_DONT_VECTORIZE -DEIGEN_DISABLE_UNALIGNED_ARRAY_ASSERT -O2 -Wall -Wextra -D_REENTRANT -fPIC -DQT_DEPRECATED_WARNINGS -DQT_NO_DEBUG -DQT_CHARTS_LIB -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I../include -isystem /usr/local/include -isystem /usr/include/qt5 -isystem /usr/include/qt5/QtCharts -isystem /usr/include/qt5/QtSvg -isystem /usr/include/qt5/QtWidgets -isystem /usr/include/qt5/QtGui -isystem /usr/include/qt5/QtCore -I. -I. -I/usr/lib64/qt5/mkspecs/linux-g++ -o impedancedisplay.o impedancedisplay.C g++ -c -pipe -Wextra -std=c++11 -DEIGEN_DONT_VECTORIZE -DEIGEN_DISABLE_UNALIGNED_ARRAY_ASSERT -O2 -Wall -Wextra -D_REENTRANT -fPIC -DQT_DEPRECATED_WARNINGS -DQT_NO_DEBUG -DQT_CHARTS_LIB -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I../include -isystem /usr/local/include -isystem /usr/include/qt5 -isystem /usr/include/qt5/QtCharts -isystem /usr/include/qt5/QtSvg -isystem /usr/include/qt5/QtWidgets -isystem /usr/include/qt5/QtGui -isystem /usr/include/qt5/QtCore -I. -I. -I/usr/lib64/qt5/mkspecs/linux-g++ -o frequencydialog.o frequencydialog.C g++ -c -pipe -Wextra -std=c++11 -DEIGEN_DONT_VECTORIZE -DEIGEN_DISABLE_UNALIGNED_ARRAY_ASSERT -O2 -Wall -Wextra -D_REENTRANT -fPIC -DQT_DEPRECATED_WARNINGS -DQT_NO_DEBUG -DQT_CHARTS_LIB -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I../include -isystem /usr/local/include -isystem /usr/include/qt5 -isystem /usr/include/qt5/QtCharts -isystem /usr/include/qt5/QtSvg -isystem /usr/include/qt5/QtWidgets -isystem /usr/include/qt5/QtGui -isystem /usr/include/qt5/QtCore -I. -I. -I/usr/lib64/qt5/mkspecs/linux-g++ -o graphpanel.o graphpanel.C g++ -c -pipe -Wextra -std=c++11 -DEIGEN_DONT_VECTORIZE -DEIGEN_DISABLE_UNALIGNED_ARRAY_ASSERT -O2 -Wall -Wextra -D_REENTRANT -fPIC -DQT_DEPRECATED_WARNINGS -DQT_NO_DEBUG -DQT_CHARTS_LIB -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I../include -isystem /usr/local/include -isystem /usr/include/qt5 -isystem /usr/include/qt5/QtCharts -isystem /usr/include/qt5/QtSvg -isystem /usr/include/qt5/QtWidgets -isystem /usr/include/qt5/QtGui -isystem /usr/include/qt5/QtCore -I. -I. -I/usr/lib64/qt5/mkspecs/linux-g++ -o configureviewdialog.o configureviewdialog.C die vna_qt.pro Datei hat folgenden Inhalt: #------------------------------------------------- # # Project created by QtCreator 2017-12-16T02:35:03 # #------------------------------------------------- QT += core gui charts greaterThan(QT_MAJOR_VERSION, 4): QT += widgets #CONFIG += static #CONFIG -= import_plugins QT += svg QTPLUGIN.iconengines += svgicon QTPLUGIN.imageformats += svg #QMAKE_LFLAGS += --static -lexpat -lz -lXext -lXau -lbsd -lXdmcp #QMAKE_LFLAGS += -L../lib -lxavna QMAKE_CXXFLAGS += -Wextra -std=c++11 QMAKE_CXXFLAGS += -DEIGEN_DONT_VECTORIZE -DEIGEN_DISABLE_UNALIGNED_ARRAY_ASSERT android: QMAKE_CXXFLAGS += -I../android_include -DANDROID_WORKAROUNDS TARGET = vna_qt TEMPLATE = app # The following define makes your compiler emit warnings if you use # any feature of Qt which as been marked as deprecated (the exact warnings # depend on your compiler). Please consult the documentation of the # deprecated API in order to know how to port your code away from it. DEFINES += QT_DEPRECATED_WARNINGS # You can also make your code fail to compile if you use deprecated APIs. # In order to do so, uncomment the following line. # You can also select to disable deprecated APIs only up to a certain version of Qt. #DEFINES += QT_DISABLE_DEPRECATED_BEFORE=0x060000 # disables all the APIs deprecated before Qt 6.0.0 SOURCES +=\ polarview.C \ mainwindow.C \ main.C \ markerslider.C \ impedancedisplay.C \ frequencydialog.C \ graphpanel.C \ configureviewdialog.C \ touchstone.C \ calkitsettingsdialog.C \ calkitsettings.C \ networkview.C \ dtfwindow.C \ calibrationfinetunedialog.C \ firmwareupdater.C \ firmwareupdatedialog.C HEADERS += \ polarview.H \ mainwindow.H \ markerslider.H \ impedancedisplay.H \ utility.H \ frequencydialog.H \ graphpanel.H \ configureviewdialog.H \ touchstone.H \ calkitsettingsdialog.H \ calkitsettings.H \ networkview.H \ dtfwindow.H \ calibrationfinetunedialog.H \ firmwareupdater.H \ firmwareupdatedialog.H FORMS += mainwindow.ui \ markerslider.ui \ impedancedisplay.ui \ frequencydialog.ui \ graphpanel.ui \ configureviewdialog.ui \ calkitsettingsdialog.ui \ calkitsettingswidget.ui \ dtfwindow.ui \ graphlimitsdialog.ui \ calibrationfinetunedialog.ui \ firmwareupdatedialog.ui TRANSLATIONS = languages/vna_qt_zh.ts DISTFILES += languages/vna_qt_zh.ts RESOURCES += \ resources.qrc LIBS += -L$$PWD/../libxavna/.libs/ -L/usr/local/lib/ -lxavna -lfftw3 -lpthread android: LIBS += -L$$PWD/../lib win32:CONFIG(release, debug|release): LIBS += -L$$PWD/../libxavna/xavna_mock_ui/release/ -lxavna_mock_ui else:win32:CONFIG(debug, debug|release): LIBS += -L$$PWD/../libxavna/xavna_mock_ui/debug/ -lxavna_mock_ui else:unix: LIBS += -L$$PWD/../libxavna/xavna_mock_ui/ -lxavna_mock_ui INCLUDEPATH += $$PWD/../include /usr/local/include DEPENDPATH += $$PWD/../include #INCLUDEPATH += ../libxavna/xavna_mock_ui #PRE_TARGETDEPS += ../libxavna/xavna_mock_ui/libxavna_mock_ui.so contains(ANDROID_TARGET_ARCH,armeabi-v7a) { ANDROID_EXTRA_LIBS = \ /persist/vna/vna_qt/../libxavna/.libs/libxavna.so \ $$PWD/../libxavna/xavna_mock_ui/libxavna_mock_ui.so } Hat jemand für mich einen Tipp? Ansonsten müsste ich mich direkt an die Projekt-Seite im Githab wenden. Habe aber noch keinen Account bei Github und kann deshalt keine Anfragen posten. Danke für Eure Mühe Markus
Markus W. schrieb: > Ansonsten müsste ich mich direkt an die Projekt-Seite im Githab > wenden. Habe aber noch keinen Account bei Github und kann deshalt > keine Anfragen posten. und du kannst dir keinen Account erstellen wegen was?
Weil irgendwo noch ein Wurm drin ist! Habe es gestern versucht einen Account zu erzeugen,aber bei der Verifikation ob ich eine Person bin geht leider was schief. Markus
Markus W. schrieb: > bekomme leider vom Compiler folgende Fehlermeldung: An Stelle der völlig end- und nutzlosen Compileraufrufe hättest du besser mal die ganze Fehlermeldung eingestellt. Denn üblicherweise kommt da noch ein „previous declaration was here“ - Hinweis. Wenn du allerdings mit der gezeigten Fehlermeldung gar nichts anfangen kannst, wird das alles für dich schwierig. Oliver
Jetzt bin ich eine Hürde weiter gekommen, aber Ihnen scheint meine Mailadresse nicht zu gefallen. Markus
Oliver, das ist doch die Fehlermeldung. Steht ganz oben in meinem Thread. In file included from /usr/include/math.h:37, from /usr/include/c++/9/cmath:45, from utility.H:6, from impedancedisplay.C:1: /usr/include/bits/types.h:145:25: error: conflicting declaration ‘typedef long unsigned int __dev_t’ 145 | __STD_TYPE __DEV_T_TYPE __dev_t; /* Type of device numbers. Das es viel Zeug war ist mir klar, aber manche von Euch bestehen sogar darauf. Zitat "nicht häppchenweise die Infos rausrücken". Alles was QTCreator rausgehauen hat habe ich geliefert. Es scheint eine Inkompatibilität mit den Deklarationen von: __STD_TYPE __DEV_T_TYPE __dev_t in /usr/include/bits/types.h und irgendeiner Deklaration von typedef long unsigned int __dev_t an einer anderen Stelle. So mein Verständnis. Wahrscheinlich fehlt irgend ein dev Paket auf meinem System.
Wie gesagt, üblicherweise liefert GCC auch die Stelle, wo sich die conflicting declaration befindet. Schau nochmal nach. Oliver
Oliver, ich bekomme nur das: In file included from /usr/include/math.h:37, from /usr/include/c++/9/cmath:45, from utility.H:6, from impedancedisplay.C:1: /usr/include/bits/types.h:145:25: error: conflicting declaration ‘typedef long unsigned int __dev_t’ 145 | __STD_TYPE __DEV_T_TYPE __dev_t; /* Type of device numbers. */ | ^~~~~~~ d.h. die Definition von __dev_t in Zeile 145 aus /usr/include/bits/types.h Beißt sich mit Deklarationen die woanders sind, aber wo? /dev/shm/nanoVNA/NanoVNA-QT-master/vna_qt >grep -n '__dev_t' /usr/include/math.h markus@zbook:/dev/shm/nanoVNA/NanoVNA-QT-master/vna_qt >grep -n '__dev_t' /usr/include/c++/9/cmath markus@zbook:/dev/shm/nanoVNA/NanoVNA-QT-master/vna_qt >grep -n '__dev_t' utility.H ich finde den Typ __dev_t nicht in den aufgeführten Files. Kann das eine Kollision mit einem Type aus einer Lib sein? Markus
Markus W. schrieb: > 145 | __STD_TYPE __DEV_T_TYPE __dev_t; /* Type of device numbers. Das kann natürlich auch ein Problem mit __STD_TYPE oder __DEV_T_TYPE sein. Compiler mal nur die Datei mit dem Fehler, und zeig dann alles, was im Compile-Fenster vom Creator steht. Oliver
Oliver, danke für Deine Mühe und die Geduld ;-) Ich habe mal den g++ Output in die angehängte Datei verfrachtet. das Gesamte NanoVNA-QT-master Packet beinhaltet verschiedene Verzeichnisse, die Kompiliert werden können/sollen. Ich habe mich auf das Vezeichnis ./vna_qt beschränkt. Wenn ich das gesamte Packet zum Komiplieren configuriere, wie in der Readme beschrieben, habe ich folgendes Problem: bei autoreconf --install ./configure bekomme ich configure: WARNING: eigen3/Eigen/Dense: present but cannot be compiled configure: WARNING: eigen3/Eigen/Dense: check for missing prerequisite headers? configure: WARNING: eigen3/Eigen/Dense: see the Autoconf documentation configure: WARNING: eigen3/Eigen/Dense: section "Present But Cannot Be Compiled" configure: WARNING: eigen3/Eigen/Dense: proceeding with the compiler's result configure: WARNING: ## -------------------------------------------------------- ## configure: WARNING: ## Report this to 54525305+nanovna@users.noreply.github.com ## configure: WARNING: ## -------------------------------------------------------- ## checking for eigen3/Eigen/Dense... no configure: error: eigen3 not installed (eigen3/Eigen/Dense include not found) Wenn ich die Datei configure.ac dahingehend modifiziere, dass ich über die Problemstelle komme AC_CHECK_HEADER(eigen3/Eigen/Dense) if test "$ac_cv_header_eigen3_Eigen_Dense" == no then #AC_MSG_ERROR([eigen3 not installed (eigen3/Eigen/Dense include not found)]) <== Zeile auskommentiert AC_CHECK_HEADER(eigen3/Eigen/Dense) <== von mir eingefügt fi Bekomme ich: checking eigen3/Eigen/Dense usability... no checking eigen3/Eigen/Dense presence... yes configure: WARNING: eigen3/Eigen/Dense: present but cannot be compiled configure: WARNING: eigen3/Eigen/Dense: check for missing prerequisite headers? configure: WARNING: eigen3/Eigen/Dense: see the Autoconf documentation configure: WARNING: eigen3/Eigen/Dense: section "Present But Cannot Be Compiled" configure: WARNING: eigen3/Eigen/Dense: proceeding with the compiler's result configure: WARNING: ## -------------------------------------------------------- ## configure: WARNING: ## Report this to 54525305+nanovna@users.noreply.github.com ## configure: WARNING: ## -------------------------------------------------------- ## checking for eigen3/Eigen/Dense... no checking for eigen3/Eigen/Dense... (cached) no checking fftw3.h usability... yes checking fftw3.h presence... yes checking for fftw3.h... yes checking that generated files are newer than configure... done configure: creating ./config.status config.status: creating Makefile config.status: creating libxavna/Makefile config.status: executing depfiles commands config.status: executing libtool commands und kann jetzt make aufrufen. Führt aber auch zu Fehlern. In file included from /usr/include/c++/9/math.h:36, from xavna.C:4: /usr/include/c++/9/cmath:1071:11: error: ‘::acoshl’ has not been declared 1071 | using ::acoshl; | ^~~~~~ Das liegt vermutlich an dem vermeindlichen Fehlen der "Eigen" Library, obwohl sie eigentlich nicht bei mir fehlt. Liegt in /usr/include/eigen3/Eigen/Dense wird auch von ./configure gefunden checking eigen3/Eigen/Dense usability... no checking eigen3/Eigen/Dense presence... yes aber dann wird moniert checking for eigen3/Eigen/Dense... no checking for eigen3/Eigen/Dense... (cached) no Ab da habe ich dann versucht nur das vna_qt Dir zu kompilieren, da darin eine .pro Datei für den QTCreator liegt. Hat aber dann die besagten Probleme hervorgerufen. Irgendwie drehe ich mich im Kreis %-( Markus
Steht doch alles in den Fehlermeldungen. Die beiden Deklarationen stehen in /usr/include/bits/types.h /usr/local/include/sys/_types.h Das erste ist ein System-include für dein System, das zweite (vermutlich) für Android. Du musst dich jetzt entscheiden, für welches der beiden Systeme du compilieren willst ;) Da stimmen halt entweder die Installation des Cross-Compilers für Android nicht, oder irgendwelche Pfade im System, oder auch defines o.ä. im Projekt. Oliver
Oliver, sorry, kannst Du mich mit der Nase drauf stupsen, wo Du das gelesen hast. /usr/include/bits/types.h /usr/local/include/sys/_types.h Es gibt die Optionen für Win/Mac/Linux und Android. Möglicherweise habe die configure Skripte noch ne Macke. Muss mich wohl doch an die Github Projekt-Verantwortlichen wenden. Danke für Diene Bemühungen mir zu helfen. LG Markus
Markus W. schrieb: > sorry, kannst Du mich mit der Nase drauf stupsen, wo > Du das gelesen hast. 1. Fehler das eine, 2. Fehler das andere, usw. Oliver
Markus W. schrieb: > sorry, kannst Du mich mit der Nase drauf stupsen, wo > Du das gelesen hast. Steht doch eigentlich klar und unübersehbar da, wie auch schon von Oliver vermutet: Oliver S. schrieb: > Denn üblicherweise kommt da noch ein „previous declaration was here“ - > Hinweis.
1 | In file included from /usr/include/math.h:37, |
2 | from /usr/include/c++/9/cmath:45, |
3 | from utility.H:6, |
4 | from frequencydialog.C:1: |
5 | /usr/include/bits/types.h:145:25: error: conflicting declaration ‘typedef long unsigned int __dev_t’ |
6 | 145 | __STD_TYPE __DEV_T_TYPE __dev_t; /* Type of device numbers. */ |
7 | | ^~~~~~~ |
8 | In file included from /usr/local/include/sys/reent.h:15, |
9 | from /usr/local/include/stdio.h:60, |
10 | from utility.H:4, |
11 | from frequencydialog.C:1: |
12 | /usr/local/include/sys/_types.h:54:15: note: previous declaration as ‘typedef short int __dev_t’ |
13 | 54 | typedef short __dev_t; |
14 | | ^~~~~~~ |
Markus W. schrieb: > @ Rolf > > Danke! > > Wie löst man das auf? Wo kommen denn diese ganzen Headers unter /usr/local/include her? Die musst du ja vorher irgendwie installiert haben. Und die gehören da nicht hin.
@Rolf, sorry kann ich Dir nicht sagen ;-) habe mit cd /var/log/zypp cat history | grep '|install' | awk -F'|' '{print $2,$3,$4}' > zypper.log das angehängte Log-File generiert. Irgend ein Packet ist dafür verantwortlich - aber welches. Werde mal den /usr/local/include Pfad temporär deaktivieren und sehen, was beim Kompilieren rauskommt. Markus
@Rolf M. Vielen Dank! Das war der Wink in die richtige richtung. Nach dem temporären Umbenennen von /usr/local/(include,lib,lib64) Komme ich bis zum Linken. g++ -Wl,-O1 -o vna_qt polarview.o mainwindow.o main.o markerslider.o impedancedisplay.o frequencydialog.o graphpanel.o configureviewdialog.o touchstone.o calkitsettingsdialog.o calkitsettings.o networkview.o dtfwindow.o calibrationfinetunedialog.o firmwareupdater.o firmwareupdatedialog.o qrc_resources.o moc_polarview.o moc_mainwindow.o moc_markerslider.o moc_impedancedisplay.o moc_frequencydialog.o moc_graphpanel.o moc_configureviewdialog.o moc_calkitsettingsdialog.o moc_networkview.o moc_dtfwindow.o moc_calibrationfinetunedialog.o moc_firmwareupdatedialog.o -L/dev/shm/nanoVNA/NanoVNA-QT-master/vna_qt/../libxavna/.libs/ -L/usr/local/lib/ -lxavna -lfftw3 -L/dev/shm/nanoVNA/NanoVNA-QT-master/vna_qt/../libxavna/xavna_mock_ui/ -lxavna_mock_ui /usr/lib64/libQt5Charts.so /usr/lib64/libQt5Svg.so /usr/lib64/libQt5Widgets.so /usr/lib64/libQt5Gui.so /usr/lib64/libQt5Core.so -lGL -lpthread /dev/shm/nanoVNA/NanoVNA-QT-master /dev/shm/nanoVNA/NanoVNA_QT_GUI-x86_64.AppImage: tmp.mount_NanoVNCFCtC0/lib/libQt5Core.so.5: version `Qt_5.15' not found (required by /dev/shm/nanoVNA/NanoVNA-QT-master/libxavna/xavna_mock_ui/libxavna_mock_ ui.so.1) Jetzt muss ich nur noch den richtigen QT dev Pfad angeben. LG Markus
Und es hat dank Deiner Hilfe geklappt.
>objdump -a vna_qt
vna_qt: file format elf64-x86-64
vna_qt
ldd vna_qt
linux-vdso.so.1 (0x00007fff7f154000)
libxavna.so.0 => not found <=== trotzdem Läuft das Programm ???
libfftw3.so.3 => /usr/lib64/libfftw3.so.3 (0x00007f84b040c000)
libxavna_mock_ui.so.1 => not found <=== trotzdem Läuft das Programm
libQt5Charts.so.5 => /usr/lib64/libQt5Charts.so.5 (0x00007f84b0248000)
libQt5Svg.so.5 => /usr/lib64/libQt5Svg.so.5 (0x00007f84b01ee000)
libQt5Widgets.so.5 => /usr/lib64/libQt5Widgets.so.5
(0x00007f84afb4b000)
libQt5Gui.so.5 => /usr/lib64/libQt5Gui.so.5 (0x00007f84af458000)
libQt5Core.so.5 => /usr/lib64/libQt5Core.so.5 (0x00007f84aeeb7000)
libGL.so.1 => /usr/lib64/libGL.so.1 (0x00007f84aee1e000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f84aedfc000)
libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00007f84aec26000)
libm.so.6 => /lib64/libm.so.6 (0x00007f84aeae0000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f84aeac4000)
libc.so.6 => /lib64/libc.so.6 (0x00007f84ae8fe000)
libz.so.1 => /lib64/libz.so.1 (0x00007f84ae8e4000)
libpng16.so.16 => /usr/lib64/libpng16.so.16 (0x00007f84ae89c000)
libharfbuzz.so.0 => /usr/lib64/libharfbuzz.so.0 (0x00007f84ae7c6000)
libsystemd.so.0 => /usr/lib64/libsystemd.so.0 (0x00007f84ae719000)
libdouble-conversion.so.3 => /usr/lib64/libdouble-conversion.so.3
(0x00007f84ae709000)
libicui18n.so.67 => /usr/lib64/libicui18n.so.67 (0x00007f84ae3fc000)
libicuuc.so.67 => /usr/lib64/libicuuc.so.67 (0x00007f84ae212000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007f84ae20d000)
libpcre2-16.so.0 => /usr/lib64/libpcre2-16.so.0 (0x00007f84ae15a000)
libzstd.so.1 => /usr/lib64/libzstd.so.1 (0x00007f84ae0c1000)
libglib-2.0.so.0 => /usr/lib64/libglib-2.0.so.0 (0x00007f84adf99000)
/lib64/ld-linux-x86-64.so.2 (0x00007f84b0653000)
libGLX.so.0 => /usr/lib64/libGLX.so.0 (0x00007f84adf67000)
libGLdispatch.so.0 => /usr/lib64/libGLdispatch.so.0
(0x00007f84adea9000)
libfreetype.so.6 => /usr/lib64/libfreetype.so.6 (0x00007f84addee000)
libgraphite2.so.3 => /usr/lib64/libgraphite2.so.3 (0x00007f84addcc000)
librt.so.1 => /lib64/librt.so.1 (0x00007f84addbf000)
liblzma.so.5 => /usr/lib64/liblzma.so.5 (0x00007f84add83000)
liblz4.so.1 => /usr/lib64/liblz4.so.1 (0x00007f84add63000)
libgcrypt.so.20 => /usr/lib64/libgcrypt.so.20 (0x00007f84adc49000)
libicudata.so.67 => /usr/lib64/libicudata.so.67 (0x00007f84adc46000)
libpcre.so.1 => /usr/lib64/libpcre.so.1 (0x00007f84adbac000)
libX11.so.6 => /usr/lib64/libX11.so.6 (0x00007f84ada68000)
libbz2.so.1 => /usr/lib64/libbz2.so.1 (0x00007f84ada48000)
libgpg-error.so.0 => /usr/lib64/libgpg-error.so.0 (0x00007f84ada28000)
libxcb.so.1 => /usr/lib64/libxcb.so.1 (0x00007f84ad9fd000)
libXau.so.6 => /usr/lib64/libXau.so.6 (0x00007f84ad9f8000)
Markus
Das erste Lib 'not found' konnte ich schon lösen.
>ldd vna_qt | grep 'not found'
Bleibt nur noch 'libxavna_mock_ui.so'
Markus
jetzt passt es! Nochmals Danke! >ldd vna_qt | grep 'not found' (kein pattern match!!!) >ldd ./vna_qt linux-vdso.so.1 (0x00007fff8cd42000) libxavna.so.0 => /usr/local/lib64/libxavna.so.0 (0x00007f94f2708000) libfftw3.so.3 => /usr/lib64/libfftw3.so.3 (0x00007f94f2509000) libxavna_mock_ui.so.1 => /usr/lib/libxavna_mock_ui.so.1 (0x00007f94f24e7000) libQt5Charts.so.5 => /usr/lib64/libQt5Charts.so.5 (0x00007f94f2323000) libQt5Svg.so.5 => /usr/lib64/libQt5Svg.so.5 (0x00007f94f22c9000) libQt5Widgets.so.5 => /usr/lib64/libQt5Widgets.so.5 (0x00007f94f1c26000) libQt5Gui.so.5 => /usr/lib64/libQt5Gui.so.5 (0x00007f94f1533000) libQt5Core.so.5 => /usr/lib64/libQt5Core.so.5 (0x00007f94f0f92000) libGL.so.1 => /usr/lib64/libGL.so.1 (0x00007f94f0ef9000) libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f94f0ed7000) libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00007f94f0d01000) libm.so.6 => /lib64/libm.so.6 (0x00007f94f0bbb000) libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f94f0b9f000) libc.so.6 => /lib64/libc.so.6 (0x00007f94f09d9000) libz.so.1 => /lib64/libz.so.1 (0x00007f94f09bf000) libpng16.so.16 => /usr/lib64/libpng16.so.16 (0x00007f94f0977000) libharfbuzz.so.0 => /usr/lib64/libharfbuzz.so.0 (0x00007f94f08a1000) libsystemd.so.0 => /usr/lib64/libsystemd.so.0 (0x00007f94f07f4000) libdouble-conversion.so.3 => /usr/lib64/libdouble-conversion.so.3 (0x00007f94f07e4000) libicui18n.so.67 => /usr/lib64/libicui18n.so.67 (0x00007f94f04d7000) libicuuc.so.67 => /usr/lib64/libicuuc.so.67 (0x00007f94f02ed000) libdl.so.2 => /lib64/libdl.so.2 (0x00007f94f02e8000) libpcre2-16.so.0 => /usr/lib64/libpcre2-16.so.0 (0x00007f94f0235000) libzstd.so.1 => /usr/lib64/libzstd.so.1 (0x00007f94f019a000) libglib-2.0.so.0 => /usr/lib64/libglib-2.0.so.0 (0x00007f94f0074000) /lib64/ld-linux-x86-64.so.2 (0x00007f94f2796000) libGLX.so.0 => /usr/lib64/libGLX.so.0 (0x00007f94f0042000) libGLdispatch.so.0 => /usr/lib64/libGLdispatch.so.0 (0x00007f94eff84000) libfreetype.so.6 => /usr/lib64/libfreetype.so.6 (0x00007f94efec9000) libgraphite2.so.3 => /usr/lib64/libgraphite2.so.3 (0x00007f94efea5000) librt.so.1 => /lib64/librt.so.1 (0x00007f94efe9a000) liblzma.so.5 => /usr/lib64/liblzma.so.5 (0x00007f94efe5e000) liblz4.so.1 => /usr/lib64/liblz4.so.1 (0x00007f94efe3e000) libgcrypt.so.20 => /usr/lib64/libgcrypt.so.20 (0x00007f94efd24000) libicudata.so.67 => /usr/lib64/libicudata.so.67 (0x00007f94efd21000) libpcre.so.1 => /usr/lib64/libpcre.so.1 (0x00007f94efc87000) libX11.so.6 => /usr/lib64/libX11.so.6 (0x00007f94efb43000) libbz2.so.1 => /usr/lib64/libbz2.so.1 (0x00007f94efb23000) libgpg-error.so.0 => /usr/lib64/libgpg-error.so.0 (0x00007f94efb03000) libxcb.so.1 => /usr/lib64/libxcb.so.1 (0x00007f94efad8000) libXau.so.6 => /usr/lib64/libXau.so.6 (0x00007f94efad1000)
