1 | U-Boot 2011.12.(TRUNK_CURRENT)-svn99721 (Oct 24 2019 - 09:15:40)
2 |
3 | Board: RTL9300 CPU:800MHz LX:175MHz DDR:600MHz
4 | DRAM: 128 MB
5 | SPI-F: MXIC/C22018/MMIO16-1/ModeC 1x16 MB (plr_flash_info @ 83f831e4)
6 | Loading 65536B env. variables from offset 0xe0000
7 | Net: Net Initialization Skipped
8 | No ethernet found.
9 | Hit Esc key to stop autoboot: 0
10 | ## Booting image from partition ... 0
11 | ## Booting kernel from Legacy Image at 81000000 ...
12 | Image Name: RTK_SDK
13 | Created: 2019-10-24 9:16:10 UTC
14 | Image Type: MIPS Linux Kernel Image (lzma compressed)
15 | Data Size: 4577343 Bytes = 4.4 MB
16 | Load Address: 80000000
17 | Entry Point: 80283510
18 | Verifying Checksum ... OK
19 | Uncompressing Kernel Image ... OK
20 |
21 | Starting kernel ...
22 |
23 | console [ttyS0] enabled
24 | bootconsole [early0] disabled
25 | Calibrating delay loop... 531.66 BogoMIPS (lpj=2658304)
26 | pid_max: default: 32768 minimum: 301
27 | Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
28 | Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
29 | NET: Registered protocol family 16
30 | SCSI subsystem initialized
31 | usbcore: registered new interface driver usbfs
32 | usbcore: registered new interface driver hub
33 | usbcore: registered new device driver usb
34 | NET: Registered protocol family 2
35 | TCP established hash table entries: 1024 (order: 0, 4096 bytes)
36 | TCP bind hash table entries: 1024 (order: 2, 20480 bytes)
37 | TCP: Hash tables configured (established 1024 bind 1024)
38 | TCP: reno registered
39 | UDP hash table entries: 256 (order: 1, 12288 bytes)
40 | UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
41 | NET: Registered protocol family 1
42 | futex hash table entries: 256 (order: 0, 7168 bytes)
43 | msgmni has been set to 239
44 | random: modprobe urandom read with 0 bits of entropy available
45 | io scheduler noop registered
46 | io scheduler deadline registered
47 | io scheduler cfq registered (default)
48 | Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
49 | serial8250: ttyS0 at MMIO 0x0 (irq = 39, base_baud = 10764700) is a 16550A
50 | RTK_SPI_FLASH_MIO driver is bypassed
51 | RTK_NORSFG3 driver is used
52 | =================================================================
53 | init_luna_nor_spi_map: flash map at 0xb4000000
54 | SPI NOR driver probe...
55 | MXIC/C22018/MMIO16-1/ModeC add SPI NOR partition
56 | MTD partitions obtained from built-in array
57 | Creating 7 MTD partitions on "rtk_norsf_g3":
58 | 0x000000000000-0x0000000e0000 : "LOADER"
59 | 0x0000000e0000-0x0000000f0000 : "BDINFO"
60 | 0x0000000f0000-0x000000100000 : "SYSINFO"
61 | 0x000000100000-0x000000200000 : "JFFS2 CFG"
62 | 0x000000200000-0x000000300000 : "JFFS2 LOG"
63 | 0x000000300000-0x000000980000 : "RUNTIME"
64 | 0x000000980000-0x000001000000 : "RUNTIME2"
65 | =================================================================
66 | ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
67 | rtk_gen1_hcd_cs_init: rtk_gen1_hcd_cs_init()!
68 | rtk_gen1_hcd_cs_init: register rtk_gen1_ehci ok!
69 | usb_phy_configure_process: usb_phy_configure_process()!
70 | rtk_gen1-ehci rtk_gen1-ehci: Realtek On-Chip EHCI Host Controller
71 | rtk_gen1-ehci rtk_gen1-ehci: new USB bus registered, assigned bus number 1
72 | rtk_gen1-ehci rtk_gen1-ehci: irq 20, io mem 0x18021000
73 | rtk_gen1-ehci rtk_gen1-ehci: USB 2.0 started, EHCI 1.00
74 | hub 1-0:1.0: USB hub found
75 | hub 1-0:1.0: 1 port detected
76 | usbcore: registered new interface driver usbtmc
77 | usbcore: registered new interface driver usb-storage
78 | TCP: cubic registered
79 | NET: Registered protocol family 17
80 | Freeing unused kernel memory: 3316K (803a3000 - 806e0000)
81 | init started: BusyBox v1.00 (2019.10.23-06:17+0000) multi-call binary
82 | Starting pid 25, console : '/etc/rc'
83 | RTCORE LKM Insert...
84 |
85 | allocate mem to rtcore_devices[0].rt_data=0x87c8f000
86 | RTCORE Driver Module Initialize
87 | IOAL init
88 | Log init
89 | Hardware-profile probe (Forced profile: RTL9302B_8218D_2x8226_2xGE)
90 | (RTL9302B_8218D_2x8226_2xGE)
91 | Hardware-profile init
92 | GPIO probe (unit 0): (found)
93 | GPIO Init
94 | Reset PHY gpio OK!
95 | SPI init (unit 0) (type3)
96 | SPI Master init
97 | TC probe (unit 0): (found)
98 | TC init (unit 0)
99 | TC util init (unit 0)
100 | TC util init (isr)
101 | Watchdog probe (unit 0): (found)
102 | Watchdog init (unit 0)
103 | I2C probe (unit 0)
104 | I2C init (unit 0)
105 | RTL8231 probe (unit 0): (found)
106 | RTL8231 init (unit 0)
107 | NIC probe (unit 0)
108 | IOAL init
109 | L2Ntfy probe (unit 0): (found)
110 | RTK Driver Module Initialize
111 | MAC probe (unit 0)
112 | Chip 9302 (found)
113 | MAC init (unit 0)
114 | SMI protocol probe (unit 0)
115 | PHY probe (unit 0)
116 | Chip Construct (unit 0)
117 | Chip Construct
118 | Disable PHY Polling
119 | PHY Reset
120 | MAC Construct
121 | Turn Off Serdes
122 | Serdes Construct
123 | PHY Construct
124 | Turn On Serdes
125 | Enable PHY Polling
126 | Misc
127 | PHY init (unit 0)
128 | Mgmt_dev init (unit 0)
129 | I2C device init (unit 0)
130 | I2C device init (unit 0)
131 | RTNIC Driver Module Initialize
132 | RTDRV Driver Module Initialize
133 | route: not found
134 | RTK.0>
