ATMEGA328P: externer Interrupt INT0 funktioniert nicht
OP #6442089
Hallo miteinander;
kann mir jemand sagen warum ich nicht in die Interruptroutine komme wenn
ich den Arduino Uno PIN 2 auf GND lege ?
.include "m328Pdef.inc"
.def temp = r16
rjmp start    ; 1     Reset
rjmp interrupt0          ; 2   External Interrupt Request 0   INT0_vect
reti      ; 3   External Interrupt Request 1   INT1_vect
reti      ; 4   Pin Change Interrupt Request 0   PCINT0_vect
reti      ; 5   Pin Change Interrupt Request 1   PCINT1_vect
reti      ; 6   Pin Change Interrupt Request 2   PCINT2_vect
reti      ; 7   Watchdog Time-out Interrupt   WDT_vect
reti      ; 8   Timer/Counter2 Compare Match A   TIMER2_COMPA_vect
reti      ; 9   Timer/Counter2 Compare Match B   TIMER2_COMPB_vect
reti      ; 10  Timer/Counter2 Overflow   TIMER2_OVF_vect
reti      ; 11  Timer/Counter1 Capture Event   TIMER1_CAPT_vect
reti      ; 12  Timer/Counter1 Compare Match A   TIMER1_COMPA_vect
reti      ; 13  Timer/Counter1 Compare Match B   TIMER1_COMPB_vect
reti      ; 14  Timer/Counter1 Overflow   TIMER1_OVF_vect
reti      ; 15  Timer/Counter0 Compare Match A   TIMER0_COMPA_vect
reti      ; 16  Timer/Counter0 Compare Match B   TIMER0_COMPB_vect
reti      ; 17  Timer/Counter0 Overflow   TIMER0_OVF_vect
reti      ; 18  SPI Serial Transfer Complete   SPI_STC_vect
reti      ; 19  USART Rx Complete   USART_RX_vect
reti      ; 20  USART Data Register Empty   USART_UDRE_vect
reti      ; 21  USART Tx Complete   USART_TX_vect
reti      ; 22  ADC Conversion Complete   ADC_vect
reti      ; 23  EEPROM Ready   EE_READY_vect
reti      ; 24  Analog Comparator   ANALOG_COMP_vect
reti      ; 25  Two-wire Serial Interface   TWI_vect
reti      ; 26  Store Program Memory Read   SPM_READY_vect
start:
ldi temp, high(RAMEND)
out SPH , temp
ldi temp, low(RAMEND)
out SPL , temp
ldi temp, 0b00000000
out DDRD, temp
ldi temp, 0b00100000
out DDRB, temp
ldi temp, 0
sts EICRA, temp
ldi temp, 1
out EIMSK, temp
sei
loop:
rjmp loop
interrupt0:
sbi  PORTB, 5
reti
Wenn ich das Pendant über die Arduino-IDE laufen lasse dann klappt es :
#include <avr/interrupt.h>
void setup()
pinMode(13, OUTPUT);
EICRA=0;
EIMSK=1;
sei();
void loop()
void blink()
Serial.println(millis());
ISR (INT0_vect)
digitalWrite(13, 1);
Gast #6442091
Ohne mir das Programm weiter angeschaut zu haben, aus dem def.inc:
; ***** INTERRUPT VECTORS ************************************************
.equ  INT0addr  = 0x0002  ; External Interrupt Request 0
.equ  INT1addr  = 0x0004  ; External Interrupt Request 1
.equ  PCI0addr  = 0x0006  ; Pin Change Interrupt Request 0
.equ  PCI1addr  = 0x0008  ; Pin Change Interrupt Request 0
Gast #6442119
Michael S. schrieb:
> Danke für den Hinweis, aber was genau muss ich damit machen ?
Assembler lernen. Was sonst?
Eine sinnvolle Deklaration eine Interruptvektors sieht z.B. so aus:
.ORG <Name des Vektors>
<Inhalt für den Vektor>
.ORG <Name eines anderen Vektors>
<Inhalt für eben diesen anderen Vektor>
Dann spielt schonmal die Reihenfolge keine Rolle, in der du die
Interruptvektoren definierst. Es müssen dann auch nicht mehr alle
Interruptvektoren definiert werden, sondern nur die tatsächlich benutzen
(wobei du dafür verantwortlich bist, keinen zu erlauben, der nicht auf
diese Art definiert wurde, sonst: sehr wahrscheinlich Crash)
Darüber hinaus spielt die Größe der Interruptvektoren "keine" Rolle
mehr. Du kannst als <Inhalt für den Vektor> reinschreiben, was immer du
willst, insbesondere auch rjmp in eine Vektortabelle für "große" AVR.
Erst wenn du mit anderen Vektoren in Konflikt kommst, weil du mehr Code
hier unterzubringen versuchst, als tatsächlich an dieser Stelle bei der
gegenwärtigen Nutzung verfügbar ist, dann knallt's. Aber schon zur
Assemblierzeit, da wird denn (sinngemaß) bemeckert, dass der Codespace
schon belegt ist. Solange du aber als Code in der Vektordefinition nur
die üblichen Varianten rjmp oder reti verwendest, sollte es dazu nicht
kommen. Auf "großen" AVR kannst du bei diesem Ansatz aber auch
problemlos jmp verwenden, wenn sonst der Sprung zum Ziel zu weit ist.
