1 | #include <UTFT.h>
2 | #include <Wire.h>
3 | #include <HX711.h>
4 |
5 | HX711 scale(A1, A0);
6 |
7 | long Rohwert; // vom HX711 gelieferter Rohwert
8 | long offset = 5300; // offset
9 | float Scale = 50000; // scale
10 | float Kraft_alt, Kraft_neu; // berechnete Kraft in N
11 |
12 |
13 | // Declare which fonts we will be using
14 | extern uint8_t SmallFont[];
15 |
16 | UTFT myGLCD(ILI9486,38,39,40,41);
17 |
18 | int i, j; // Zählvariable
19 |
20 | const int offsetPin = 2; // the number of the pushbutton pin
21 | int offsetState = 0; // variable for reading the pushbutton status
22 | const int startPin = 3; // the number of the switch pin
23 | int startState = 0; // variable for reading the switch status
24 |
25 |
26 |
27 | // ====================================
28 | // === ===
29 | // === SETUP ===
30 | // === ===
31 | // ====================================
32 |
33 | void setup()
34 | {
35 | Serial.begin(9600);
36 | // while(!Serial); // time to get serial running
37 |
38 | pinMode(offsetPin, INPUT);
39 | pinMode(startPin, INPUT);
40 |
41 | // Setup the LCD
42 | myGLCD.InitLCD();
43 | myGLCD.setFont(SmallFont);
44 | myGLCD.clrScr();
45 |
46 | myGLCD.setColor(255, 255, 0);
47 | myGLCD.fillRect(0, 0, 479, 13);
48 | myGLCD.setColor(0, 0, 0);
49 | myGLCD.setBackColor(255, 255, 0);
50 | myGLCD.print("Newtonmeter - stoppi", CENTER, 1);
51 |
52 |
53 | scale.set_gain(128); // A-Kanal: gain = 64 oder 128; B-Kanal: fix 32
54 |
55 | Kraft_alt = 0.0;
56 | }
57 |
58 |
59 |
60 |
61 | // ====================================
62 | // === ===
63 | // === HAUPTSCHLEIFE ===
64 | // === ===
65 | // ====================================
66 |
67 | void loop()
68 | {
69 | while(startState = digitalRead(startPin)) // Warten bis start-Taster betätigt wurde
70 | {
71 | Rohwert = scale.read(); // Einlesen eines Rohwerts
72 |
73 | Kraft_neu = (Rohwert - offset) / Scale; // Berechnung der Kraft in Newton
74 |
75 | //Serial.println(Kraft_neu);
76 |
77 | myGLCD.setColor(0, 255, 0);
78 | myGLCD.setBackColor(0, 0, 0);
79 | myGLCD.print(" ", 70, 18);
80 | myGLCD.printNumF(Kraft_neu, 2, 70, 18);
81 |
82 | offsetState = digitalRead(offsetPin); // button for new tara (offset)
83 |
84 | if (offsetState == LOW)
85 | {
86 | offset = scale.read(); // Einlesen eines Rohwerts zur Ermittlung des offsets
87 | }
88 |
89 | delay(20);
90 | }
91 |
92 | Kraft_alt = 0.0;
93 |
94 | myGLCD.clrScr();
95 |
96 | myGLCD.setColor(255, 255, 0);
97 | myGLCD.fillRect(0, 0, 479, 13);
98 | myGLCD.setColor(0, 0, 0);
99 | myGLCD.setBackColor(255, 255, 0);
100 | myGLCD.print("Newtonmeter - stoppi", CENTER, 1);
101 |
102 | // Zeichnen der beiden Achsen
103 |
104 | myGLCD.setColor(255, 255, 255);
105 | myGLCD.drawLine(50,290,430,290);
106 | myGLCD.drawLine(50,20,50,290);
107 |
108 | myGLCD.setColor(255, 255, 255);
109 | myGLCD.setBackColor(0, 0, 0);
110 | myGLCD.print("F[N]", 5, 18);
111 | myGLCD.setColor(255, 255, 255);
112 | myGLCD.setBackColor(0, 0, 0);
113 | myGLCD.print("t[sec]", 420, 300);
114 |
115 | myGLCD.setColor(255, 255, 255);
116 | myGLCD.drawLine(45,290,50,290);
117 | myGLCD.drawLine(45,240,50,240);
118 | myGLCD.drawLine(45,190,50,190);
119 | myGLCD.drawLine(45,140,50,140);
120 | myGLCD.drawLine(45,90,50,90);
121 | myGLCD.drawLine(45,40,50,40);
122 |
123 | myGLCD.drawLine(50,290,50,295);
124 | myGLCD.drawLine(100,290,100,295);
125 | myGLCD.drawLine(150,290,150,295);
126 | myGLCD.drawLine(200,290,200,295);
127 | myGLCD.drawLine(250,290,250,295);
128 | myGLCD.drawLine(300,290,300,295);
129 | myGLCD.drawLine(350,290,350,295);
130 | myGLCD.drawLine(400,290,400,295);
131 |
132 | myGLCD.setColor(255, 255, 255);
133 | myGLCD.setBackColor(0, 0, 0);
134 | myGLCD.printNumI(0,30,285);
135 | myGLCD.printNumI(2,30,235);
136 | myGLCD.printNumI(4,30,185);
137 | myGLCD.printNumI(6,30,135);
138 | myGLCD.printNumI(8,30,85);
139 | myGLCD.printNumI(10,25,35);
140 |
141 | myGLCD.printNumI(0,48,300);
142 | myGLCD.printNumI(4,98,300);
143 | myGLCD.printNumI(8,148,300);
144 | myGLCD.printNumI(12,194,300);
145 | myGLCD.printNumI(16,244,300);
146 | myGLCD.printNumI(20,294,300);
147 | myGLCD.printNumI(24,344,300);
148 | myGLCD.printNumI(28,394,300);
149 |
150 |
151 | // graues Gitternetz zeichnen
152 |
153 | myGLCD.setColor(120, 120, 120);
154 | myGLCD.drawLine(51,265,430,265);
155 | myGLCD.drawLine(51,240,430,240);
156 | myGLCD.drawLine(51,215,430,215);
157 | myGLCD.drawLine(51,190,430,190);
158 | myGLCD.drawLine(51,165,430,165);
159 | myGLCD.drawLine(51,140,430,140);
160 | myGLCD.drawLine(51,115,430,115);
161 | myGLCD.drawLine(51,90,430,90);
162 | myGLCD.drawLine(51,65,430,65);
163 | myGLCD.drawLine(51,40,430,40);
164 |
165 | myGLCD.drawLine(100,40,100,289);
166 | myGLCD.drawLine(150,40,150,289);
167 | myGLCD.drawLine(200,40,200,289);
168 | myGLCD.drawLine(250,40,250,289);
169 | myGLCD.drawLine(300,40,300,289);
170 | myGLCD.drawLine(350,40,350,289);
171 | myGLCD.drawLine(400,40,400,289);
172 |
173 |
174 | myGLCD.setColor(0, 255, 0);
175 |
176 | for(i = 1; i <= 380; i++)
177 | {
178 | offsetState = digitalRead(offsetPin); // button for new tara (offset)
179 |
180 | if (offsetState == LOW)
181 | {
182 | offset = scale.read(); // Einlesen eines Rohwerts zur Ermittlung des offsets
183 | }
184 |
185 |
186 | //Rohwert = scale.read_average(2); // Einlesen der gemittelten Rohwerten
187 | Rohwert = scale.read(); // Einlesen eines Rohwerts
188 |
189 | Kraft_neu = (Rohwert - offset) / Scale; // Berechnung der Kraft in Newton
190 |
191 | //Serial.println(Rohwert);
192 |
193 | myGLCD.print(" ", 70, 18);
194 | myGLCD.printNumF(Kraft_neu, 2, 70, 18);
195 |
196 | if(Kraft_neu >= 0 && Kraft_neu <= 10)
197 | {
198 | //myGLCD.drawPixel(50 + i, 290 - Kraft * 25);
199 | myGLCD.drawLine(50 + (i - 1),290 - Kraft_alt * 25,50 + i,290 - Kraft_neu * 25);
200 |
201 | Kraft_alt = Kraft_neu;
202 | }
203 |
204 | }
205 |
206 | }
